Old Mar 20, 2009, 10:11 AM
JochenK is offline
Find More Posts by JochenK
JochenK's Avatar
Joined Jan 2005
Bill,
yes, I suppose so, though I don't know any other brand. But you can try the 23824RB (2.375" x 24") blades from Aerobalsa.
Jochen
JochenK is offline Find More Posts by JochenK
Old Mar 20, 2009, 10:58 AM
Mud Duck Bill is offline
Find More Posts by Mud Duck Bill
Mud Duck Bill's Avatar
Up State New York , USA
Joined Mar 2009
Ok Jochen I have a set of the 23824RB blades on the way. About how long do you think It will be before I see them here in the states? you aren't in the states are you.
Mud Duck Bill is offline Find More Posts by Mud Duck Bill
Old Mar 20, 2009, 11:05 AM
JochenK is offline
JochenK's Avatar
Joined Jan 2005
Bill,
I'm in Germany. But I don't think it'll take long.
When you use these wider blades, drill the holes that will hold the blade at the same distance from the leading edge as given in the plan.
Jochen
Old Mar 20, 2009, 11:16 AM
PeterO_UK is offline
Find More Posts by PeterO_UK
PeterO_UK's Avatar
Joined Aug 2006
I always think that the 2" blades on my Minimum look wide , these 2.375" blades are going to look even bigger
PeterO
PeterO_UK is offline Find More Posts by PeterO_UK
Old Mar 20, 2009, 12:39 PM
Boneswamped is offline
Find More Posts by Boneswamped
RC Group therapist
Boneswamped's Avatar
DeRidder LA.
Joined Nov 2008
Hello Bill,
Good to see another Minimum(ish) build in progress. Do you know what the ready to fly weight will be yet? It looks as if it will be much heavier than the original plan, but I also saw the thread about your larger blades so this may work out. Good luck with the Redneck engineering. All of the "Mum" designs are cool, and usually describe the size in the name. I think in your case perhaps you could name yours the Plumbermum since it's constructed out of plumbing pipe.
Regards,
-Mike
Boneswamped is offline Find More Posts by Boneswamped
Old Mar 20, 2009, 12:40 PM
Joined Mar 2009
Got -ya Now this is probably a question of preference but should I build a tail section with a functioning rudder or a ridged one?
Old Mar 20, 2009, 12:52 PM
Joined Mar 2009
Hi Boneswamped I read your Bio Hope your not in the pilot seat when you crash-um , Although the feeling is somewhat the same when you put a lot of effort into building some thing and it becomes a lawn DART. Below is my latest finished project waiting for some warmer weather to TEST FLY this one. Bill
Like I said I like the wow factor at the field.
Old Mar 20, 2009, 01:16 PM
JochenK is offline
JochenK's Avatar
Joined Jan 2005
Bill,
if you want to ROG, you'll have to build a rudder. Otherwise it's a question of preference.
Jochen
Old Mar 20, 2009, 01:25 PM
Joined Mar 2009
Rog??? Hold it I think I got R O G roll on ground? This is what I have in mind I use an airplane tail wheel assembly mounted on the front and let it pivot freely with a rather large wheel, build a functional rudder and let the front wheel seek is own direction aided but the force of the rudder inputs what do you guys think? Bill
Old Mar 20, 2009, 01:38 PM
RC Group therapist
DeRidder LA.
Joined Nov 2008
ROG is "Roll off ground" as opposed to hand launch.
Old Mar 20, 2009, 08:39 PM
Joined Mar 2009
It's amazing what you can do when your inspired.below is what I have so far.
I think I need more space between the prop and the tail feathers. What do you think? It looks like I could use a micro receiver have to go to bed and dream up some kind of storage for the ESC, receiver,Battery,and a nest of wires. enough for one day See ya later guys Bill
Old Mar 21, 2009, 02:08 AM
PeterO_UK's Avatar
Joined Aug 2006
It's looking good Bill.
If you do consider adding a rudder, I found that extra bracing is needed for the tail otherwise it tends to flex when rubber is applied, and that has odd results ! (like reversed controls ).
PeterO_UK
Old Mar 21, 2009, 04:08 AM
JochenK is offline
JochenK's Avatar
Joined Jan 2005
Bill.
as long as your prop doesn't hit the tail that's ok. But you should do some tests to find the correct motor offset:
http://www.rcgroups.com/forums/showthread.php?t=656504
What's the weight of your gyro up to now?
Jochen
Old Mar 23, 2009, 06:09 PM
Joined Mar 2009
Oh-Boy I got my sheet of garolite (gf) but I think I ordered the wrong thickness It is 1/16" that is too thick isn't I think I need 1/32" sheet right?
I must have missed somthing in the conversion table.
Old Mar 24, 2009, 04:02 AM
JochenK is offline
JochenK's Avatar
Joined Jan 2005
Bill,
the original hinge is 0.02". I've flown a 1/32" hinge but found it too stiff.
Jochen
Build Log 200g/7oz. dc head pusher - the Micromum JochenK Auto Gyros 216 Mar 16, 2009 12:19 PM
17.5 oz. Wing Load Dmerino Electric Ducted Fan Jet Talk 11 Dec 31, 2004 10:05 PM
The Sub-One: 24.5 g, 0.93 oz/sq ft (step 1 towards my goal) drliu Scratchbuilt Indoor and Micro Models 18 Jul 31, 2002 04:32 AM
Yippee! My wife got me a digital postal scale today. My moth is 6.5 oz w/ no battery! The Other Dave Parkflyers 1 Feb 08, 2002 10:37 PM
8.5 oz - 7.6v - 4,360Mah battery!!! asperkins Power Systems 5 Jan 03, 2002 08:27 PM
