This thread is privately moderated by the wiz, who may elect to delete unwanted replies.
Old Jan 16, 2011, 04:20 PM
Peteohms is offline
Find More Posts by Peteohms
Peteohms's Avatar
USA, TX, Leander
Joined Jul 2001
Originally Posted by StevenatorLTFO View Post
Always use fresh sandpaper.
Same with toilet paper.
Pete
Couldn't resist!
Peteohms is offline Find More Posts by Peteohms
Old Jan 17, 2011, 12:07 AM
CoolBudz is offline
Find More Posts by CoolBudz
RCPlaye
United States, CT, East Hartford
Joined Aug 2009
Pete
Couldn't resist!
and even when you think you have a no wiper a safety wipe is always necessary
CoolBudz is offline Find More Posts by CoolBudz
Old Jan 17, 2011, 12:30 AM
Jim.Thompson is offline
Find More Posts by Jim.Thompson
Entropy is happening!
Jim.Thompson's Avatar
Australia, NSW, Bellingen
Joined Aug 2008
Originally Posted by mtesa View Post
I forgot that. my left hand finger was in path of a very sharp knife.
Fingertip was cut of in a split second.
7 days off. changing bandages 2 times per day.
Still hurts like hell, I you touch it.
I learned to build boats with a guy 25 years older than me who had been building wooden boats and later steel boats for around 50 years at the time.
The skin on his hands were leathery with scars from many, many cuts like the one described above.
He was adamant about his radical way of treating cuts. He stressed that first of all they should never be washed. Then they should be firmly wrapped with clean cloth or better still, bandage with blood intact etc.
The limb or appendage is to be kept dry for 7 days without changing the bandage.
When the bandage is removed on the 8 th day, it smells of course, but the cut is cleanly healed!
I have tried it (bravely), and it does work. The salient point is to not wash and dirt or foreign matter into the wound. And then to exclude water and oxygen.
Jim,
(Trust me!)
Jim.Thompson is offline Find More Posts by Jim.Thompson
Old Jan 17, 2011, 02:53 AM
discostu956 is offline
Find More Posts by discostu956
Is my CG correct?
discostu956's Avatar
Wollongong, Aus
Joined Sep 2009
I still remember a car salesman saying "trust me" I always had a rule to never trust someone who said that!!
Will give it a go next time I get a bad cut
Were you implying that this method is instead of stitches etc as well?
discostu956 is offline Find More Posts by discostu956
Old Jan 17, 2011, 05:30 AM
Joined Aug 2008
No. However, my old work mate Bob would have!
The "trust me" bit was very much tongue in cheek.
Jim.
Old Jan 17, 2011, 06:02 AM
Is my CG correct?
Wollongong, Aus
Joined Sep 2009
Cheers Jim, will still see the doctor then!!
Old Jan 19, 2011, 05:20 PM
Joined Aug 2008
Originally Posted by maukabud View Post
LOL! Disturbing...but nice to see others are as "plane-crazy" as myself!
Three classics indeed...at Miramar NAS....sweet.
Oh...since this is technically a build tip thread...be careful using the supposed "low tack" green painters tape...I just pulled up a bunch of blue paint I just painstakingly rattlecanned on last night, trying to do black borders on blue stripes on my glider wings. Maybe I just didn't let it dry long enough? Taking care of a 4 year old boy and doing detail paintwork definitely don't mix!!! (It's like herding cats!) :exhausted:
-Bud
On my last paint job I let the paint dry 2 days before masking for painting trim colours. The masking tape still left tape marks in the paint. I will wait at least 4 days next time. I was using the cheap generic masking tape.
Jim.
Old Jan 20, 2011, 12:12 AM
st99 is offline
Find More Posts by st99
st99's Avatar
United States, PA, Uniontown
Joined Jan 2005
The cheap generic type is too sticky. Use the 3M blue masking tape from an auto parts store that sells Automobile paint. You will like it and it will leave a sharp nice paint line when you pull the tape off.
st99
st99 is offline Find More Posts by st99
Old Jan 20, 2011, 01:01 AM
Curare is online now
Find More Posts by Curare
KE your cub.
Curare's Avatar
Australia, WA, Perth
Joined Jun 2005
agreed, Also beware that a lot of the paints you'll encounter in the home-handyman section of your store will take weeks, if not MONTHS to cure, and will show finger marks and the like from premature handling.
Patience or paying more for better paint are the only two known fixes.
Curare is online now Find More Posts by Curare
Old Jan 20, 2011, 06:23 AM
Joined Aug 2008
st99
Ok. I will buy some of the 3M stuff.
Jim.
Last edited by Jim.Thompson; Jan 20, 2011 at 02:24 PM. Reason: correction of error
Old Jan 20, 2011, 06:27 AM
Joined Aug 2008
Yes, I found out by experience that our local brand "Dulux" cured extremely slowly. It would show finger marks after 7 days!
Our "White Knight" brand is ok. Still slow, but better than the above. And cheaper too!
These are both rattle can paints. If I use proper spraying enamel through one of my guns, they do dry much better. But the rattle cans are so convenient for trims etc.
Now I am acustomed to using my airbrush more, I will use it with superior paints rather than a rattle can.
Thanks for comments.
Jim.
Old Jan 20, 2011, 10:41 AM
st99 is offline
st99's Avatar
Joined Jan 2005
Originally Posted by Jimbello View Post
Ok. I will buy some of the 2M stuff.
Jim.
3M stuff
Old Jan 20, 2011, 02:25 PM
Joined Aug 2008
Ooopps!
3M stuff
Oops! Asleep at the wheel again. I've corrected my post.
Thanks.
Old Jan 21, 2011, 02:01 AM
KE your cub.
Curare's Avatar
Joined Jun 2005
Jim.
...and as I found out, they're not particulary fuel proof either. I've gone back to using acrylic laqcuers. It's just nicer.
Old Jan 21, 2011, 03:24 AM
Joined Aug 2008
Yes I am tempted to do so too. I am learning to airbrush and have acquired a set of acrylic lacquer in the primary colours, white, black and some clear. I like using it so much, I think I will use it in my detail gun for all my painting. Clear over the top, and a follow up fine grit wet sand and polish if necessary.
I am planning on a very simple conversion of a small shed I have into a spray booth. That will solve the frustration of witnessing small insects and leaf detritus etc. spoiling an otherwise good spray job.
It simply involves installing an extraction fan in the place of one window and filter/screening one of the others. I can block up around the door with hanging drapes or some such material to sufficiently exclude insects etc.
The biggest job will be giving it a good clean before use!
Jim.
Have you ever done something THIS stupid ? ChrisP Electric Plane Talk 57 May 06, 2015 02:27 PM
Question whats the best single strator cdrom you ever made? thenetpoet Power Systems 8 Oct 27, 2005 03:21 PM
Have you ever "Got a free one" AustinTatious Sailplane Talk 6 Aug 27, 2004 05:38 AM
Sarted building gws p-51. Whats the best tip you have for me? Thanks! liaudio Parkflyers 10 Feb 12, 2003 11:37 PM
August EFI, Which one of you guys got my missing pages Ken Lapointe Electric Plane Talk 14 Aug 01, 2001 01:38 AM
