Old Jul 27, 2006, 08:44 AM
Geoff_S is online now
Find More Posts by Geoff_S
Geoff_S's Avatar
Brisbane, Australia
Joined Feb 2002
HF Models: DG303 vs ASW28
Is anyone familiar with how the HF Models DG303 (3.3m) compares in flight to the 3m ASW28 ? Is the DG particularly more aerobatic, or would they both be considered pretty mild when it comes to slope aerobatics ?
thanks
Geoff
Geoff_S is online now Find More Posts by Geoff_S
Old Aug 01, 2006, 11:19 PM
Commplexxo is offline
Find More Posts by Commplexxo
Calgary, Alberta CANADA
Joined Feb 2004
If you're looking at the HF line of models - always go bigger (i.e. 4m ASW 28). If you're looking at the 3.6 m version of the models then I would suggest HF DG 1000 or DG 505. DG 505 is "more aerobatic" if you will.
I have flown the HF DG 303 3.6m, HF ASW 28 4m and the HF DG 505 3.6m. My picks would be from best first to not as great last (as you see I like bigger models).
HF ASW 28 4m
HF DG 505 3.6m
HF DG 303 3.6m
My 2 cents.
Good Luck,
Martin
Commplexxo is offline Find More Posts by Commplexxo
Old Aug 24, 2006, 12:12 PM
jorgeeli is offline
Find More Posts by jorgeeli
Joined Aug 2004
Does HF still make the 4m ASW28? I totalled mine and would like to replace it, but as far as I can tell, they no longer make the 4m.
Am I correct? I hope not.
jorgeeli is offline Find More Posts by jorgeeli
Old Aug 24, 2006, 12:44 PM
SteveR is offline
Find More Posts by SteveR
New York
Joined Feb 2002
I've got a NIB all molded HF ASW-28 that I'm never going to get to build (too many birds in the hanger). If interested, just send a PM.
Regards,
Steve
SteveR is offline Find More Posts by SteveR
Old Aug 24, 2006, 01:19 PM
TFLG is offline
Find More Posts by TFLG
TFLG's Avatar
United States, CA, Riverside
Joined Feb 2002
If you go with the sheeted wings you can always add flaps to make the plane a bit more aerobatic. I have the DG-1000 and the DG-505 and I added flaps to both models. With the flaps mixed to the ailerons I get a reasonable roll rate for planes of this size. I have not flown the 303 but the 1000 flies great and I hope to maiden the 505 next weekend at Soar Utah. I fully expect it to fly great too. Maybe not as "floaty" in light air but it should have a better roll rate and be a little faster since it has less area and thinner tips.
You can see the flaps in this flight shot.
TFLG
TFLG is offline Find More Posts by TFLG
Question HF models ventus 2ax 5.0m craignzcd Scale Sailplanes 4 Sep 28, 2006 01:57 AM
Discussion HF Models sailplane Quality Issue wingdragon Scale Sailplanes 9 May 14, 2006 11:14 PM
Wanted WTB HF models DG600 wingbeat Aircraft - Sailplanes (FS/W) 0 Sep 14, 2005 10:30 PM
HF Models Duo Discus - anybody have one? neonbutterfly Scale Sailplanes 1 Nov 19, 2003 04:53 PM
HF models ASW-28 3M soaringMoe Scale Sailplanes 7 Aug 21, 2003 05:49 PM
