This thread is privately moderated by the wiz, who may elect to delete unwanted replies.
Old Sep 08, 2006, 08:45 PM
RCTyp is offline
Find More Posts by RCTyp
Smashes Things
RCTyp's Avatar
Montpelier, VA
Joined Feb 2005
Thanks for all the tips, this helped me.
I was told to get a thick glass plate to build on. That, on top of my 2" maple building table is dead nuts flat.
Wrap masking tape around your finger tips to stop CA'ing the fingers together and to the balsa.
Use flight sim (I know that is flying tip)
Did you know that a brass tube makes a great drill bit?
Typ
RCTyp is offline Find More Posts by RCTyp
Old Sep 09, 2006, 08:09 AM
pd1 is offline
pd1
Find More Posts by pd1
pd1
United States, MA, Haverhill
Joined Jun 2006
When spray painting small or light parts place them on a widow screen, they won't blow away as easily.
With electric airplanes, whenever you're going to change any radio function or check servo direction, make sure you remove the prop first.
pd1 is offline Find More Posts by pd1
Old Sep 09, 2006, 04:00 PM
RCTyp is offline
Smashes Things
RCTyp's Avatar
Montpelier, VA
Joined Feb 2005
Help - Harriers
Deleted, wrong thread
Old Sep 09, 2006, 04:16 PM
RCTyp is offline
Smashes Things
RCTyp's Avatar
Montpelier, VA
Joined Feb 2005
Help - Harriers
Deleted
Last edited by RCTyp; Sep 09, 2006 at 04:17 PM. Reason: Argghhhh, I can't believe I did it again
Old Sep 09, 2006, 05:44 PM
Ekim is offline
Find More Posts by Ekim
Linux addict
Ekim's Avatar
S. Jersey, US, the 51 state
always cover your models in an area that is colder than anything you expect to fly in... (an airconditioned hous'll do) cause if you don't the coverin will sag (at least some of mine have) esp. fabic covering..
Ekim is offline Find More Posts by Ekim
Old Sep 10, 2006, 06:55 AM
Iflyrc_vic is offline
Find More Posts by Iflyrc_vic
Iflyrc_vic's Avatar
USA
Joined Dec 2004
Use a Laser Level
A laser level can be used for a variety of building tasks. You can check the alignment of ribs, check wing-stab incidence, and line up anything before you glue it in place.
Iflyrc_vic is offline Find More Posts by Iflyrc_vic
Old Sep 10, 2006, 07:18 AM
Jim_Marconnet is offline
Find More Posts by Jim_Marconnet
Fly long and land softly
Jim_Marconnet's Avatar
Madison, Alabama USA
Joined Oct 2005
Could you share or point out how you use it to check wing-stab incidence?
And wish they came a little more powerful for cutting balsa, plywood, carbon fibre, etc.
Jim_Marconnet is offline Find More Posts by Jim_Marconnet
Old Sep 10, 2006, 09:36 AM
Ollie is offline
Find More Posts by Ollie
Punta Gorda, FL
Joined Apr 2002
Iflyrc_vic,
Great tip! I'll use it later.
Ollie is offline Find More Posts by Ollie
Old Sep 10, 2006, 05:21 PM
Iflyrc_vic's Avatar
USA
Joined Dec 2004
Laser check
When using a laser level to check wing incidence, you must have a method of stabilizing the lazer position and then get the laser leveled. Mine came with a tripod and leveling bubbles. Your laser must also have a horizontal line function and be able to rotate the horizontal line.
1. Place the plane with the wing tip facing the laser.
2. Set the plane so that the laser beam runs as close as possible along the center of the wing from one side to the other (with straight wings this is near the main spar). I set my laser in the "dot" mode and point the dot at the wing tip nearest the laser. Then just rock the plane left or right until the beam is hitting the far wing tip. Adjust the location of the plane so that the beam hits both wing tips at the same distance from the leading edge.
