Old Oct 14, 2008, 05:20 PM
StephanB is offline
Find More Posts by StephanB
Restricted User
StephanB's Avatar
Frankfurt-region, Germany
Joined Mar 2003
DanT,
gf is Glas Fibre. Search in yr. region for circuit board material without the copper-layer.
Stephan
StephanB is offline Find More Posts by StephanB
Old Nov 09, 2008, 03:32 PM
GeeW is offline
Find More Posts by GeeW
SB-28 UK Display Pilot
GeeW's Avatar
ENGLAND
Joined Jul 2001
A quick question for Jochen.
Is the v4 (2blade head) version any different to fly compared with the v2 (3blade head).
Would it be practical to use the same fuselage on either head, with 2 different set-ups on the Tx to adjust the neutral (tilt) angle and throws etc?
Reason I'm asking is that tomorrow night I need to decide which one I'm building before I start the main fuselage drilling and glueing!
And another thing if I may...whilst I'm in the chair
How are you balancing the completed head/blades?
Tail glueing as I speak.
Regards
Gordon
GeeW is offline Find More Posts by GeeW
Old Nov 09, 2008, 05:30 PM
JochenK is offline
Find More Posts by JochenK
JochenK's Avatar
Joined Jan 2005
Gordon,
yes, it is. Two-bladers have a higher following rate than three-bladers and are much more difficult to control. If you have no previous experience with gyros, start with the v2.
For balancing, I put my rotors on a horizontal axle and wait until the rotor movement ceases. The top blade now is the lightest blade and I stick a strip of some textile sticky tape to this blade, big enough to make it move downwards. Then I cut pieces off the tape, until one of the other blades is either pointing straight upwards or straight downwards. This means that two blades are balanced and the third blade is either lighter than the other blades (pointing upwards) or heavier (pointing downwards). If the third blade is lighter, add some tape to its end, and then cut it down until the rotor is balanced, if it's heavier, add equal pieces of tape to the two other blades and cut that down by equal amounts. I consider a rotor balanced when, from a stopped postition, the rotor will move slowly to its rest position, without swinging back.
Jochen
JochenK is offline Find More Posts by JochenK
Old Nov 10, 2008, 04:11 AM
PeterO_UK is offline
Find More Posts by PeterO_UK
PeterO_UK's Avatar
Joined Aug 2006
My 2ps worth on blade balancing.....
Before I cover the blades I weigh them and add laquer to the lightest blades to get them all to the same weight.
Then I line up all three blades and lay them across a tube on a flat surface. I then position each blade so they are all balancing level. I then sand off laquer / add laquer to move the CofG of the blades until they are all balancing at the same point.
I carefully cut out the covering to ensure each blade has the same amount added. Post covering "trimming" is carried out as described by Jochen.
This only works if the mounting plates have been made exactly right and the blades are all mounted at the same radius.
PeterO_UK
PeterO_UK is offline Find More Posts by PeterO_UK
Old Nov 10, 2008, 04:12 AM
PeterO_UK's Avatar
Joined Aug 2006
Pictures / Build Log ?
PeterO_UK
Old Nov 10, 2008, 04:03 PM
GeeW is offline
GeeW's Avatar
ENGLAND
Joined Jul 2001
Peter
I'll sling the odd image in your build thread if I may?
Jochen
I've been flying a 1/2A PT Gyro for a couple of years so not a complete Autogyro Novice.....
Regards
Gordon
Old Nov 10, 2008, 04:50 PM
JochenK is offline
JochenK's Avatar
Joined Jan 2005
Gordon,
ok. But remember, flying the three-bladed Minimum is fun, flying the two-bladed version is hard work.
Jochen
Old Nov 10, 2008, 05:22 PM
GeeW is offline
GeeW's Avatar
ENGLAND
Joined Jul 2001
Jochen
Your phrase "But remember, flying the three-bladed Minimum is fun, flying the two-bladed version is hard work" answered my basic question in one
V2 it is and maybe a 2 blade head later.
Regards
Gordon
Old Nov 29, 2008, 11:05 AM
PeterO_UK's Avatar
Joined Aug 2006
I can confirm that flying the V2 is fun
PeterO_UK
Old Dec 06, 2008, 11:16 AM
NYCBobby is offline
Find More Posts by NYCBobby
Joined Jun 2008
Dear Jochen:
Thanks so much for posting your design. This autogyro is exactly the configuration I wanted...pusher prop, tripod look. I'm gonna try to build one these but flying it will be another story.
-NYC BOBBY
NYCBobby is offline Find More Posts by NYCBobby
Old Dec 08, 2008, 07:28 AM
PeterO_UK's Avatar
Joined Aug 2006
Video of mine flying yesterday at
http://www.peteronion.org.uk/video/MinimumSecond.mpeg
(Right click the link to down load the file, then open it with windows media player).
PeterO_UK
Old Dec 08, 2008, 07:57 AM
SafeLandings is offline
Find More Posts by SafeLandings
It was a GLITCH! Honestly!
SafeLandings's Avatar
Stourport on Severn ,Worcestershire, United Kingdom
Joined Dec 2007
I was looking forward to that..but I cant get it to play?
SafeLandings is offline Find More Posts by SafeLandings
Old Dec 08, 2008, 08:37 AM
PeterO_UK's Avatar
Joined Aug 2006
Works fine for me
Did you follow the instructions ? FOr some reason Windows seems to think it is a QuickTime video file (which it isn't). If you down load the file and then explicitley open it with windows media player it should work OK.
PeterO_UK
Old Dec 08, 2008, 09:27 AM
Boneswamped is offline
Find More Posts by Boneswamped
RC Group therapist
Boneswamped's Avatar
DeRidder LA.
Joined Nov 2008
I have really enjoyed reading your posts about the development and flying of this model. Great show! Keep the posts coming. I have a .60 size O.S. laying around that is dying to go into a larger version of your design. Not sure what the scale would need to be to accomplish this, but maybee some of you smart guys would be willing to help scale the plan for a project of this nature. I'm always impressed with the smaller aircraft, but I prefer the big stuff. Any input would be greatly appreciated.
-Mike
Boneswamped is offline Find More Posts by Boneswamped
Old Dec 08, 2008, 03:04 PM
PeterO_UK's Avatar
Joined Aug 2006
MinimumSecond.mpeg (3 min 13 sec)
PeterO_UK
Build Log 200g/7oz. dc head pusher - the Micromum JochenK Auto Gyros 216 Mar 16, 2009 12:19 PM
17.5 oz. Wing Load Dmerino Electric Ducted Fan Jet Talk 11 Dec 31, 2004 10:05 PM
The Sub-One: 24.5 g, 0.93 oz/sq ft (step 1 towards my goal) drliu Scratchbuilt Indoor and Micro Models 18 Jul 31, 2002 04:32 AM
Yippee! My wife got me a digital postal scale today. My moth is 6.5 oz w/ no battery! The Other Dave Parkflyers 1 Feb 08, 2002 10:37 PM
8.5 oz - 7.6v - 4,360Mah battery!!! asperkins Power Systems 5 Jan 03, 2002 08:27 PM
