Old Oct 29, 2012, 03:03 AM
FRANCE
Joined Feb 2004
Hello
I am about to finish building the minimum 3 blades version .
Some questions :
Is the thickness of GF head plate 0,5 mm critical , is 0,8mm too much ? I did not find less , I have to search more !
I read somewhere here that height of motor thrust must be 1,4 inch above CG , is it OK ? or some other value is better ?
My overall weight comes to 630 gr , should I use longer blades to have more than 930 mm rotor diameter ? for instance 500 mm long blades instead of 450 mm to get 1030 mm rotor diameter ?
Are these values OK : 15° aileron , 8° elevator , ....... ?
Hang angle : 8° ? Are other values OK too ?
I added a rudder , with maximum throw , is that OK ?
MANY THANKS for answers
Andre
andre seb is online now Find More Posts by andre seb
Old Oct 31, 2012, 07:08 PM
britinoz's Avatar
Elizabeth South Australia 5113
Joined Nov 2005
G'Day Andre
I have been flying a couple of three blade minimums for several years and have found that the plastic lid of a "Tupperware " container makes a ver good hinge for the blades.
Your weight is just a little more than my models ...but should be OK and not require longer blades. This model is very "floaty" ..... Re the thrust......Can't remember the details.....but I just went as per the plan.
Your angles look OK Rudder max..OK
Happy Landings
Chris..................
britinoz is offline Find More Posts by britinoz
Old Nov 09, 2012, 09:19 AM
Joined Sep 2004
Originally Posted by andre seb View Post
Hello
Some questions :
Andre
Hi Andre,
I used some 0.8mm glass fibre sheet once and managed to survive one flight, the handling was not very good. I now only use 0.5mm Gf sheet, try this link, great products http://www.bucks-composites.com/cate...ss-fibre-sheet
Mick
boomerang is offline Find More Posts by boomerang
Old Nov 09, 2012, 12:38 PM
FRANCE
Joined Feb 2004
Hi
Thanks for infos
I finaly found ,5mm glass fiber sheets
I flew it without problem except I find it oscilate a lot ( pendulum movement left to right )
Perhaps it ocures because I only have 5° hang angle ?
I will try to fly it adding weight forward to get some 10 or 12° hang angle , perhaps it will help !
Last my CG is straight in the motor thrust line , not over like I read in a post !
Perhaps this is wrong ?
I am new to autogyros so I am searching
Regards
Andre
Old Nov 13, 2012, 02:17 PM
PeterO_UK's Avatar
Joined Aug 2006
I just realised my Minimum is coming up to being four years old ! How time flies
Four years ago.....
MinimumSecond.mpeg (3 min 13 sec)
MinimumEighth (2 min 59 sec)
I've not done much flying this year but I did have it out last Sunday when the weather was perfect (~5mph steady wind).
PeterO
PeterO_UK is offline Find More Posts by PeterO_UK
Old Nov 19, 2012, 05:32 PM
Joined Oct 2012
Hi PeterO
could you tell me what motor you use in your Minimum ? Is it a Hacker? If so which one?
Many thanks. John.
jobow52 is offline Find More Posts by jobow52
Old Nov 25, 2012, 06:35 PM
britinoz's Avatar
Joined Nov 2005
Autogyro by Antonio Di Giacomo...first test flight (4 min 4 sec)
According to this gentleman......this is "HIS" new design ?????????????????..................... Makes me think that I have seen something similar before......I could be wrong??
Chris...........
Old Jan 25, 2013, 11:09 AM
Jockadopolus's Avatar
Scotland
Joined Jan 2010
Face to the name Hans-Joachim Koester
Hans-Joachim Koester aka JochenK
http://www.mroecky.de/html/modelle_jk.html
Jockadopolus is offline Find More Posts by Jockadopolus
Build Log 200g/7oz. dc head pusher - the Micromum JochenK Auto Gyros 216 Mar 16, 2009 12:19 PM
17.5 oz. Wing Load Dmerino Electric Ducted Fan Jet Talk 11 Dec 31, 2004 10:05 PM
The Sub-One: 24.5 g, 0.93 oz/sq ft (step 1 towards my goal) drliu Indoor and Micro Models 18 Jul 31, 2002 04:32 AM
Yippee! My wife got me a digital postal scale today. My moth is 6.5 oz w/ no battery! The Other Dave Parkflyers 1 Feb 08, 2002 10:37 PM
8.5 oz - 7.6v - 4,360Mah battery!!! asperkins Power Systems 5 Jan 03, 2002 08:27 PM
