Go Back   RC Groups > RC Clubs > International Scale Soaring Association (ISSA)
Old Dec 24, 2006, 01:20 AM   #46
Hi there Scale builder whats the big yellow wing in the background???
Big Nuts 181 is offline Find More Posts by Big Nuts 181   Reply With Quote
Old Dec 25, 2006, 12:17 PM   #47
scalebldr
scalebldr's Avatar
HI, 1:3 scale Cmelak, from Airworld, with a Moki 215cc 5 cyl raidal. Just finished a month ago.
  • Name: MVC-005F.jpg
Description: I copyed a full size from Hungary. I copyed a full size from Hungary. 75.4 KB · Views: 225
scalebldr is offline Find More Posts by scalebldr   Reply With Quote
Old Jan 03, 2007, 05:03 AM   #48
that is a gorgous model! I have been campaining my 40% 1-26 over the last couple of years now, and she's still doing big aero's. To tow her up and the following 40% 2-32 I have been building a 1-30 with a 140 king in the front for power, hopefully it won't take me too much longer!!
  • Name: 501.jpg
Description: on maiden flight at camperdown on maiden flight at camperdown 58.2 KB · Views: 195
  • Name: Mail0019.jpg
Description: the real 1-30 in 1965 the real 1-30 in 1965 50.2 KB · Views: 182
  • Name: 516.jpg
Description: the easy way to get the model back to camp! the easy way to get the model back to camp! 118.1 KB · Views: 207
  • Name: 1187.jpg
Description: landing at bendigo last year. landing at bendigo last year. 54.6 KB · Views: 177
  • Name: 100_1072.jpg
Description: sorry about the mess, as a refrence for size the table is a 8ft x 4ft sorry about the mess, as a refrence for size the table is a 8ft x 4ft 87.8 KB · Views: 216
Old Jan 03, 2007, 06:33 AM   #49
Rick, hope you're planning on bringing the new Cmelak and ASW-28 to the JR event this year, can't imagine a prettier picture than seeing the ASW towed by that yellow bent wing bird.
Steve
SteveR is offline Find More Posts by SteveR   Reply With Quote
Old Jan 04, 2007, 11:22 AM   #50
scalebldr
scalebldr's Avatar
Steve
HI Steve, not sure about the Cmelak, but will bring the 28.
Rick
Old Jan 04, 2007, 11:25 AM   #51
scalebldr
scalebldr's Avatar
Looking good, I bet your 26 is a great flyer, how much does it weigh? and what servos did you use?
Rick
Old Jan 04, 2007, 03:44 PM   #52
scalebldr
scalebldr's Avatar
Making the side combings
Making the side combings is much the same as I did on the 26 except I am making the plugs removable so I can mold them.
Since this model is bigger it's a little easier to work on and I wanted to keep the weight down so making molds for lighter parts made sence.
Later I will show the cocpit with the parts in place and primed.
  • Name: MVC-012F.jpg
Description: Here is the left side patern with a foam former. Here is the left side patern with a foam former. 41.8 KB · Views: 147
  • Name: MVC-013F.jpg
Description: I masked the inside of the fuse, then used partal wax mold release.
Clamped the formers in place ready for body filler. I masked the inside of the fuse, then used partal wax mold release. Clamped the formers in place ready for body filler. 50.7 KB · Views: 215
  • Name: MVC-014F.jpg
Description: Here is the rough plugs with some referance photos. Here is the rough plugs with some referance photos. 41.5 KB · Views: 207
  • Name: MVC-017F.jpg
Description: Fiting and finishing the right side.
Here you see the air vent and the mount for the seat adjustment pad. Fiting and finishing the right side. Here you see the air vent and the mount for the seat adjustment pad. 43.9 KB · Views: 202
  • Name: MVC-018F.jpg
Description: Same with the left side.
Here you see the flap and spoiler recess and the tow release faring. Same with the left side. Here you see the flap and spoiler recess and the tow release faring. 44.8 KB · Views: 158
  • Name: MVC-019F.jpg
Description: Here I show the plugs primed with polyester primer Here I show the plugs primed with polyester primer 46.4 KB · Views: 167
  • Name: MVC-015F.jpg
Description: Here I made the bulkheads to hide the rear of the cocpit.
I used light ply that is removable with screws. The top white cardboard templet will be fited after the combings are permante. Here I made the bulkheads to hide the rear of the cocpit. I used light ply that is removable with screws. The top white cardboard templet will be fited after the combings are permante. 48.4 KB · Views: 205
  • Name: MVC-022F.jpg
Description: Here you see how the right side combing fits the rear bulkhead. Here you see how the right side combing fits the rear bulkhead. 53.4 KB · Views: 231
  • Name: MVC-023F.jpg
Description: Again on the right side.
