This thread is privately moderated by the wiz, who may elect to delete unwanted replies.
Old Jun 12, 2012, 02:26 AM
mtesa is offline
Find More Posts by mtesa
mtesa's Avatar
Joined Aug 2009
OffTopic:
Found it!!
Yey!!!
mtesa is offline Find More Posts by mtesa
Old Jun 22, 2012, 09:16 AM
digiex_chris is offline
Find More Posts by digiex_chris
Joined Apr 2011
Packing tape will heat shrink! I discovered this by accident. I was trying to toughen up a foamie, so I covered the thing in packing tape, completely wrapping the wing. Then I spray painted it, and was trying to speed up the drying between coats with a heat gun, overheated it, and it shrunk the inevitable tape wrinkles out! It doesn't stick to foam so well though, so you've gotta wrap the wing such that there's a tape on tape joint or it'll pull off what you've stuck it to. Or CA the edges down, or something.
As a plus, heat shrinking it has significantly increased rigidity in that thin wing.
digiex_chris is offline Find More Posts by digiex_chris
Old Jun 22, 2012, 09:19 AM
Joined Apr 2011
Take a guitar string, string it across a 2' wide 8' long piece of melamine covered particle board at about 2mm higher than the thickness you want, and heat it up with your favorite foam bow cutting power supply. You can now slice insulation foam to whatever thickness you want. I use the blue 2x8 sheets in 1.5" thickness. The pink stuff is stiffer but heavier. The green stuff, if you can find it, is lighter, but flexier and needs a little reinforcement. 10 foamies for $20!
I find it works best if you stick one end up on the workbench and the other end on the ground, weigh down the foam with about 10 lbs of weights across it's length, and let gravity do the feeding.
Old Jun 22, 2012, 10:30 AM
rcav8r2 is offline
Find More Posts by rcav8r2
rcav8r2's Avatar
United States, PA, Beaver
Joined Sep 2001
Since you mentioned heat and tape.... On foamies I use Scotch Brand tape (not the cheap imitations) and use my covering iron on low to set the tape in the foam when making hinges and such. Test on scrap, you want it hot enough to "set" the glue, but not too hot to melt the foam/tape. Also burnish it down with the iron.
Once set like this it will take a little bit of foam with it when removing so it is really on there. If you do need to remove it, just apply heat, and it will come off very easily.
HUmmm I always wanted to do this. With an 8' piece of foam, I'm guessing you have really high ceilings, and set the board at a 45? You would need 16' of space, right? Or does the shaved piece just curl along the floor?
I do use gravity to square up cuts in foam when cutting core blanks. Guaranteed a 90 degree cut every time
rcav8r2 is offline Find More Posts by rcav8r2
Old Jun 22, 2012, 12:41 PM
Joined Apr 2011
with one end on my bench (3 feet high or so) and the other end a foot or so off the ground, and the wire in the middle of the sheet, it seems to work ok. half of the sheet is on the board before it even starts cutting. It's not 45 degrees, it's closer to 25 or 30. I also tend to cut half sheets, not full 8' sheets, that way it doesn't hang up on the section of the sheet that's hanging off the top edge and I don't need to hand hold the top half. Still gives you a 2x4' piece, which is plenty for a wing half for a 90" plane. But at that angle I can get an 8' sheet 4' onto the rig and 4' hanging off with room to spare in a 7' garage. Don't need 45 degrees, just weight. A dimmer on the heat control is good, lets you dial in the speed. Low as you can stand (time wise) seems to give the best finish. I cut a 4' sheet one pass in about 5 minutes.
The material is critical. Slippery! If it sticks anywhere, it won't cut well or you'll end up with a line across your nice finish from the wire stopping there. You'd probably need less weight or less critical of a surface with more angle, but then you run into the problem of the weights not staying put and leaving the foam behind and ending up in a pile on the ground.
One addition I want to make is melamine sides to guide it, it'll tend to fall off one side or another.
Old Jun 22, 2012, 12:52 PM
Joined Apr 2011
I only tried an 8' sheet once, I just raised the rig enough keeping the angle the same for it to clear on the ground. I just ran it through the CAD, for a full 8' sheet, at 25 degrees, you need 15' of floor space and 7.2' of ceiling height.