3. Now switch to the horizontal line function. Line up the laser line on the side of the plane with the line running along the thrust line (axis) of the plane from front to back. This should start at the tip of the spinner and run along the axis to the rear of the plane. Note the angle indication on the laser.
4. Then rotate the level so that the line is running parallel to the wing root (leading edge to trailing edge). Note the angle on the laser.
5. The difference from the first angle to the second is the incidence.
If your laser does not have angular indication then perform the steps listed above. Move the plane out of the way, and shine the horizontal beam on a piece of paper on the wall. First set it to the thrust line - mark the line with a pencil on the paper. Then set the laser to the angle you got from the wing - mark the line with a pencil. Use a protractor to measure the difference between the two lines - that's the incidence!
This same process can be used to check the stabilizer incidence.
This laser method works better than using a level with angular indication because it does not have to "sit" on the wing which is normally curved.
Old Sep 11, 2006, 07:24 AM
electrotor is offline
Find More Posts by electrotor
Bonnie Scotland
Joined Jun 2004
Originally Posted by gwinhh
#2:
Simplicate and add lightness.
howell
Are you sure??
http://www.urbandictionary.com/defin...erm=simplicate
Alternatively you really did mean "simplify" but gained your English degree at the George Bush School of Inventive Speechification.
electrotor is offline Find More Posts by electrotor
Old Sep 11, 2006, 03:08 PM
Mark Miller is offline
Find More Posts by Mark Miller
Mark Miller's Avatar
United States, WI, Waunakee
Joined Oct 2002
When you think you are done sanding you are halfway there.
Mark
Mark Miller is offline Find More Posts by Mark Miller
Old Sep 11, 2006, 03:26 PM
jinithith2 is offline
Find More Posts by jinithith2
Just a sip
jinithith2's Avatar
Hudson, OH
Joined Jul 2006
don't sand in your bedroom (i sand in my bedroom)
jinithith2 is offline Find More Posts by jinithith2
Old Sep 12, 2006, 06:34 AM
the wiz is offline
Find More Posts by the wiz
the wiz's Avatar
Bullhead City Az.
Joined Jun 2006
i truly believe in using a shop vac with the inlet of the hose close to the work when sanding or using power & hand tools for cutting or shaping. i'm lucky enough to have an understanding wife. she let me have her rainbow vac. it's a great shop vac. the water traps all or very nearly all dust and doesn't let much back out into the shop environment.
the wiz is offline Find More Posts by the wiz
Old Sep 14, 2006, 01:39 PM
kfong is offline
Find More Posts by kfong
Sterling Heights, Michigan, United States
Joined Nov 2003
You can get hepa filters for shop vacs now, and the new quiet series sold by Lowes have disposable bags as well. I use this combination when sanding and cutting carbon fibers and anything else.
I've also installed a kitchen hood over one of my workbench and used a drop cloth to close in the area. I've attached a clear plexiglass to the front of the hood and use this for all my epoxy,CA,painting and goop work. It works great, all the fumes are exausted to the outside. It works much like a chemistry labs fume extraction system.
Kin
http://www.embeddedtronics.com/
kfong is offline Find More Posts by kfong
Old Sep 14, 2006, 11:24 PM
Hangup is offline
Find More Posts by Hangup
Practice more "crashing"
Hangup's Avatar
Chandler, AZ
Joined Apr 2006
don't have a celeing fan above your workbench(im still trying to remember mine is above my bench)
Hangup is offline Find More Posts by Hangup
Have you ever done something THIS stupid ? ChrisP Electric Plane Talk 57 May 06, 2015 01:27 PM
Question whats the best single strator cdrom you ever made? thenetpoet Power Systems 8 Oct 27, 2005 02:21 PM
Have you ever "Got a free one" AustinTatious Sailplane Talk 6 Aug 27, 2004 04:38 AM
Sarted building gws p-51. Whats the best tip you have for me? Thanks! liaudio Parkflyers 10 Feb 12, 2003 10:37 PM
August EFI, Which one of you guys got my missing pages Ken Lapointe Electric Plane Talk 14 Aug 01, 2001 12:38 AM
