Old Mar 04, 2012, 02:35 PM
ChilledGrave is offline
Find More Posts by ChilledGrave
Joined Dec 2011
I made this plane with 8mm depron and I am using a 1100kv motor along with 3s 2200mah battery. The prop I am using is an 8x4 ,but the plane is not able to fly and I am not able to figure out why. I want to maiden with this plane ,can anyone help?
ChilledGrave is offline Find More Posts by ChilledGrave
Old Apr 19, 2012, 07:34 AM
chambo88 is offline
Find More Posts by chambo88
1 can never have 2 many planes
chambo88's Avatar
Australia, QLD, Surfers Paradise
Joined Sep 2011
a few questions to better answer your question.
-how big is the model?
-how heavy is the model?
mine comes in at 250grams RTF. and runs a 1500kv 26g motor and using a 800mah 2s.
has 1:1 power to weight with an 8x4 prop. and i would get about 9-11mins on a battery.
mine is 800mm long x 600mm wingspan.
also check your cg.. needs to be right for these types of planes.
chambo88 is offline Find More Posts by chambo88
Old Apr 26, 2012, 03:40 PM
chambo88 is offline
chambo88's Avatar
Joined Sep 2011
here are some pics and specs that i have now the maiden is out of the way...
using the design listed on this thread, the CG is 90mm aft of the leading edge of the wing where the wing joins the fuse. note this plane has a wingspan of 600mm.
flying weight is now 289g..
power to weight is pretty much right on 1:1 with a 26g 1500kv motor from hobbyking.
Old May 21, 2012, 08:39 AM
chambo88 is offline
chambo88's Avatar
Joined Sep 2011
have now rewound the 1500kv motor with 20awg wire. managed fill up the stators with just 4 turns! i guesstimated the kv at around 4100kv now. was spinning a 8x4 prop on the 1500kv version, now running a 4x2.5 on the newly wond motor on 2s 800mah, sounds like a formula 1 car during a fly-by and i get about 10mins flight time. loving it!
Old Mar 25, 2013, 01:21 AM
monishdv is offline
Find More Posts by monishdv
United States, NY, Rochester
Joined Mar 2013
Eurofighter (2 min 15 sec)
monishdv is offline Find More Posts by monishdv
Old Jul 14, 2013, 04:50 PM
SCantu is offline
Find More Posts by SCantu
SCantu's Avatar
Mexico, NL, Monterrey
Joined Jul 2013
I have one question, the ailerons are working in this particular case to control the roll and pitch?
Can you post the specs of the servos, motor, prop, esc, and batter?
please please, I'm a newbie
SCantu is offline Find More Posts by SCantu
Old Nov 19, 2013, 04:31 PM
Blackrat is offline
Find More Posts by Blackrat
Registered Loon
Blackrat's Avatar
South Africa, WC, Knysna
Joined May 2006
damn thats fast for a foamy
Blackrat is offline Find More Posts by Blackrat
