Old Jul 21, 2006, 12:03 PM
rapghsi is offline
Find More Posts by rapghsi
Great RC Pilot
Joined May 2006
What do you think about that? will work?
200gr plane, with improved lenceRC (i make it 18 turn).
28 inch wingspam and 30 inch fuslege.
i got max 675gr trust at 9 amp with the PQ 300mah 3 cell.
i use 2 cell 300mah PQ to but the power run out fast (20 gr battery ).
about 500 gr trust at normal conditions.
the plane is a profile epp with flat wing.
about 40% CG center, well i test it a few times but the loops are very big and the knife loops to.
what can cause that? here is a pic of the plane:
thanks!!
rapghsi is offline Find More Posts by rapghsi
Site Sponsor
Old Jul 23, 2006, 11:10 AM
Jerry Combs is offline
Find More Posts by Jerry Combs
is it flying time?
Jerry Combs's Avatar
Wyandotte Oklahoma
rapghsi,
I have one of those and they are a bit fast for F3P flying, however they are great trainers for flying 3D indoors since they are pretty tough little birds. I would look at getting a slightly larger battery as the PQ 300 will not deliver enough amps for your motor.
Most F3P models will weigh 5 ounces or less and will be larger, typically 31" to 35" wingspan.
Jerry
Jerry Combs is offline Find More Posts by Jerry Combs
Old Jul 24, 2006, 01:17 AM
rapghsi is offline
Great RC Pilot
Joined May 2006
i test flight it with the 2 cell PQ 300mah battery, yea i get power, bot not for long time, i will try the 3 cell PQ 300mah and tell you how it gows.
Site Sponsor
Old Jul 24, 2006, 06:06 AM
Thatovalguy is offline
Find More Posts by Thatovalguy
Foam rules
Thatovalguy's Avatar
HdG Md.
Joined Jan 2003
((got max 675gr trust at 9 amp with the PQ 300mah 3 cell))
Way to much amps for the battery guy. We've done tests and your eating it alive at that amp rate plus your loosing so much voltage. You know your only gonna see about 20 cycles at that amp rate and the battery will be toast. Any 20C battery out there really only gives you great performance all around at 12C. Any more than that and its eating itself up. Yeh it will do it but not for long.
Plus like Jerry said the plane really doesn't work for this area it belongs up in the foamie area.
Thatovalguy is offline Find More Posts by Thatovalguy
Old Jul 24, 2006, 10:24 AM
racerxky is offline
Find More Posts by racerxky
Watts is where its at!
racerxky's Avatar
United States, WA, Seattle
Now I wouldnt go writing this guy off. 200g is inthe ballpark for the larger F3P models, particularly the biplanes. For a monoplane it sounds heavy. EPP is an interesting material too.
The large loops can be caused by not enough movement (throw) on the elevator and rudder. You want at least 45 degrees of deflection. It could also be not a large enough control surface. From the pic your throws look pretty good, you might want more aileron throw/size.
It might also be the servo stalling in flight.
racerxky is offline Find More Posts by racerxky
Old Jul 24, 2006, 11:37 AM
is it flying time?
Wyandotte Oklahoma
Rapghsi,
On my model that has a similar motor I am using a 750 mAh 3s1p pack that will handle the Amp draw of the motor. The PQ 300's can handle 6 amps maximum and that only for a short time. On my motors that only draw 4.5 amps or less I use my PQ 300's but these motors are on much lighter airframes that weigh 5 ounces or less.
Only trying to help, not discourage you,
Jerry
Old Jul 24, 2006, 02:59 PM
rapghsi is offline
Great RC Pilot
Joined May 2006
oh i understand.
i build this motor by my self, i think thats why it drows so much power.
i make it 17 turn with 28 AWG wire, i think i need to try thw 26 awg wire, and make it 20 turn, hope it will not draw so much amps.
the battery get alittle hot on 3d flight i think thats why.
i am lucky i still have two bran new 300 mah PQ batterys.
you think 20 turn 26 awg wire will make it work? and not draw too much amps?
thanks!
Site Sponsor
Old Jul 24, 2006, 03:02 PM
rapghsi is offline
Great RC Pilot
Joined May 2006
and today i removet about 8 gr of my plane so now he is arund the 180 gr with battery after i wight it in a scale that works . and i add some more D/R and now its doing it very well, i will stop fliying it untill i will make a motor that draws a normal amps.
Site Sponsor
Old Jul 24, 2006, 03:21 PM
is it flying time?
Wyandotte Oklahoma
Rapghsi,
The motor that I am using is a Westport 17t 26ga, it draws about 4.5 amps on an 8*4 GWS HD prop.
Jerry
Old Jul 24, 2006, 03:34 PM
rapghsi is offline
Great RC Pilot
Joined May 2006
how much trust you get from it? and you use 3 cell or 2 cell?
Site Sponsor
Old Jul 24, 2006, 04:15 PM
is it flying time?
Wyandotte Oklahoma
Rapghsi,
According to the numbers that I have I am getting about 220 grams of thrust on 2 cells.
Jerry
Old Jul 24, 2006, 04:52 PM
rapghsi is offline
Great RC Pilot
Joined May 2006
sounds good, but i have some facts that make my plane heavier.
i use 20 amp ESC and i don't use the pull-pull system with wires, i use a metal pushrodes, do you have a suggest how to make horns from home materials?
or in a local hardware store?
i will try this pull-pull system to, should make the plane a little easier.
where can i found a manual about this pull-pull system?
i am new in this pettern subject, trying to convert my plane to pettern plane.
pettern is a 3d with precision, and much more organized am i correct?
thanks!
Site Sponsor
Old Sep 13, 2006, 12:00 PM
rapghsi is offline
Great RC Pilot
Joined May 2006
ok new weight... gess what? 5.6 OZ...
fly well!.
pull pull system on the rudder, in time all my control areas will be pull-pulled!
Site Sponsor
What do you think about my site? Laurens Electric Plane Talk 14 Sep 27, 2003 10:20 AM
What do you think about this......?? mlehman Parkflyers 6 Feb 26, 2003 03:14 PM
What do you think about this? Electric FliteStreak tlh101 Parkflyers 7 Jan 18, 2003 06:04 AM
what do you think about US Aircore floats? KMKAZE Electric Plane Talk 0 May 30, 2002 03:38 PM
What do you think about this tape for zagi's funflyer Foamies (Kits) 1 Jul 02, 2001 10:58 PM