Old Jun 28, 2012, 10:02 PM
Xanadu is offline
Find More Posts by Xanadu
Xanadu's Avatar
Canada, MB, Winnipeg
Joined Nov 2006
Hot wire foam cutter (1 min 16 sec)
Xanadu is offline Find More Posts by Xanadu
Old Jun 29, 2012, 06:34 AM
xairflyer is online now
Find More Posts by xairflyer
Bleriot's R Us
xairflyer's Avatar
Ireland, Donegal
Joined Nov 2003
Excellent what are you using as a power supply?
Also the wire seemed to be slack at the end
xairflyer is online now Find More Posts by xairflyer
Old Jun 29, 2012, 06:55 PM
Xanadu is offline
Xanadu's Avatar
Joined Nov 2006
Uses a home made power supple with a transformer gong from 120v to 12v, and a dimmer switch to alter the power in.
I know the wire stretches a bit but it never seems to effect the cut thickness so far. Hard to get the right power setting for cutting versus not having the wire stretch while its hot. Maybe puting a tension spring would help, but I have broken a few wires as well with greater tension.
Works great for what I need. I also made a hotwire "band saw". Go to youtube and search for Xan2k. There you will find the other videos.
Old Jun 29, 2012, 08:08 PM
barry wilson is offline
Find More Posts by barry wilson
amherst,nova scotia,canada
Joined Nov 2003
Any specifications on the transformer label? Other than 120 to 12 volts..Amperage for example or anything else. I want to build a foam cutter and am not sure of the amount of current delivery required without burning out the transformer.
barry wilson is offline Find More Posts by barry wilson
Old Jun 29, 2012, 11:07 PM
Xanadu is offline
Xanadu's Avatar
Joined Nov 2006
Actually it cuts it down to 6.0 - 6.3 volts and 6amps. I just looked at the transformer. Bought it at Radio shack 4 years ago for $10.
Old Jun 30, 2012, 06:53 AM
RknRusty is offline
Find More Posts by RknRusty
RknRusty's Avatar
United States, SC, Columbia
Joined May 2010
If the stretch was causing a problem, you could try different types of wire. Tungsten might do it. Or different thicknesses. The necessary current would vary with those differences.
RknRusty is offline Find More Posts by RknRusty
Old Jun 30, 2012, 09:58 AM
Xanadu is offline
Xanadu's Avatar
Joined Nov 2006
Been thought that, just using what I currently have. Works good enough for me.
Old Jun 30, 2012, 06:40 PM
scrubmonkey is offline
Find More Posts by scrubmonkey
Australia, QLD, Booyal
Joined Aug 2011
I found was to use a cheap stanley knife with those break off blades. Because you really only use the tip of your knife(thats why xacto knives have a short blade and not a 3 foot samuri blade) you just snap off that section with a pair of pliers and PUT IT IN THE BIN!!!! Not on the bench. And you have a practically brand new blade.
scrubmonkey is offline Find More Posts by scrubmonkey
Old Jul 02, 2012, 08:08 AM
rcav8r2 is offline
rcav8r2's Avatar
Joined Sep 2001
@Xanadu... Thanks for the video... that was a lot less complicated than what I was thinking about making. I see your not using a whole sheet which simplifys things. I'll have to make one of these... BTW, I have the same basic dimmer/Xformer setup, but include an amp meter. This way I can set the current no matter how large or small my bow is. I find about 2.1 amps to be idea for cutting.
Have you ever done something THIS stupid ? ChrisP Electric Plane Talk 57 May 06, 2015 01:27 PM
Question whats the best single strator cdrom you ever made? thenetpoet Power Systems 8 Oct 27, 2005 02:21 PM
Have you ever "Got a free one" AustinTatious Sailplane Talk 6 Aug 27, 2004 04:38 AM
Sarted building gws p-51. Whats the best tip you have for me? Thanks! liaudio Parkflyers 10 Feb 12, 2003 10:37 PM
August EFI, Which one of you guys got my missing pages Ken Lapointe Electric Plane Talk 14 Aug 01, 2001 12:38 AM
