This thread is privately moderated by the wiz, who may elect to delete unwanted replies.
Old Oct 06, 2011, 08:50 PM
NoFlyZone is offline
Find More Posts by NoFlyZone
Joined Jul 2006
What's a servo eyelet?
NoFlyZone is offline Find More Posts by NoFlyZone
Reply With Quote  (Disabled)
Old Oct 06, 2011, 09:55 PM
Jim.Thompson is offline
Find More Posts by Jim.Thompson
Entropy is happening!
Jim.Thompson's Avatar
Australia, NSW, Bellingen
Joined Aug 2008
Good question, I am wondering too! Maybe its a small eye? If so, the ones I buy don't have one.
Jim.
Jim.Thompson is offline Find More Posts by Jim.Thompson
Legot is offline
Find More Posts by Legot
Build to Fly? FLY to BUILD!
Legot's Avatar
United States, AZ, Gilbert
Joined Nov 2009
It's a little hole where the metal grommet goes, It aides in secure mounting.
They're more common on bigger servos.
Unless I'm mistaken.
Legot is offline Find More Posts by Legot
Old Oct 06, 2011, 11:19 PM
Curare is online now
Find More Posts by Curare
KE your cub.
Curare's Avatar
Australia, WA, Perth
Joined Jun 2005
that sounds like the hard way to me. I just get them started in the gromment and use a pair of broad pliers to push them into place. You don't push the grommet out and the eyelet remains captive the whole time.
I can do this to 4 servos in about 5-10 minutes.
Curare is online now Find More Posts by Curare
Old Oct 07, 2011, 12:53 AM
Little Black Duck is offline
Find More Posts by Little Black Duck
Little Black Duck's Avatar
Thornleigh - 20k N of Sydney,N.S.W.,AUSTRALIA
Joined Aug 2001
Servo grommet eyelet insertion
G'day all,
The small eyelets look a bit like tophats with the top removed, and are similar to those used on Hitec HS82 servos and several other types.
They are designed to prevent crushing the rubber mounting grommets, while still giving vibration damping.
The eyelets should be inserted with the 'hat-brim' on the underside of the grommet to make contact the servo mount, but has to be inserted after the grommet has been fitted on to the servo lug, which is the easy bit, or you won't be able to mount the grommet.
All the above most of you clue-ey blokes would already know.
However on some small servos inserting these eyelets into the grommets can be a real pain in the nether-end, especially into the mounting lug where the servo lead exits the servo case and gets in the way.
Easy fix - Use a sharp kebab stick, cut down to a convenient length. The eyelet is inserted ... don't jam it on tight ... the right way round on the pointy end and then just jab it into the grommet from the underside, giving the kebab stick a bit of a twist to release it from the eyelet which should then stay in the hole in the grommet ... all done.
Having dropped a few of these tiny eyelets on the workshop floor where they'd never be seen again, and ending up with eyelet-less grommets, this solution worked well.
Regards from Oz
Daffy
Little Black Duck is offline Find More Posts by Little Black Duck
Old Oct 07, 2011, 04:25 AM
Dean.roberts is offline
Find More Posts by Dean.roberts
a.k.a. GlideZilla
Dean.roberts's Avatar
Australia, VIC, Macleod
Joined Sep 2003
G'day Daffy.
I'm waiting for the question... "What's a kebab?"
Cheers
Dean
Dean.roberts is offline Find More Posts by Dean.roberts
Old Oct 07, 2011, 10:28 AM
maukabud is offline
Find More Posts by maukabud
HELP I AM BEING SET UP!!
maukabud's Avatar
United States, OR, Deschutes
Joined Jul 2009
Originally Posted by Dean.roberts View Post
G'day Daffy.
Cheers
Dean
As in "throw another kebab on the barbie":
maukabud is offline Find More Posts by maukabud
Old Oct 07, 2011, 10:55 AM
RknRusty is offline
Find More Posts by RknRusty
RknRusty's Avatar
United States, SC, Columbia
Joined May 2010
I use a metal kebab skewer on a string for my CL stooge. Works well... when it doesn't nose over and grind up the prop. Or when I don't wrap my ankles together in the string. That only happened once. I swear. I'm hungry.
RknRusty is offline Find More Posts by RknRusty
Old Oct 07, 2011, 11:10 AM
grosbeak is offline
Find More Posts by grosbeak
Illegitimi non carborundum
grosbeak's Avatar
Canada, ON, Ottawa
Joined Mar 2011
Eyelets:
Eyelets on nail set:
Eyelets into grommets:
grosbeak is offline Find More Posts by grosbeak
Old Oct 07, 2011, 11:49 AM
rcav8r2 is offline
Find More Posts by rcav8r2
rcav8r2's Avatar
United States, PA, Beaver
Joined Sep 2001
Grosbeak... Yep that's they way I do it, but use an old soldering tool. Works GREAT, takes seconds to prep a servo.
Not sure if it was mentioned earlier in the thread (I may have even mentioned it) bit I use bamboo kebab skewers for pins of all sorts. IMO better then dowels as a hardwood dowel will snap, but the bamboo really resists this. Just drill the hole a little undersized, add a dab of glue, and push the pin in. Sands flush really easily.
rcav8r2 is offline Find More Posts by rcav8r2
Old Oct 07, 2011, 01:02 PM
dr.klepp is offline
Find More Posts by dr.klepp
Joined Oct 2008
G'day Daffy.
Cheers
Dean
Where I come from it's more like this:
and it get's served like this:
dr.klepp is offline Find More Posts by dr.klepp
Old Oct 07, 2011, 01:17 PM
Joined Jul 2006
Oh mannnnnnnnnn, I want one of those!
Old Oct 07, 2011, 02:36 PM
maukabud is offline
maukabud's Avatar
Joined Jul 2009
OMG I'm starving! That looks so awesome.
Isn't that lamb? And isn't that a Greek "gyro"?
Dangit Klepp....our only Greek eatery in town went out of business a while ago...now I want a gyro.
Old Oct 07, 2011, 03:21 PM
Joined Jul 2006
I work in Pontiac, Michigan and there are a few small restaurants that serve Greek foods. Gyros are my all time favorite. Geeeeze, they are good!
Old Oct 07, 2011, 03:31 PM
dr.klepp is offline
Joined Oct 2008
Just for all those who've never seen it before ....
Think it's time for lunch
Have you ever done something THIS stupid ? ChrisP Electric Plane Talk 57 May 06, 2015 01:27 PM
Question whats the best single strator cdrom you ever made? thenetpoet Power Systems 8 Oct 27, 2005 02:21 PM
Have you ever "Got a free one" AustinTatious Sailplane Talk 6 Aug 27, 2004 04:38 AM
Sarted building gws p-51. Whats the best tip you have for me? Thanks! liaudio Parkflyers 10 Feb 12, 2003 10:37 PM
August EFI, Which one of you guys got my missing pages Ken Lapointe Electric Plane Talk 14 Aug 01, 2001 12:38 AM
