This thread is privately moderated by the wiz, who may elect to delete unwanted replies.
Old Jan 02, 2013, 03:50 PM
Jim.Thompson is offline
Find More Posts by Jim.Thompson
Entropy is happening!
Jim.Thompson's Avatar
Australia, NSW, Bellingen
Joined Aug 2008
Originally Posted by Marion View Post
Never get CA on your fingers when you have baking soda on them. I just did that. Don't recommend it
Why would you have baking soda on the bench anyway? Is it used as a "kicker" for the CA?
Jim.Thompson is offline Find More Posts by Jim.Thompson
Old Jan 02, 2013, 04:17 PM
scruffy1 is offline
Find More Posts by scruffy1
looking up down under
scruffy1's Avatar
Australia, NSW, Fairlight
Joined Feb 2008
it's a cheap gap filler that goes off like concrete when you use cyanoacrylate on it
brittle and impossible to sand, but easy to get into gaps
scruffy1 is offline Find More Posts by scruffy1
Old Jan 02, 2013, 04:38 PM
Joined Aug 2008
That's good to know Scruffy.
Do you put the baking soda in the required place and then add the CA?
I like your Avatar! Another Aussie bird.
Jim.
Old Jan 03, 2013, 05:00 AM
Stef is offline
Find More Posts by Stef
Flying Saucer Mechanic
Stef's Avatar
Middle River MD
Joined Dec 2000
You can make cheap "kicker" that doesn't melt foam. Alcohol a little water (or alcohol that already has some water in it) enough baking soda to make a saturated solution (it won't disolve in the alcohol only in the the water) pour off the clear solution into a small spray bottle and there you have it. The alcohol helps overspray to evaporate quickly.
Stef is offline Find More Posts by Stef
Old Jan 03, 2013, 08:27 AM
scruffy1 is offline
scruffy1's Avatar
Joined Feb 2008
yep
i usually "spoon" a little bit in the vicinity with a #11 blade, massage it in the gap with my finger and the drop thin c.a. at one end and let it roll down the join
don't touch the bicarb or it will wick onto your glue
and you'll be picking it off your fingers for ages if you are silly enough to "check if it's gone off yet"
i took the avatar pic on my balcony; they are fairly regular visitors
Old Jan 03, 2013, 02:19 PM
Marion is offline
Find More Posts by Marion
Marion
USA, NC, Hillsborough
Joined Oct 2003
scruffy1 has it right. That is exactly what I was doing. Had baking soda on my finger and touched some still wet CA. Burned me like crazy too :-(
Marion is offline Find More Posts by Marion
Old Jan 03, 2013, 10:12 PM
scruffy1 is offline
scruffy1's Avatar
Joined Feb 2008
yep, c.a. going off is exothermic - hence the wisp of vapour it often produces
Old Jan 04, 2013, 02:39 AM
scrub monkey is offline
Find More Posts by scrub monkey
use the 4s luke, use the 4s...
scrub monkey's Avatar
Australia, QLD, Booyal
Joined Sep 2012
hence that burning feeling when youve got your arm half way to china in a glider and a bit gets through to your fingers. ive put blood, tears and flesh into that plane
scrub monkey is offline Find More Posts by scrub monkey
Old Jan 04, 2013, 09:37 AM
builderdude is offline
Find More Posts by builderdude
builderdude's Avatar
United States, TX
Joined Jun 2011
Keep in mind that if you end up having too much of the baking soda/CYA glue and can't sand it, you can use a dremel to sand it down if you're careful. But watch out for the fumes that come off from the sanding, because that burns your eyes too.
builderdude is offline Find More Posts by builderdude
Old Jan 04, 2013, 11:18 AM
RknRusty is offline
Find More Posts by RknRusty
RknRusty's Avatar
United States, SC, Columbia
Joined May 2010
I use baking soda too. I wonder if CA vapor is what went wrong with the coating on my eyeglasses.
RknRusty is offline Find More Posts by RknRusty
Old Jan 04, 2013, 11:27 AM
xrx1113 is offline
Find More Posts by xrx1113
xrx1113's Avatar
United States, FL, Lehigh Acres
Joined Aug 2011
"Get out of my way , I'll fix it"
xrx1113 is offline Find More Posts by xrx1113
Old Jan 04, 2013, 12:43 PM
United States, TX
Joined Jun 2011
Very possible.
If you build scale plastic models, you will notice that using too much CA glue on the clear parts (canopies and windshields) results in a permanent fog on the clear.
Old Jan 04, 2013, 03:35 PM
rcav8r2 is offline
Find More Posts by rcav8r2
rcav8r2's Avatar
United States, PA, Beaver
Joined Sep 2001
If I am going to glue more than a few glue joints with CA, I will remove my contacts. Not sure if it is needed, but after seeing on those crime shows how they use CA vapors to pull finger prints from plastic bags and such, I figured it can't hurt as the principles are basically the same....
rcav8r2 is offline Find More Posts by rcav8r2
Old Jan 05, 2013, 01:58 AM
Aerogance is offline
Find More Posts by Aerogance
Anyone can build! It's fun!
Aerogance's Avatar
United States, CA, Ventura County
Joined Sep 2008
I was told early on in my model building career to cut with a razor knife by cutting away from your body instead of toward it. I took the guy's word for it after he showed me the 14 stitches in his thigh.
Aerogance is offline Find More Posts by Aerogance
Old Jan 05, 2013, 10:36 AM
kwmtrubrit is offline
Find More Posts by kwmtrubrit
Be an organ donor
Little Rock, AR. U.S.A via U.K
Joined May 2004
Short version, probably so. Long version: CA vapour/fumes are attracted to moisture/oil and will form a hard film.
This process is used to detect finger prints on items such as styrofoam cups. This is how I saw it demonstrated. The cup is put into a metal cabinet. Also in the cabinet is one of those little hot plate things that keeps your coffee warm. On the is a little metal ashtray. A couple drops of CA, turn on the hot plate. The CA turns into a vapour/fumes and is attracted to the oil of the finger print. it will harden and then can be dusted and photographed.
So, the question I always have is: Who thought of this?: I don't know that, but I can tell you how it was noticed. Car parts coming from Japan were bagged in plastic that was sealed with CA..The heat in the belly of the container ships would vapourise the CA. the Vapours were attracted to the moisture of the Japanese workers finger prints showing a print on the packaging.
kwmtrubrit is offline Find More Posts by kwmtrubrit
Last edited by kwmtrubrit; Jan 05, 2013 at 11:21 AM. Reason: Corrections and additions
Have you ever done something THIS stupid ? ChrisP Electric Plane Talk 57 May 06, 2015 01:27 PM
Question whats the best single strator cdrom you ever made? thenetpoet Power Systems 8 Oct 27, 2005 02:21 PM
Have you ever "Got a free one" AustinTatious Sailplane Talk 6 Aug 27, 2004 04:38 AM
Sarted building gws p-51. Whats the best tip you have for me? Thanks! liaudio Parkflyers 10 Feb 12, 2003 10:37 PM
August EFI, Which one of you guys got my missing pages Ken Lapointe Electric Plane Talk 14 Aug 01, 2001 12:38 AM
