Old Jul 20, 2006, 06:46 AM
RC Man is online now
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
Align Trex 600 power options
What are some proven power systems for this helicopter?
Motor
Pinion
Battery
RC Man is online now Find More Posts by RC Man
Old Jul 20, 2006, 08:13 AM
Aobid is offline
Find More Posts by Aobid
Enjoying the good life!
Aobid's Avatar
Ashburn, Virginia
Joined Feb 2002
I thought these only came with the motor and ESC in the package? And they recommended using a 6S pack, I think their 6S2P 4200 or 4400 is a great pack, good price too.
Aobid is offline Find More Posts by Aobid
Old Jul 20, 2006, 12:36 PM
GGoodrum is offline
Find More Posts by GGoodrum
GGoodrum's Avatar
South Orange County, CA
Joined Mar 2003
I think with a little trimming, you can make quite a few more motors fit, as our friends "down under" have been doing. The "standard" Z50-600 would be be a good choice, as would an Orbit 30-12, both on a 10s setup in the 3300-3800 range, using two side-mounted 5s packs. I'd think also a Hacker A50-10S, and an Actro 24-4 Heli, would also work quite well. I had two massive 5s-4700 special packs that Charlie did, at the MWE in early May. While these were way too big and heavy, we strapped them to Danny Szabo's TRex 600 anyway, and put in an A50-10S. There is a video of Danny flying the bejesus out of this setup here. Now, imagine what he could've done if it was a pound lighter, with a 10s-3300 Evo setup...
-- Gary
GGoodrum is offline Find More Posts by GGoodrum
Old Jul 20, 2006, 12:58 PM
Steph280 is offline
Find More Posts by Steph280
1.21 Gigawatts!
Steph280's Avatar
Irvine, CA, USA
Joined Oct 2000
I'd love to try the Z50-600 on this heli. Just have to wait for Gary to get some more in stock.
Gary does A50 really have problems with max RPM when ran with a Kontronik ESC?
Steph280 is offline Find More Posts by Steph280
Old Jul 20, 2006, 02:35 PM
United States
Joined Feb 2001
Has anyone tried an eMoli battery setup?
Old Jul 20, 2006, 04:42 PM
Bjorn Tore is offline
Find More Posts by Bjorn Tore
Team Visa
Bjorn Tore's Avatar
Norway
-- Gary
Well I tried two 6 cell 3300mah fp evo packs up front, and it came out just a tad nose heavy, so I think two 5 cell 3700mah packs might be just fine up front since they weight 60-70 grams less... I use a 2100 mah receiver battery mounted under the "shelf" as far behind as I can get it...
Bjorn Tore is offline Find More Posts by Bjorn Tore
Old Jul 20, 2006, 06:01 PM
aaronredbaron is offline
Find More Posts by aaronredbaron
Spektrum Dev Team
aaronredbaron's Avatar
United States, IL, Champaign
Joined Apr 2002
I think another potential setup would use about a 1200kv motor, and 8s. I found these cells http://www.maxamps.com/index.html?lmd=38908.605289, their link for that page doesn't take you straight to the cells, I am talking about their 4 series pack of 16c 4000 mah cells. at 8s made up of two 4s 4000 mah packs the pack would weigh in at 730 grams compared to the stock 4400 which weighs 700 grams. I think these may prove to be a good choice with the right motor, the max watt output for the stock 4400 pack is about 1760, the max watts for 8s of those 4000 cells is about 1895
aaronredbaron is offline Find More Posts by aaronredbaron
Last edited by aaronredbaron; Jul 20, 2006 at 06:05 PM. Reason: link goes to wrong place
Old Jul 20, 2006, 07:07 PM
d-bledsoe is offline
Find More Posts by d-bledsoe
Dumb Thumbs
Kirkland WA
Joined Jul 2005
Thats a interesting idea.... Although i think the packs your suggesting are actually 12c packs, not 16c capible of about 50 amps continous. Unless im seeing the wrong packs.
I wonder how many amps less it would pull in compairison to the align 6s packs. I would assume in a 8s config the amp draw would be low enough not to damage the packs.
Any thoughts
-Derek
d-bledsoe is offline Find More Posts by d-bledsoe
Old Jul 21, 2006, 03:57 AM
Flint is offline
Find More Posts by Flint
Flint's Avatar
Australia, ACT, Canberra
Joined May 2001
Sounds great but I have not found a 1200kv motor in that size yet. Anyone know of such a motor? 45mm outside diamater is the biggest you want to go before removing material from the inside of the frame.
Cheers
Flint is offline Find More Posts by Flint
Old Jul 21, 2006, 04:53 AM
ozace is offline
Find More Posts by ozace
Renewed interest
ozace's Avatar
Melbourne , Australia
Joined Jun 2002
There is a Z-30 motor that has a KV of 1100, said to be good for 2000watts. I have a couple, one is in the swift and the other in its box. I will have to go and measure it up.
http://www.wattsuprc.com.au/product_detail.asp?pid=ZP07
43mm wide
ozace is offline Find More Posts by ozace
Old Jul 21, 2006, 09:07 AM
Philpops is offline
Find More Posts by Philpops
Australia
Joined Mar 2004
Ive seen the Z30 go very well in a Logo 14 on 600mm blades. Not as well as the Z50 though.
Philpops is offline Find More Posts by Philpops
Old Jul 21, 2006, 01:53 PM
Spektrum Dev Team
Joined Apr 2002
you guys are right about the C rating, sorry, it does look like its rated at 12c continous. but I still say that an 8-10 series setup made up of 3300-4000 mah cells may be able to provide more consistant power and longer flight times
Old Jul 21, 2006, 03:18 PM
geneween is offline
Find More Posts by geneween
Conformity Kill's
Mission Viejo, CA
Joined Nov 2005
RC Man,
I have used the Emolis with the stock stuff. you can find info in this thread.
http://www.rcgroups.com/forums/showt...page=122&pp=15
Starting at post #1821
GW
geneween is offline Find More Posts by geneween
Old Jul 21, 2006, 10:27 PM
ozace is offline
Renewed interest
ozace's Avatar
Joined Jun 2002
I just had the thought that the z-30 may fit straight in without frame mods.
Old Jul 21, 2006, 10:54 PM
Flint is offline
Flint's Avatar
Joined May 2001
It should, anything up to 45mm will fit with no mods. I am tempted to get one
Sold Almost New Align Trex 600 XL motor--65$ shipped Jag72 Aircraft - Electric - Power Systems (FS/W) 0 Jun 15, 2007 10:10 AM
Discussion Align Trex 600 metal head parts driving me crazy! kenmalecki Electric Heli Talk 12 Jun 05, 2007 01:09 AM
Careful! Align Trex 600 - the Issue files ozace Electric Heli Talk 95 Oct 20, 2006 05:51 AM
Yippee! Align Trex 600 at modefo's heli!!!!!! prodigy Mini Helis 19 Jul 13, 2006 01:55 AM
Discussion Align TREX 600 mysn95 Electric Heli Talk 7 Mar 10, 2006 01:29 PM
