Old Jul 21, 2006, 08:01 PM
us_matrix is offline
Find More Posts by us_matrix
Joined May 2005
Kyosho HOR Special Gear & Sprocket options..
Hi,
Which one is better and more durable? GPM make alloy gear & sprocket and Kyosho make something like derlin gear & sprocket.
Anyone try both and what would you recommand?
Thanks.
us_matrix is offline Find More Posts by us_matrix
Old Jul 21, 2006, 08:26 PM
^jynx^ is offline
Find More Posts by ^jynx^
Danbury, CT
Joined Jun 2005
kyosho steel gears will last you the longets
^jynx^ is offline Find More Posts by ^jynx^
Old Jul 21, 2006, 09:36 PM
Butters is offline
Find More Posts by Butters
Butters's Avatar
Your Mama's house!
Joined Mar 2005
Unless you plan on racing, you really can't go wrong with what ever you buy.
I have used these in my original bike for over 2 years now.
http://cgi.ebay.com/KYOSHO-GPW11-SPE...QQcmdZViewItem
And I have gone through 3 riders and 4 bodys so I am not gentle.
Alloy will work just fine but don't use a metal pinion or it will chew the alloy up. IMO I would use a plastic pinion with the alloy or a alloy pinion but with the gears above you can use anything.
James
Butters is offline Find More Posts by Butters
Old Jul 21, 2006, 09:43 PM
Akura2 is offline
Find More Posts by Akura2
PROFESSOR TRUTH JIMMY ICE
Akura2's Avatar
Joined Sep 2003
I had the GPM allow gears in my bike for a while... but I also have a Mamba 6800 as well and after about a week of running my HOR, although the pinion ans spur were ok, the alloy front sprocket looked like sharks teeth and the chain began slipping..
if you are going to go with a powerful motor... stick with the Kyosho steel gears from the above link
Akura2 is offline Find More Posts by Akura2
Old Jul 23, 2006, 03:40 AM
Joined May 2005
I will be running Speed 300 motor w/gpm alloy gear box.
I will order the Kyosho one then.
Thanks.
Discussion looking for kyosho hor aluminum main gear! TITANIUMHELI Motorcycles 11 Jun 19, 2007 05:56 PM
For Sale Kyosho HOR suzuki rgv RTR w/options NEW! or trade 4 mamba max blue4uevo8 Cars - Cars and Parts (FS/W) 2 Mar 19, 2007 08:38 PM
Idea Kyosho HOR Interals axle182 Motorcycles 12 Sep 17, 2004 10:10 AM
Hughes500 Kyosho/Concept landing gear part needed gerrycase Aircraft - Electric - Helis (FS/W) 1 Nov 05, 2003 04:08 PM
Kyosho pitts special 40 size conversion Wolfy2671 Power Systems 35 May 06, 2003 04:12 AM
