Old Jun 11, 2012, 11:10 PM
britinoz is offline
Find More Posts by britinoz
britinoz's Avatar
Elizabeth South Australia 5113
Joined Nov 2005
Mick
Dont tell every one how easy they are to fly, they will all want one.
Chris.........
britinoz is offline Find More Posts by britinoz
Old Jun 12, 2012, 03:35 PM
Si_B is offline
Find More Posts by Si_B
Si_B's Avatar
United Kingdom, England, East Grinstead
Joined Nov 2007
Mick,
What Scorpion motor are you running?
Cheers,
Simon
Si_B is offline Find More Posts by Si_B
Old Jun 12, 2012, 06:08 PM
Si_B is offline
Si_B's Avatar
Joined Nov 2007
Chris,
Just noticed your Minimum is fitted with a HK head. How do you find this as it would reduce the building time. I have the uv joints to build as per plan, but would like to get this one together quickly.
Cheers,
Simon
Old Jun 12, 2012, 07:38 PM
britinoz is offline
britinoz's Avatar
Joined Nov 2005
G'Day Simon
I find that the HK head is very good for any of the " Minimum-Spyro" size models.
Unfortunately HK is often OOS. I shall grab some more when they become available again.
Chris.........
Old Jun 13, 2012, 12:50 PM
boomerang is offline
Find More Posts by boomerang
Joined Sep 2004
Originally Posted by Si_B View Post
Mick,
Cheers,
Simon
Hi Simon,
I am using the 2212-22 Scorpion motor.
Mick.
boomerang is offline Find More Posts by boomerang
Old Jun 20, 2012, 05:38 PM
jeffstu is offline
Find More Posts by jeffstu
United Kingdom, Gt Lon
Joined Jan 2010
Well at long last i have made a start on my 2 blade Minimum and have now finished
the fus.frame,the main back upright is 5mm carbon x4mm tube and i have filled inbetween the uprights with lite ply,also note servo mounts and rudder servo mount
nose wheel assy finished and motor mount,i have this evening made up the blade blanks using 1/4" x 1/2" spruce LE epoxyed to 1/4" x 1 1/2" TE balsa section and will be shaped in aerofoil section as per the American balsa blades,hopefully will post photos of blades and head assy in next couple of days
regards Jeff
jeffstu is offline Find More Posts by jeffstu
Old Jun 20, 2012, 08:33 PM
britinoz is offline
britinoz's Avatar
Joined Nov 2005
Good one Jeff
Us Londoner's like our modelling ....don't we..........
Chris.......
Old Jun 21, 2012, 02:30 PM
Joined Sep 2004
regards Jeff
Hi Jeff,
Great to see another Minimum taking shape, you will enjoy every minute,
Another video of the 2 blader, the helmet mounted camera is getting better, I have another improvement to try and stop the model going out of frame. I have rolled the Auto 5 times but not on the video, I will capture the rolls next time.
Chris, I got your comment about the bunny, I had to delete and re upload the vid due to the poor quality. Seems ok now.
Mick.
2Blade evening flight (4 min 40 sec)
Old Jun 21, 2012, 04:39 PM
SafeLandings is offline
Find More Posts by SafeLandings
It was a GLITCH! Honestly!
SafeLandings's Avatar
Stourport on Severn ,Worcestershire, United Kingdom
Joined Dec 2007
Mick,
Excellent piloting skills, loved every minute of the flight
That is some power to weight ratio you have there
Regards
Rich
SafeLandings is offline Find More Posts by SafeLandings
Old Jun 21, 2012, 05:39 PM
jeffstu is offline
Joined Jan 2010
That was a great video and some super flying Boomerang,what watts of power have you of your motor.
I an going to use a Turnigy 180watt motor.
In my previous post regarding start of Minimum i stated that i used a 5mmx4mm carbon tube for the back upright,i should of said i used 6mmx4mm carbon tube as i needed a 4mm hole in tube at top for the rotor head,
here are more photos and included another view of main fuse frame,also the universal joint for the head, and a couple of rotor blade blanks.
regardsJeff
Old Jun 22, 2012, 01:41 AM
Si_B is offline
Si_B's Avatar
Joined Nov 2007
Jeff,
Did you have to glue the splined brass inserts into that UV joint. I used a similar one on my new Spyro, and only noticed during the last set up that they were not actually fitted in !!. I ended up epoxying mine in.
Good looking machine, I have all the carbon to build one of these, just need the time now!!
Old Jun 22, 2012, 02:56 AM
jeffstu is offline
Joined Jan 2010
Yes i had to apply epoxy glue to the splined shaft.i got my universal joint from Maplin
but now noticed that Giant Shark list them with verious hole sizes in the splined parts
regards Jeff
Old Jun 22, 2012, 06:09 AM
Si_B is offline
Si_B's Avatar
Joined Nov 2007
Jeff,
If you are ever near East Grinstead give me a shout. Be good to see someone else flying autogyro !! Will keep and eye on your build thread.
I bought mine off ebay but it was a bit steep price wise, will have a look on Giant Shark. I managed to get hold of a couple of the uv joint suspension joints for the States for my build, which means I can stick to the plan.
Cheers,
Simon
Old Jun 22, 2012, 08:45 AM
Joined Sep 2004
Originally Posted by SafeLandings View Post
Mick,
Regards
Rich
Thanks Rich,
I will check what power the set up is giving me, I am looking into getting more power, maybe better battery or a little bit more pitch on the prop, you can never have enough.
Mick
Old Jun 23, 2012, 04:03 AM
Joined Dec 2007
Mick,
MORE POWER, I'm shaking my head here..LOL! are you going to try and pull a bunt off?
Regards
Rich
Build Log 200g/7oz. dc head pusher - the Micromum JochenK Auto Gyros 216 Mar 16, 2009 12:19 PM
17.5 oz. Wing Load Dmerino Electric Ducted Fan Jet Talk 11 Dec 31, 2004 10:05 PM
The Sub-One: 24.5 g, 0.93 oz/sq ft (step 1 towards my goal) drliu Scratchbuilt Indoor and Micro Models 18 Jul 31, 2002 04:32 AM
Yippee! My wife got me a digital postal scale today. My moth is 6.5 oz w/ no battery! The Other Dave Parkflyers 1 Feb 08, 2002 10:37 PM
8.5 oz - 7.6v - 4,360Mah battery!!! asperkins Power Systems 5 Jan 03, 2002 08:27 PM
