Old Jul 19, 2006, 01:23 PM
spiffy_spaceguy is offline
Find More Posts by spiffy_spaceguy
Hydrofoil Semi-Pilot
spiffy_spaceguy's Avatar
Ottawa, Ontario, Canada
Joined Jul 2005
Cool
World's First Dry-Cell Battery Plane Flies
A Japanese team from the Tokyo Institute of Technology has flown a glider-like airplane on 160 AA alkaline batteries. It flew to 16 feet in altitude and covered 391 metres in 59 seconds.
It has a wingspan of 102 feet.
http://evworld.com/view.cfm?section=...31016print.asp
http://www.todayonline.com/articles/131016print.asp
spiffy_spaceguy is offline Find More Posts by spiffy_spaceguy
Old Jul 19, 2006, 01:29 PM
sarge is offline
Find More Posts by sarge
sarge's Avatar
Fayetteville, NC
Joined Dec 2002
Except for the wingspan part, I've done much better on fewer batteries! Wait, they landed thiers intact, didn't they.
sarge is offline Find More Posts by sarge
Old Jul 20, 2006, 02:14 AM
Mister UHU is offline
Find More Posts by Mister UHU
Mister UHU's Avatar
London UK
Joined Dec 2005
Yes, very good, but WHY ?
The more I think about this, the less I understand !
Am I missing something ?
What are the power specs for this setup ?
If each cell 1000 mAh, @ 1.5 Volts,
1A X 1.5V = 1.5 Watts
160 cells X 1.5W = 240 Watts
Weight of aircraft + weight of pilot = guess 50Kg + 50Kg = 100Kg ??
16 feet is about 5 metres
Therefore 100Kg lifted 5 metres vertically
Hey Spiffy, can you help me with the theoretical equations, I'm feeling too lazy.
Mister UHU is offline Find More Posts by Mister UHU
Old Jul 20, 2006, 02:57 AM
JMP_blackfoot is online now
Find More Posts by JMP_blackfoot
JMP_blackfoot's Avatar
United States, OH, Galena
Joined Jul 2003
Not Watts, but Watt x hours
They flew for 59 seconds.
Say the total run time was 3 minutes before batteries are exhausted, that would mean a power of 240 x 60/3 = 4800 Watt.
Of course, the battery voltage under high load must be less than 1.5 V, so maybe a peak power of 3 kW ?
It all depends how much peak current the batteries can supply.
JMP_blackfoot is online now Find More Posts by JMP_blackfoot
Old Jul 20, 2006, 03:21 AM
Muxje is offline
Find More Posts by Muxje
You win again, gravity!
Muxje's Avatar
Rotterdam, NL
Joined Jun 2004
Not a lot since their internal resistance is rather high. I wonder if they can manage even 1A
Muxje is offline Find More Posts by Muxje
Old Jul 20, 2006, 08:06 AM
Scott Clarke is offline
Find More Posts by Scott Clarke
AP pro;)
Northants, UK
Joined Jul 2003
Hey that's not fair!
Seriously, I have been testing a range of AA cells from different manufacturers for a non modelling purpose.
I've not found an AA cell that will deliver an 80% return on a 1C draw BUT...... A few 2500mah cells I have can push 1500mah out at a rate of 2C so 60% return. In fact it's fair to say none of the AA cells I've tested deliver their stated capacity at any current I've tested at and I have gone down to .2C..............
I run 160 cells in one vehicle application (40S4P) - I have 4 packs like this - maybe I should build an airplane!
Scott Clarke is offline Find More Posts by Scott Clarke
Old Jul 20, 2006, 09:22 AM
Mark Gund is offline
Find More Posts by Mark Gund
Parrothead Extraordinaire
Mark Gund's Avatar
Island of Margaritaville.No parallels of latitude or longitude mark the spot exactly. Passports are not required
Joined Sep 2002
Whaaaat? The Japanese haven't heard of lipos?
Mark Gund is offline Find More Posts by Mark Gund
Old Jul 20, 2006, 03:20 PM
Joined Jul 2005
Not really. I don't really understand the equations. From where I'm sitting, it looks like these guys had 131 amps to play with and I'm pretty sure that isn't right.
Old Jul 20, 2006, 04:14 PM
markdrela is offline
Find More Posts by markdrela
Cambridge, MA USA
Joined May 2001
It's clearly a publicity stunt for advertising purposes.