The tape on the seat tray is marking where the landing gear handel with go. Again on the right side. The tape on the seat tray is marking where the landing gear handel with go. 53.2 KB · Views: 208
  • Name: MVC-024F.jpg
Description: Here you see the left side in the rough.
Starting to look like the real thing.  Here you see the left side in the rough. Starting to look like the real thing. 56.7 KB · Views: 193
Old Jan 04, 2007, 05:36 PM   #53
Rick, your cockpit is looking super! How do you get from the foam formers that you clamp in place to the rough plugs? Is it simply a matter of globbing on body putty and sculpting it? If so, what gives the plugs some strength and keeps them from cracking?
Also, you mentioned using 3 oz cloth for the air scoop on my Cub. Where do you find this weight as the LHS don't seem to carry it?
Steve
Old Jan 04, 2007, 08:56 PM   #54
scalebldr
scalebldr's Avatar
Steve
Steve
The body filler is fairly hard when it cures. I did place a steel rod on the left side combing to bridge the thinner section where the flap a spoiler controls will be.
Try getting it from CST http://www.cstsales.com/index.html They have distrubutors all over. The have every thing you need except polyester resins, you can get that any marine store or mabe a hardware store. The also carry a wide variety of fiberglass and carbon plate, so you could use the idea that BN 181 referd to for your Cubs scoop.
Rick
Old Jan 04, 2007, 09:56 PM   #55
Thanks Rick, will have to coordinate one of my CA business trips with Visalia, etc., so I can listen to your 215cc 5-cylinder wind up for a takeoff...gotta be a thrill!
Steve
Old Jan 05, 2007, 10:57 AM   #56
Rick
High there Rick my first composite 1-26 (the one in the picture) came out a tad heavy at 45lb but much of that was "developmental" weight but the new model weighs in at 35 lb and a wing area of 25 1/2 square feet. Even so at that weight she is a floater on the slope with presence and on the flat the model can 'hang' around in an almost spookey manner. The servos I used were the Hitech 30kg for rudder and elevator, 12 kg on each aileron and tow release and 6kg on each airbrake. And to power it all 2 5 cell packs.
cheers Rossco
Old Jan 27, 2007, 01:42 PM   #57
Rick, was at HKM today in Germany and Willi is setting up a big ASW-28 with a Schambeck up and go system. Very, very cool and there's such a small opening on the top of the fuselage. If you don't add one, surely Dan T. will!
Regards,
Steve
Old Jan 28, 2007, 08:54 PM   #58
scalebldr
scalebldr's Avatar
Regards,
Steve
Hey! don't post this kind of message with out photos, are you nuts. Its like watching the superbowl with a tied game with 6 seconds to go and a field goal is about to be kicked and the satilite blows up! Is this the 40% Im building?
Rick
Old Jan 29, 2007, 07:37 AM   #59
Geeezzz, next time I'll remember to bring a camera along when I visit HKM! Of course it's the big ASW-28. The Schambeck is barely visible in that big fuse. I'll see if I can get HKM to send along some photos. Willi was setting up a new 28 while I was in the store and he demo'd the up and go system (without spinning the prop, of course). It is a very slick unit.
Steve
Old Jan 29, 2007, 01:53 PM   #60
scalebldr
scalebldr's Avatar
Steve
Hey sounds prety neet, I would love to build a 1/2 scale with the Schambeck.
I understand that it keeps the C/G problem at a minimum. Hows the weather over there? Sure do mis Germay.
Rick
Build Log HKM ASW28 1.2.5 scale scalebldr Scale Sailplanes 1 May 15, 2007 10:41 PM
New Product The big one flies! 7.2 meter ASW 28 by HKM hkm-usa Scale Sailplanes 31 Jun 06, 2006 07:14 AM
For Sale fs aveox 27/13/4 brushless with mega 1:2.5 gearbox erict Aircraft - Electric - Airplanes (FS/W) 7 May 30, 2005 01:35 PM
FS speed 400 gearbox 2:1 2.5:1 3:1 pinions barb wire Aircraft - Electric - Airplanes (FS/W) 0 Feb 01, 2005 08:36 PM
2,1 and 2,5 ccm nitro question aveox Motorcycles 2 Jan 09, 2005 09:43 AM
Bored? Want to fight?
Join the RCGroups clan!
