Old Jul 15, 2006, 10:38 PM
nuv22 is offline
Find More Posts by nuv22
Joined Jul 2006
Help!
Lama 4 in 1 chip falls off after hard landing!--with pictures
so i had my first hard landing... not a crash because it landed on the skids and i did not brake anything on my lama. and all of the sudden everything was dead no lights no nothing! i inspected the battery and put it on the concrete outslide but while i was taking off the battery i heard something loose in the cockpit when i look it was the power chip that ussually blows in the 4 in 1. i will post pictures in a few minutes. it looks like it wasent even soldered on to the board you will see in the pictures what i am talking about.
nuv22 is offline Find More Posts by nuv22
Old Jul 15, 2006, 11:22 PM
nuv22 is offline
Joined Jul 2006
as you can see in the pictures the solder is not even damaged. i dont get why it fell off there is also no solder residue on the chip. wating for the soldering iron to heat up as i type!
Old Jul 16, 2006, 12:39 AM
nuv22 is offline
Joined Jul 2006
well after some STEADY HAND soldering i finnaly got all the leads of the chip solder on to the board. now comes the power up test. i will let you guys know how it goes wish me luck !lol
Old Jul 16, 2006, 01:08 AM
109Mechanik is offline
Find More Posts by 109Mechanik
Wie Ein floh!
109Mechanik's Avatar
UK
Joined Jun 2006
hopefully you made sure the IC was replaced the correct way round before testing....
109Mechanik is offline Find More Posts by 109Mechanik
Old Jul 16, 2006, 01:18 AM
nuv22 is offline
Joined Jul 2006
ohh yeah made sure that little circle was down at the bottom right. well have full controlls everything works except for the lower rotors (switched the motor leads on the board and both motors work fine) so it must be that i missed a solder point anyone know which lead controlls the bottom rotor?
Old Jul 16, 2006, 02:14 AM
nuv22 is offline
Joined Jul 2006
its alive ALIVE!!!!!!!!!!!!! both motors working i used a volt meter and found out which lead was not making contact so little more solder and we have power! i will do a fully asembled flight test tomorrow and give an update.
Old Jul 16, 2006, 03:21 AM
nuv22 is offline
Joined Jul 2006
well why wait till morning right ! flew around a bit and everything is A ok i might have to do a few changes to trim it out again but overall its working great ! here are some pictures.
Question Mosfet on Lama 4-in-1 Impulz3 Coaxial Helicopters 6 Feb 24, 2008 08:32 PM
Help! BCX 4 in 1 flashing Green and Red after Crash brocja01 Coaxial Helicopters 4 Oct 16, 2006 10:48 AM
Question Where to buy lama 4 in 1? nuv22 Coaxial Helicopters 1 Jul 26, 2006 11:46 AM
For Sale Brand New Esky Lama 4-in-1 & Tx 35 MHz cp-mike Aircraft - Electric - Helis (FS/W) 0 Jul 13, 2006 01:04 PM
Question 4 in 1 not arming until after several connects to the battery. JKA Coaxial Helicopters 13 Jan 12, 2006 08:47 AM
