Old Jul 25, 2007, 01:04 AM
Ramen is offline
Find More Posts by Ramen
Ramen's Avatar
Joined Mar 2007
Thanks for the plans Black rat, it's a very cool looking plane!
I've built one today at 80% the size of the plans. It just needs a little more work, so i might be able to fly it tomorrow. I'll try to post some pics with descriptions tomorrow. As for the center of gravity, the plans have a line that says where the CG should be, is that what i should be following?
ghiapilot, nice build as well although i was just wondering what type of foam you used and where a good place would be to buy some?
Ramen is offline Find More Posts by Ramen
Old Jul 25, 2007, 03:19 PM
lrplin is offline
Find More Posts by lrplin
lrplin's Avatar
Stockton CA.
Joined May 2007
I use Elmer's Foam Board, they are 20"x30"x3/16" and cost $2.95 each sheet on Target, Walmart and maybe some other stores. They have many colors, and I think Black is the best.
lrplin is offline Find More Posts by lrplin
Old Jul 25, 2007, 03:28 PM
lrplin is offline
lrplin's Avatar
Stockton CA.
Joined May 2007
durable foam board, cheap and can buy it anywhere.
Old Jul 25, 2007, 09:32 PM
Ramen is offline
Ramen's Avatar
Joined Mar 2007
Funny that you mentioned foam board, its what i used to build the eurofighter. it sounded like a great idea to me too. This is my first time using it and i haven't flown the plane yet. How well does the foam board handle crashes?
Old Jul 26, 2007, 12:59 AM
lrplin is offline
lrplin's Avatar
Stockton CA.
Joined May 2007
i haven't use it on a jet yet, but i used it on a Hydro-flying boat, slow stick, and one of my self design airplane, it works fine so far to handle crashes. It is strong but heavy.
Old Jul 26, 2007, 01:43 AM
Ramen is offline
Ramen's Avatar
Joined Mar 2007
Hmm.. The battery has to be far away from the Esc connection. How did you guys connect them? I keep reading that using an extension from the ESC to the batt may result in killing your ESC. So what do i do? Should i extend the wires from my Motor to the ESC?
Edit: My question was answered... I think, Heres the link if anyones interested.
http://www.rcgroups.com/forums/showt...74#post7873413
Old Jul 28, 2007, 04:28 PM
Ramen is offline
Ramen's Avatar
Joined Mar 2007
I took my Eurofighter out for its first flight today, and it was awesome! I took some pics before the flight since i knew i was gonna crash (I need lots more practice) I did a hard nose dive right into the ground since I couldn't recover fast enough, the motor and electronics came off but to my surprise it handled the crash better then i thought it would, just gotta add some hot glue and its good to go again.
As you can see in the pics i did a few minor mods, and i had to make a lipo box since it didnt fit in the nose. I built this one 20% smaller, but i will build another at it's full scale sometime soon I Used foam board (the kind sold in the school/office sections at most department stores) my motor is a BP 21 Brushless outrunner, I had to extend the motor wires. Prop is a GWS HD8060 attached to a prop saver (the extra motor shaft was cut off with a dremel.) Berg micro receiver, thunderbird 18 Esc, and towerpro 5 gram servos. Lipo is an Etec 7.4v 1250mah. Thats about all the info i can think of at the moment... well I'm off to fix it then heading out to the field again, cya!
Old Mar 28, 2008, 09:10 PM
thewz is offline
Find More Posts by thewz
"It's a Quad" :O
thewz's Avatar
Temecula
Joined Jul 2004
Anyone have a 1 page full size version of the PDF plan?
thewz is offline Find More Posts by thewz
Old Mar 29, 2008, 05:47 AM
Bolleke is offline
Find More Posts by Bolleke
Joined May 2004
Can somebody tell me where the cg of this plane and how much the aileron and elevator distance while bee.
We are gone build this plane on a workshop day in are club.
Greetings Bolleke
Bolleke is offline Find More Posts by Bolleke
Old Mar 31, 2008, 09:59 AM
Dick Rankin is offline
Find More Posts by Dick Rankin
It Is All Fun
Dick Rankin's Avatar
Arlington, Texas
Joined Mar 2003
See if this will help you.
I have also included a tiled file for letter size printing.
Have a great day all!
Dick
Dick Rankin is offline Find More Posts by Dick Rankin
Old Jun 16, 2008, 03:19 AM
Resurectorx is offline
Find More Posts by Resurectorx
Joined Jun 2008
Isn't that a ehh..Euro Fighter..type Rafael..or the swedish JAS 39 Gripen?
Resurectorx is offline Find More Posts by Resurectorx
Old Jun 16, 2008, 03:20 AM
Joined Jun 2008
Ooops..someone beat me to it..sorry
Old Jun 20, 2008, 01:49 PM
dsmithuk is offline
Find More Posts by dsmithuk
Joined Apr 2007
what is the best way to make a motor mount? anyone got some advice? thanks!
dsmithuk is offline Find More Posts by dsmithuk
Old Jun 29, 2008, 09:59 AM
Blackrat is offline
Find More Posts by Blackrat
Registered Loon
Blackrat's Avatar
South Africa, WC, Knysna
Joined May 2006
its all dependant on your motor .. so many different motor and so many ways to mount them.
on motors with the four screw holes, ive been using a piece of a credit card to keep weight down, it looks flimsy but it works very well
Blackrat is offline Find More Posts by Blackrat
Old Aug 03, 2008, 03:31 AM
sbrv24 is offline
Find More Posts by sbrv24
Madras India
Joined Aug 2006
Eurofighter lightning
Hi ,
Got the fuse ready for the Euro fighter . I am planning to use a motor Eq. to AXI 2212/06 with a 30 amp Esc and turning an APCE 6x4 pusher prop with a 11.1v 3 S 1800 mah LIPO.
The dimensions did not turn out as per the original eventhough I used the tile plan but I dont think that is an issue because they seem to be propotinally reduced :
Fuse length : 760 mm
Wing Span : 570 mm
Depron Weight air Frame weight : 100 gms.
Used 8 mm Depron for the Wing and 4 mm depron for the fuse .
Looking for some advice on my set up of the Motor Prop and ESC .
Rgds
Sai
sbrv24 is offline Find More Posts by sbrv24
