Old Aug 01, 2002, 01:50 PM
SKINNI MINI flyer
Barrett's Avatar
Pearl River, LA, USA
Joined Sep 2001
How does a CNC foam cutter do tapered wings?
I ve been looking at CNC foam cutters for a while now (just curious because foamies are cool ) But now im might be able to purchase one for work. We will be using it to do some shapes and letters for halloween. I work in the entertainment department for a theme park BTW.
But since i also fly foamies and have recently started to cut my own cores, This is great! So back to my main question.....
How do they cut tapered wings. I think i understand how constant chord wings are cut. It seems that they only require a 2
axis machines. But for tapered wings do i need a 3 axis cutter or even a 4 axis cutter?
Thanks guys!
Barrett is offline Find More Posts by Barrett
Old Aug 01, 2002, 05:13 PM
melw's Avatar
Sunnyvale Ca.
Joined Jul 2002
I helped a friend with his CNC foam cutter. I built a four-axis controller and made all of his cables. The four-axis setup works very well. In fact he has just cut me some wing cores that I am turning in to a flying wing like the wing nutz. The four-axis are arranged in a L shape on each end of the bow. The software that he is using is found on this site,
http://gm.cnc.free.fr/index_en.html . And the controller board kit is found here,
http://www.hobbycnc.com/ . If you have any questions about the kit I would be happy to help.
Mel
melw is offline Find More Posts by melw
Old Aug 01, 2002, 06:34 PM
SKINNI MINI flyer
Barrett's Avatar
Joined Sep 2001
Well ive got lots of questions
First do you have any pics of your setup? Im not really sure i understand the L shaped part. If your friends setup looks similar to most of the other pics that ive found then i understand, I think.
Let me see..... So you build one side with a up and down and back and forth motion (and thats 2 axis) ......
Then you build a second side that is just a mirror image of the first side and it has up and down and back and forth motion (and thats the other 2 axis?) Then attach a hot wire with some sort of temp control between the two sides...... Its starting to come together.
Then to cut a tapered wing you put in a root airfoil and a tip airfoil into the control software. The computer outputs to the stepper motor control board and the 4 stepper motors move independently of each other to cut the wing.
Is this about right? Does the software accept DXF files from autocad? Is it easy to get the software to do anything else besides wings? Like letters and numbers?
Old Aug 01, 2002, 07:11 PM
melw's Avatar
Sunnyvale Ca.
Joined Jul 2002
You have grasped it. As for photos of my setup I don’t have a CNC foam cutter. I am building a CNC desktop mill and a photo is on this site, http://www.crankorgan.com/index.html just click on the pics link and look for my name. (Mel Williams)
If you explore the link for the software you will find lots of photos of CNC foam cutters. To make it do letters and numbers might be somewhat difficult my friend seemed to be having a bit of trouble. He was trying to make ovals and squares for making aircraft bodies. But the web page for the software shows some nice shapes and maybe some signs. It has been a while since I looked at it and I seem to recall seeing some. Some of the cutters I have seen on line have been quite crude. Made out of wood and drawer slides. and old stepper motors from printers. Most will work although somewhat slowly.
Mel
P.S. I forgot about your DFX question. I dont know if it will. I do know that you can put in airfoil coordinates.
Mel
Old Aug 01, 2002, 07:49 PM
SKINNI MINI flyer
Barrett's Avatar
Joined Sep 2001
Thanks Mel!
Old Aug 02, 2002, 11:28 AM
melw's Avatar
Sunnyvale Ca.
Joined Jul 2002
Barrett
My friends foam cutter in shone in this thread.
http://www.rcgroups.com/forums/showt...NC+foam+cutter
Mel
CNC foam cutter electronics kit--anyone interested? fregon45 Foamies (Kits) 14 Jun 11, 2008 12:02 PM
Curious how many of you have a home brew CNC foam cutter? Summer Foamies (Kits) 2 Aug 12, 2003 08:55 PM
CNC Foam Cutter Update. Photos posted fregon45 Foamies (Kits) 4 Jun 18, 2003 05:48 AM
CNC foam cutter...I need some help. JayParke Power Systems 16 Apr 22, 2002 08:36 AM
Electronics kit for CNC Foam cutter--Anyone interested? fregon45 Power Systems 1 Mar 07, 2002 10:14 AM