To sustain level flight, an airplane of that span and weight will require roughly 260W of shaft power. So figure maybe 320W of electrical power with the losses of the motor and the very substantial gear-down. So that's 2W = 1.4Amps x 1.4Volts for each or the 160 cells. The 1.4 Amps is pretty good for an Alkaline AA cell, but kinda lame for a NiMH or NiCd.
PS.
Clearly the takeoff and climb would have required more power, so figure maybe 2.0-2.5 Amps per cell for the initial burst. Still kinda lame.
markdrela is offline Find More Posts by markdrela
Old Jul 21, 2006, 04:07 AM
shaneyee is offline
Find More Posts by shaneyee
shaneyee's Avatar
Singapore
Joined Aug 2002
Yes, It did look like a publicity stunt for the battery maker. I also hear that the battery maker sponsored a battery powered car using the same cells.
BTW the design of the plane looks remarkably like your Bubble Dancer... albeit enlarged a bit...
Shane
shaneyee is offline Find More Posts by shaneyee
Old Jul 21, 2006, 10:02 AM
Cambridge, MA USA
Joined May 2001
There's actually a good reason. I did the aero design for the Daedalus HPA, which flew in 1988.
http://en.wikipedia.org/wiki/MIT_Daedalus
http://www.dfrc.nasa.gov/Gallery/Photo/Daedalus/HTML/
On this airplane we developed the V-mount system for the tail surfaces, and used semi-centered vertical tail planform to minimize torsional loads on the booms.
The numerous Japanese HPA builders copied this tail system since then, and the electric airplane is just an adapted HPA.
http://www.nasg.com/birdman/birdman03/tc_3.html
I also used a minature version of this tail system in 1999 when I started doing RC gliders. See tail photo halfway down:
http://www.charlesriverrc.org/articl...edancer-3m.htm
So the Japanese airplane and my gliders have a common origin in the Daedalus.
Old Jul 21, 2006, 03:40 PM
Troy is offline
Find More Posts by Troy
Caution:Makes sharp left turns
Troy's Avatar
United States, CA, Lake Forest
Joined Feb 1999
Why? When a corporation is that big and wealthy, why not show off your product and get a nice right-off at the same time. Besides, that plane is beautiful and a work of art.
http://www.rcgroups.com/forums/showt...ight=panasonic
Troy is offline Find More Posts by Troy
Old Jul 21, 2006, 04:01 PM
Cambridge, MA USA
Joined May 2001
I didn't mean to imply that it wasn't worthwhile from an advertising viewpoint. If it gets lots of people's attention, then it's worthwhile for them. But it's not a particularly notable engineering feat.
I've myself flown in a 60 ft span airplane powered by 16 NiCd C-cells, augmented by pedal power. That was the MIT Monarch B, way back in 1983.
Old Jul 23, 2006, 05:11 AM
Mister UHU's Avatar
London UK
Joined Dec 2005
PS.
WOW, Mark Drela responding to something I posted, I feel humbled.
So my guesses weren't so far out ?
According to the RCGroups link, the data logger recorded about 500 W on take off,
which is about 3 Amps per cell !
But as the entire flight lasted only one minute, I don't think AAs are the power source of the future.
If my guesses about the Panasonic website are correct it looks like they have also sponsored
an electric car "mileage marathon", which also makes some sense.
Any electric planes powered by fuel cells ?
Apparently MIT does some fuel cell work, so this might be interesting ??
As the Daedalus was covered in DuPont stickers, did they provide sponsorship,
or just materials ??
Old Jul 23, 2006, 10:53 AM
orenda635 is offline
Find More Posts by orenda635
Canucklehead
orenda635's Avatar
GTA, Ontario, Canada
Joined Apr 2004
It probably is a publicity stunt but it does prove something. A manned aircraft can run entirely on electricity. As Mister UHU mentioned, this type of aircraft could have a future with fuel cell technology.
orenda635 is offline Find More Posts by orenda635
MIA's RC TRIKE (world's first?) Mario Parkflyers 80 Jan 31, 2010 10:02 AM
World’s First 16:9 CCD*8.4-Megapixel BAR-STOOL Aerial Photography 7 Jul 28, 2005 07:24 AM
Dry cell battery holders east6008 1/2A Planes 5 Jul 20, 2005 06:50 PM
World's First-----CP Symetrical Micro Heli Blades Mario Micro Helis 26 May 15, 2004 02:31 AM
FS:Brushless ESC's and 7-8 cell battery packs. Art Horne Aircraft - Electric - Airplanes (FS/W) 2 Nov 23, 2003 09:49 AM
