Old Apr 06, 2009, 08:50 AM
kdahlhaus is offline
Find More Posts by kdahlhaus
kdahlhaus's Avatar
United States, OH, Westlake
Joined Mar 2002
Bass, great to hear that. Thanks for posting the results. Dick's KF wing just works wonders on these planes.
kdahlhaus is offline Find More Posts by kdahlhaus
Old Apr 06, 2009, 03:51 PM
bass4220002000 is offline
Find More Posts by bass4220002000
Crash and Burn
Butler, Indiana
Joined Nov 2008
Kdahlhaus,The kmf4 is something that is left to experianced pilots.Definitly not for training also I felt the vortex trap would work better on a larger model.The me-109 is fast the way it is and has excellent control.On the me-109 it was better without the vortex trap being small it is a darty little plane it seemed to make the alieron controls jerky and faster that make it hard to keep up with. Also need power to land would stall out without power.
bass4220002000 is offline Find More Posts by bass4220002000
Old Apr 07, 2009, 04:36 AM
Crash and Burn
Butler, Indiana
Joined Nov 2008
On a kf wing it calls (example) out for 50%of chord at 9% what happens if the fold is less than 50% of chord. What effect will it have on a model if any? Will it change the center of gravity? Or will it not create the proper lift that it is required? Anyone explain this to me. Trying to understand th kf wing better and the best place to use it.
Old Apr 09, 2009, 07:01 PM
Gerry E is offline
Find More Posts by Gerry E
Australia, QLD, Buderim
Joined Dec 2008
Originally Posted by kdahlhaus
With some help from Gene, I modified his Blu-51cd P-51 to create a ME-109. It flies great, which is no surprise as the control surface size and location is pretty much identical to that of the Blu-51.
It's an easy build - I left the skin on, rounded the leading edges and tempered the wings with a heat gun. There's a single skewer bracing the wing. Ailerons and elevator are taped on with a single layer of packing tape. Hot glue for everything except the control horns. The horizontal stabilizer is one piece. I attached one of the elevators, glued the stabilizer in place, then attached the other elevator and glued a *bucks coffee stirrer across the elevators ( you want to remove the blue-skin where the stirrer contacts the foam ).
All build information on the Blu-51 ( http://www.rcgroups.com/forums/showt...ghlight=blu+51 ) applies to this plane as well.
Edit:
newbie125 posted a great video of his blu-109. His 109 starts 1:16 into the video.
jonesymj posted some video in post #61 of this thread.
there's also a short video in the Airplanes - electric videos forum.
Awsome plane I Had to build one Just gotta add servos and give it a test
Gerry E is offline Find More Posts by Gerry E
Old Apr 10, 2009, 06:17 AM
Crash and Burn
Butler, Indiana
Joined Nov 2008
Gerry E, Kdahlhaus has a very good plane that flys well above the expectations of most.It is rather fast and responsive.After you maiden you may want to have the alierons alittle above flush to help keep nose up and trim the elevator down to help with glide these are the adjusments I made but these are my preferences.Besure to post pics good luck on your maiden, may your flights be as sucessful as mine.
Old Apr 10, 2009, 10:03 AM
chewytm is offline
Find More Posts by chewytm
Ipoh, Perak Malaysia
Joined Jul 2006
Bass, if you have both ailerons up, then they are essentially air-brakes/spoilers. This will slow the plane down and make it drop faster also. If you add in down elevator, it will on make the situation worse. Why would you think such a condition would help you with the glide, unless you want the plane to nose down faster?
chewy
chewytm is offline Find More Posts by chewytm
Old Apr 10, 2009, 09:02 PM
Crash and Burn
Butler, Indiana
Joined Nov 2008
chewytm, It did help the plane it was less than 1/8" had a nose down condition two out of three I build did this didn't slow it down use alieron up alittle to keep nose up used elevator to fine tune.When raising aileron,is like flaps helped keep nose up no room to move battery back.
Old Apr 11, 2009, 02:22 AM
chewytm is offline
Joined Jul 2006
bass, raising the ailerons would press the nose down, not raise it up. You should tray that instead, but not too much all you may find that the plane will tip-stall easily.
chewy
Old Apr 11, 2009, 04:32 AM
Crash and Burn
Butler, Indiana
Joined Nov 2008
Chewy, Was having nose up problem battery all the way forward it helped my situation.Without any major sacrifice.This is what Gene Bond had to do with the blue P51,With cg in front of the alierons air on the back of wing will force nose up,only a little above 4\40 wing trailing edge,disadvantage if you go too far it can cause instability and force the plane down.I use the elevator to trim in level flight.
Old Apr 11, 2009, 05:32 AM
Crash and Burn
Butler, Indiana
Joined Nov 2008
Chewy, Here on this thread is an explanation http://www.rcgroups.com/forums/showt...=389720&page=2
Post 23 and 24 are the explanation of design.Nobody explains it better than Gene can.
Old Jun 14, 2009, 08:04 PM
evan.flatt is offline
Find More Posts by evan.flatt
evan.flatt
evan.flatt's Avatar
United States, IN, West Lafayette
Joined Apr 2008
Where is the CG on this plane? I just built one and it seems tail heavy, also what size battery did you use and what is the RTF weight?
evan.flatt is offline Find More Posts by evan.flatt
Old Jun 15, 2009, 09:28 AM
kdahlhaus's Avatar
Joined Mar 2002
I'd start w/the CG at the spar. Never weighed mine, but I'd guess around 7 3/4-8oz or so AUW. I ran mine with a 900 mAh 3-cell lipo, blue-wonder (both from lazertoyz), and a 8060 gws hd prop.
Hope that helps. Post a pic if you have one, would love to see your build.
Old Jun 15, 2009, 11:15 AM
evan.flatt
evan.flatt's Avatar
Joined Apr 2008
I am going to use a rimfire 300 brushless with a 8x3.8 apc prop, e-flite 10 amp pro brushless esc, e-flite 6.5g aileron servo and I will have a 5g elevator servo. Without motor the weight is 7.5 oz, I don't know if the 2 cell willhave the umph to fly the plane when the motor is on it, it should weigh about 9 oz with motor, prop, prop saver etc. The plane has foam board with paper left on. Will it fly?
Old Jun 15, 2009, 01:29 PM
kdahlhaus's Avatar
Joined Mar 2002
Looks good! I'm not an expert on these calculations, but I'm pretty sure she'll fly just fine at 9 oz.
Old Jun 15, 2009, 01:58 PM
evan.flatt
evan.flatt's Avatar
Joined Apr 2008
Great, it feels good to have an outside opinion. Thanks
Modeltech 25 size ME 109 Conversion Joe Elston Electric Plane Talk 10 Oct 24, 2007 07:20 PM
Video Blu-109 FFF kdahlhaus Electric Plane Talk 0 Jul 02, 2007 08:12 PM
Modeltech ME 109 Electric Conversion Which Prop? Joe Elston Electric Plane Talk 6 Jul 09, 2002 08:34 PM
ME 109 Joe Elston Electric Plane Talk 0 Jul 10, 2001 01:41 AM
Any sites with photos of the ME 109? slowflyer Scale Kit/Scratch Built 6 May 24, 2001 08:17 PM
