This thread is privately moderated by the wiz, who may elect to delete unwanted replies.
Old Oct 29, 2012, 06:03 PM
builderdude is offline
Find More Posts by builderdude
builderdude's Avatar
United States, TX
Joined Jun 2011
For me, it was advice I got from Pat Tritle:
"Build an airplane to fly, not to crash."
builderdude is offline Find More Posts by builderdude
Old Oct 29, 2012, 06:41 PM
scruffy1 is offline
Find More Posts by scruffy1
looking up down under
scruffy1's Avatar
Australia, NSW, Fairlight
Joined Feb 2008
i believe the advice is "build a thermal glider to fly, and a slope soarer to crash"
scruffy1 is offline Find More Posts by scruffy1
Old Oct 30, 2012, 01:52 AM
Curare is offline
Find More Posts by Curare
KE your cub.
Curare's Avatar
Australia, WA, Perth
Joined Jun 2005
No he's right.
Built it strong enough to withstand flight loads, not crash loads.
If you built it to withstand crash loads it'll probably never fly.
Curare is offline Find More Posts by Curare
Old Oct 30, 2012, 04:42 AM
scruffy1 is offline
scruffy1's Avatar
Joined Feb 2008
Originally Posted by Curare View Post
No he's right.
you haven't flown the slopes where i live obviously
even a brick will gain elevation in a good sou' easterly, but getting anything to return in one piece requires resilience on attaining terra firma
Old Oct 30, 2012, 05:56 PM
Curare is offline
KE your cub.
Curare's Avatar
Joined Jun 2005
I've flown in some pretty crazy places.
Old Nov 01, 2012, 08:28 AM
RknRusty is offline
Find More Posts by RknRusty
RknRusty's Avatar
United States, SC, Columbia
Joined May 2010
The best building tip I ever got... well, this one applies to life in general, I learned it the hard way and I've reminded my son of it as he was growing up, and that is:
Never ever think(or talk) about how good you are at something while you're doing it.
RknRusty is offline Find More Posts by RknRusty
Old Nov 01, 2012, 08:49 AM
RknRusty is offline
RknRusty's Avatar
Joined May 2010
If you are working hard on a project especially when precision is at a premium, and you hear your inner voice say, That'll do, back off and take a break. Come back later when you are fresh and re-think your work.
I hope that's not too obvious to qualify as a good tip.
Old Nov 01, 2012, 09:31 AM
United States, TX
Joined Jun 2011
I like this one.
And I personally reminded someone of this here, just a few days ago.
Old Nov 03, 2012, 11:16 PM
ARUP is offline
Find More Posts by ARUP
Joined Mar 2010
A foam roller to varnish a fabric and wood wing in lieu of a brush. The foam roller spreads the varnish (or paint) and if any squeezes thru the fabric the foam will re-absorb it once it when it becomes less saturated with the varnish. Thanks Nigel Tarvin of Tarvin Model Products!
ARUP is offline Find More Posts by ARUP
Old Nov 04, 2012, 10:41 AM
-S- is offline
-S-
Find More Posts by -S-
-S-
Just one more..... Just one...
United States, TX, Henderson
Joined Jan 2010
Building the Other wing when you only have one on the plans
I have not read all the great tips here yet, and this has most likely been submitted but.......
I'm doing my second build (Sportster 60)
I asked one of the experienced builders the best way to build the other wing, the idea of "building upside down" has me a bit flabbergasted.
He gave me a genius idea, take the existing wing plan, flip it over, and lightly coat it with cooking oil.
Obviously putting down plastic or wax paper over it to protect the building board and Balsa
It makes it just as good as side "A"
Hope it helps -S
-S- is offline Find More Posts by -S-
Old Nov 04, 2012, 05:51 PM
cbarnes0061 is offline
Find More Posts by cbarnes0061
Flying Low
cbarnes0061's Avatar
United States, VA, Petersburg
Joined Mar 2012
Spraying the plans with WD-40 works as well.
cbarnes0061 is offline Find More Posts by cbarnes0061
Old Nov 04, 2012, 08:29 PM
seeingeyegod is offline
Find More Posts by seeingeyegod
seeingeyegod's Avatar
United States, OR, Portland
Honestly, the best tip I ever got was from the last guillows kit I attempted to build, believe it or not. Before I started building kits as an adult, I had tried a couple times as a kid and had apparently never noticed the part where you are supposed to put wax paper or plastic wrap over the plans. That was a big Oooooooh thats how this works moment for me
seeingeyegod is offline Find More Posts by seeingeyegod
Old Nov 07, 2012, 10:11 PM
baronthebaron is offline
Find More Posts by baronthebaron
Joined Nov 2012
best building tip
" you should put locktite on that"
baronthebaron is offline Find More Posts by baronthebaron
Old Nov 27, 2012, 04:12 PM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
Tried a couple of searches to see if this had been brought up -no find.
For those putting retracts in a wing with modest dihedral, some times a 90 set just doesn't sit 90 to the ground. Use these to shim up the correct angle.
http://www3.towerhobbies.com/cgi-bin...&I=LXE953&P=SM
20, 40 , or 60 size One plate will do a set of mains. Just cut in 4 pieces. I suppose you could double them to get up 6.
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Nov 28, 2012, 09:38 AM
xrx1113 is offline
Find More Posts by xrx1113
xrx1113's Avatar
United States, FL, Lehigh Acres
Joined Aug 2011
build it to fly not to withstand a crash
and a close second was build it straight.
xrx1113 is offline Find More Posts by xrx1113
Have you ever done something THIS stupid ? ChrisP Electric Plane Talk 57 May 06, 2015 01:27 PM
Question whats the best single strator cdrom you ever made? thenetpoet Power Systems 8 Oct 27, 2005 02:21 PM
Have you ever "Got a free one" AustinTatious Sailplane Talk 6 Aug 27, 2004 04:38 AM
Sarted building gws p-51. Whats the best tip you have for me? Thanks! liaudio Parkflyers 10 Feb 12, 2003 10:37 PM
August EFI, Which one of you guys got my missing pages Ken Lapointe Electric Plane Talk 14 Aug 01, 2001 12:38 AM
