This thread is privately moderated by the wiz, who may elect to delete unwanted replies.
Old Jan 05, 2013, 10:29 PM
RknRusty is offline
Find More Posts by RknRusty
RknRusty's Avatar
United States, SC, Columbia
Joined May 2010
As to who thought of it, I'd say probably nobody had a ureka moment. The chemists just knew it because they know the reactive properties of chemicals. My son is a chemist, so I might have an inflated opinion of their scientific intuition.
RknRusty is offline Find More Posts by RknRusty
Old Jan 09, 2013, 10:05 PM
Billinaz is offline
Find More Posts by Billinaz
Billinaz's Avatar
United States, AZ, Chandler
Joined Jul 2011
When scratch building I often want to lighten parts. One of my favorite ways is to simply bore holes in them. Wing ribs especially. When boring holes in plywood, I do it like everyone else - with a drill. When doing it in balsa, I use brass tubes with the ends sharpened. Seen here: http://www.rcgroups.com/forums/showt...1563292&page=2 (Photo far right, post #20.)
To sharpen those ends I use a reloader's case preparation tool known as a case deburring and chamfering tool.
Here is one example: http://www.midwayusa.com/product/389...deburring-tool
Here's another - identical to the one I use:http://www.midwayusa.com/product/789...er?cm_vc=subv1
These are hardened steel tools and will last you more than one lifetime.
Bill
Billinaz is offline Find More Posts by Billinaz
Old Jan 11, 2013, 12:34 PM
builderdude is online now
Find More Posts by builderdude
builderdude's Avatar
United States, TX
Joined Jun 2011
That's a good tip.
I have used 1/16" balsa sheeting for wing ribs before, but I don't like using balsa that thin because it is extremely fragile, which makes it tough to work with. I prefer 1/8" balsa for wing ribs. But if I could use your hole-cutting lightening method, that might be better than trying to use fragile solid 1/16" sheet.
builderdude is online now Find More Posts by builderdude
Old Jan 13, 2013, 07:54 PM
Curare is online now
Find More Posts by Curare
KE your cub.
Curare's Avatar
Australia, WA, Perth
Joined Jun 2005
Split the difference, go for 3/32" ribs with the guts cut out of them
Curare is online now Find More Posts by Curare
Old Jan 21, 2013, 07:16 AM
Stuart A is offline
Find More Posts by Stuart A
You know nothing....
Stuart A's Avatar
Joined Sep 2011
And if you're working with soft balsa sheeting KEEP YOUR NAILS SHORT
don't ask.........
Stuart A is offline Find More Posts by Stuart A
Old Jan 22, 2013, 07:10 PM
sroge is offline
Find More Posts by sroge
sroge's Avatar
Germany
Joined Sep 2010
My best low budget tool: wooden McDonalds coffee sticks. I use them for mixing, applying and removing excess (sanded to 45-60 deg) epoxy or to CA glue them to thin wood layers for stiffening. Stole large amounts of them until my local restaurant manager gave me a 500 pack.
sroge is offline Find More Posts by sroge
Old Jan 22, 2013, 07:51 PM
RknRusty is offline
RknRusty's Avatar
Joined May 2010
Yeah, me too. I raided a coffee shop at a book store for a year's supply of the little wooden sticks. I use them for the same things you do.
Old Jan 22, 2013, 08:43 PM
tailskid2 is offline
Find More Posts by tailskid2
tailskid2's Avatar
USA, AZ, Phoenix
Joined May 2003
And while we are at McDonald's.....their straws are very BIG and good for antenna wires for those not using 2.4!
tailskid2 is offline Find More Posts by tailskid2
Latest blog entry: VQ 112" Beaver
Old Jan 22, 2013, 10:25 PM
RknRusty is offline
RknRusty's Avatar
Joined May 2010
I call those big ol' McDonalds straws "Pipes". I guess "Conduits" would be more fitting for wire.
Old Jan 24, 2013, 03:19 PM
motorrc is online now
Find More Posts by motorrc
United States, OH, Canton
Joined Nov 2010
work less than you think you should
motorrc is online now Find More Posts by motorrc
Old Jan 24, 2013, 04:50 PM
Jim.Thompson is online now
Find More Posts by Jim.Thompson
Entropy is happening!
Jim.Thompson's Avatar
Australia, NSW, Bellingen
Joined Aug 2008
Straws for drag spars.
[QUOTE=tailskid2;23898938]And while we are at McDonald's.....their straws are very BIG .........................QUOTE]
I got some the other day for another purpose. I plan to use them to make up drag spars for moulded wings. Slide them onto a temporary mandrel, and then thread biaxial glass sleeving over them. When tacked into position with CA and the mandrel removed, just wet out with epoxy just prior to assembly of the two halves.
However, the very best building tip that I have is one I learned only a few days ago.
When applying PVA after wax on a plug or mould to complete the release system application, dust with talc first. Then dust off excess or blow off with air.
The PVA flows superbly without any of the surface tension fisheye phenomenon that otherwise happens.
Fantastic results.
Jim.
Jim.Thompson is online now Find More Posts by Jim.Thompson
Last edited by Jim.Thompson; Jan 24, 2013 at 04:51 PM. Reason: spelling correction
Old Jan 24, 2013, 06:41 PM
scruffy1 is online now
Find More Posts by scruffy1
looking up down under
scruffy1's Avatar
Australia, NSW, Fairlight
Joined Feb 2008
Fantastic results.
Jim.
i wish i understood any of that
is this for fibreglass, carbon, or some other method of mould ?
i am a complete noob with composites
scruffy1 is online now Find More Posts by scruffy1
Old Jan 24, 2013, 06:57 PM
Joined Aug 2008
This applies to any composite moulding process. That is, fibreglass of any variety of resin and reiforcement combination.
Not to plaster or plaster based moulding systems.
I'm not sure just how detailed an answer you are looking for.
Old Jan 24, 2013, 07:23 PM
scruffy1's Avatar
Joined Feb 2008
that'll do
i am still getting to grips with carbon tissue and finishing epoxy; my release mechanism in wax paper on a glass surface
curves are for future experimentation
Old Jan 25, 2013, 07:04 AM
sroge is offline
sroge's Avatar
Germany
Joined Sep 2010
I had problems with my Somethin' Extra and had to turn the engine by 90 degrees, but the t-nuts were in the wrong place now. How install new ones inside there? Finally I came up with this idea and it works perfectly:
Stefan
Have you ever done something THIS stupid ? ChrisP Electric Plane Talk 57 May 06, 2015 01:27 PM
Question whats the best single strator cdrom you ever made? thenetpoet Power Systems 8 Oct 27, 2005 02:21 PM
Have you ever "Got a free one" AustinTatious Sailplane Talk 6 Aug 27, 2004 04:38 AM
Sarted building gws p-51. Whats the best tip you have for me? Thanks! liaudio Parkflyers 10 Feb 12, 2003 10:37 PM
August EFI, Which one of you guys got my missing pages Ken Lapointe Electric Plane Talk 14 Aug 01, 2001 12:38 AM
