Seagull Pilatus PC-9 Roulette RIP
Finally recieved the PC-9, bought at Sussex Model Centre. This is the first time I've bought from England. Shipping is fairly priced £18.5. It shippes with Parcel Force Euro 48, Don't ask what 48 stands for, shipping took 10 days. Nothing to gripe about as long as you know it, kinda hard to wait once you decided for something
Wasn't supposed to do anything Tuesday evening but one thing led to another and I ended up in my hobby room anyway Everything looks to be a nice fit, fitted the winghalves and let it cure for the night(1,2) Took away the covering for the wing retaining screws -they were misaligned (3), corrected the hole, filling up so the wing won't move during flight, glued on supports (4). Looks like the hole already been adjusted once, found filler in one end of the hole.I'm not going to use standard servos, trying 16g/0.56oz for ailerons (5). Been told that she's tail heavy, therefore everything aft CG is going to be kept light. Moving elevator and rudder servos forward to throttle servo bay (which is being unused going electric) Setup: Motor: Dualsky XM4250CA-6 ESC:Aero-Nuts Platinum 60A (Dualsky XC6015BA) UBEC: Dualsky VR-3 Battery: 4X VamPower VP-2S1P2250 4S 4500mAh Reciever: JETI REX 7 MPD Servo: Aileron : Global-RC 17gr Naro Max Midi, Elevator, Rudder:Jamara XT Miniblue. (All later changed to 27gr Jamara mini servos ) Will add more information as the work progresses. Cheers, Peter //Peter |
well, maybe thats why I never had a balance problem. I am not afraid of a little extra weight. This model has plenty of room for my stick battery 2x1x10 lenthwise into the belly. I believe I am still under the max weight for this model. If I am imagining your pack looking more like a brick, it should even out the reduction in noseweight from smaller motor, because more of your battery will be forward of the CG.
Actually I'm going to try smaller/lighter servos, -against better judgement
Worst case scenario is a spare parts plane and a killed hare (the deere don't come that close)Fitted the mini servo (1), fixating the horn with CA before drilling the holes (2). These are the battery packs that will go up against the firewall (3). |
I've already guessed that, don't worry. Sorry mate. ATB, Peter |
I'm using Grapner's way (or the way they always recommend) to remove the covering (1,2) -using a soldering iron, no risk cutting too deep and the edges stays sticked to the surface.
It's taking shape I always use slowsetting (24h fully cured) epoxy for high stress areas, besides it gives you a lot of time to correct and gave me time to mount both horisontal and vertical stabilizer (2) without having to wait for one to cure. I believe the strength of the whole tail section increases being glued with one solid joint. More to come ... |
I thought that the exhausts should do some good instead of just sitting there (1), may not do much good but I want as much air flow around ESC and motor as I can get.
Making battery hatch lock with neodym magnets (rare earth) (2). Airscoop/battery leads exit (3). Loaded everything in (4,5) (excluding motor mount) and got CG only 10mm/0,39" off, should be perfect with the added weight of the motor mount . Weight is so far 2322gr/81,9oz excluding the mount, I'm still waiting for it though, that's why I'm fiddeling with small timeconsuming stuff and not getting too much done
I'm going to have two servos for elevator later on, this will have to do for now (1).
Got the motor mount today, besides from being rock steady it looks good too (2,3) , blindnuts included (4).I might add that the included propadapter is very high quality, way better than my other MP JET which is considered high quality ones. Servos on their way in (5). What takes up so much time is trying to get the ESC and all the cables to fit snugly inside the cowl, at the same time is should be easy to change batteries. I'm going to use neodym magnets for the cowl, I think, maybe If I worked as much as I scratched my head I'd be flying by now
