Old Jul 20, 2006, 03:43 PM
ryancx is offline
Find More Posts by ryancx
Joined Jul 2006
Help!
Replacing Blade CX aluminum head's inner shaft
I just had a nasty crash and need to replace the inner shaft for the aluminum head that the flybar and upper rotors attatch to. Can anyone tell me how to replace the inner shaft?
I know I sound stupid with something that is probably so obvious. Pleeeeeese help me!
ryancx is offline Find More Posts by ryancx
Old Jul 20, 2006, 04:51 PM
rocknbil is offline
Find More Posts by rocknbil
Just call me crash.
Joined Jan 2006
1. Remove canopy and rear fuselage.
2a. Optional: remove landing skids (they pull right out) and battery holder. You can do it without this but it's easier. The battery holder is held in by 4 screws.
2b. remove two screws in the aluminum collar on the bottom gear. Slide collar and gear off shaft. Note that shaft has a flat side, you MUST get one of the screws on this flat spot on reassembly.
3. Slide entire inner shaft out from the top, taking care to not lose the bearing holder at the top of the outer shaft. If it falls off, simply press it back on.
Reverse for reassembly, but on reassembly make sure of a couple things:
1. The set screw holding the aluminum head on the shaft was loose when I got it. Back it out a little, put a drop of blue loctite on it, and snug it up good.
2. When you put the flybar and pitch control link in, make triple-sure that nothing binds, the flybar should hinge freely. Loctite the tiny screws here too.
3. See above about the flat spot on the bottom of the shaft, very important.
4. Don't over-tighten the screws in the collar on the bottom, the aluminum collar will strip easily. Tight, with a little locktite.
rocknbil is offline Find More Posts by rocknbil
Old Jul 20, 2006, 05:04 PM
ryancx is offline
Joined Jul 2006
I know that much; I just can't actually remove the inner shaft from the aluminum head! I have a replacement for the aluminum head so I know its possible. Thanks anyways
Old Jul 20, 2006, 05:31 PM
cjg is offline
cjg
Find More Posts by cjg
cjg
"Pull up, pull up!"
cjg's Avatar
Vermillion, SD
Joined Jan 2006
I was unable to get the set screw out, ruined the screw even with a high quality, hardened hex driver. Essentially ruined the whole thing. I've had to revert back to my plastic head until I replace it.
Someone suggested heating the whole head before trying to break it free. Good suggestion, do this before you try to remove the set screw - it will help break the locktite they use free.
cjg is offline Find More Posts by cjg
Old Jul 20, 2006, 05:48 PM
Steve Shepard is offline
Find More Posts by Steve Shepard
Infinitisqrd
Hilo, Hawaii
Joined Dec 2004
Unless something has changed recently, the aluminum head does NOT need to be removed from the shaft. The head is cast in place on the shaft, thus making the whole thing a one-piece affair.
I may well be wrong about this, but I'm sure someone will correct me if I am. Don't want to put out incorrect information. My friend bought a replacement alloy unit that was cast in place. Are there different manufacturers for these parts ?
Aloha, Steve
Steve Shepard is offline Find More Posts by Steve Shepard
Old Jul 21, 2006, 03:53 AM
Spockie-Tech is offline
Find More Posts by Spockie-Tech
Joined Aug 2005
a good tip for undoing loctited grub screws without heating the whole head up is to stick the tip of a soldering iron (softly) into the hex socket for a second or three. Softens loctite right up without toasting the whole assembly.
Spockie-Tech is offline Find More Posts by Spockie-Tech
Old Jul 21, 2006, 07:11 AM
helmutk is offline
Find More Posts by helmutk
Pleasant Valley, NY
Joined Sep 2005
Aloha, Steve
Yes, I have found the same with the replacement inner shaft assemblies I have seen and purchased. The rotor head assembly comes molded, glued, or screwed to the inner shaft.
helmutk is offline Find More Posts by helmutk
Old Jul 21, 2006, 01:09 PM
manse is offline
Find More Posts by manse
Joined Apr 2006
Eflight has an aluminum head assembly, and spare shafts. I own this one:
Inner Shaft w/Aluminum Head/Hub: BCX $16.99 [EFLH1240]
http://www.horizonhobby.com/Products...rodID=EFLH1240
Inner Shaft for Aluminum Head/Hub: BCX $3.99 [EFLH1241]
http://www.horizonhobby.com/Products...rodID=EFLH1241
The aftermarket ones may come with the shaft cast in, but not the one's from Eflight/horizon.
manse is offline Find More Posts by manse
Old Jul 21, 2006, 02:35 PM
helmutk is offline
Pleasant Valley, NY
Joined Sep 2005
Yes the inner shaft is secured with a screw for both of the Aluminum head replacement parts but you can not order them separately.
The orginal equipment inner shaft with plastic head is molded in.
Old Jul 21, 2006, 06:53 PM
manse is offline
Joined Apr 2006
Well, you can order the set, [EFLH1240], then order just the shafts if you want [EFLH1241], which I have done.
Old Jul 22, 2006, 10:10 AM
helmutk is offline
Pleasant Valley, NY
Joined Sep 2005
Ahhh...OK manse, I see that Horizon Hobby is now offering just the inner shaft for their aluminum inner shaft/head upgrade. Sorry I miised that in your first post. Nice to know. The aluminum head upgrade is definitely worth it over the stock inner shaft/head assembly.
Help! TBE now that I installed Aluminum Center Hub / Inner Shaft For Lama / Paul6ppca Coaxial Helicopters 25 Aug 09, 2007 06:16 PM
Discussion allen screw size on cx aluminum head cjg Coaxial Helicopters 6 Jul 18, 2006 03:04 PM
Discussion Blade CX aluminum lower head! gassper Coaxial Helicopters 15 May 25, 2006 09:27 PM
Question MicroHeli's Inner Shaft for the Lama ? Lou Coaxial Helicopters 0 Apr 03, 2006 01:55 PM
Discussion Blade CX Aluminum Parts Shandolyn Coaxial Helicopters 17 Mar 09, 2006 04:09 PM
