This thread is privately moderated by the wiz, who may elect to delete unwanted replies.
Old Mar 29, 2007, 06:02 AM
ultralajt is offline
Find More Posts by ultralajt
ultralajt's Avatar
Ljubljana Brnik, Slovenia
Joined Sep 2004
If you don`t know how, then DON`T!!
ultralajt is offline Find More Posts by ultralajt
Old Mar 29, 2007, 11:46 AM
Soar-on is offline
Find More Posts by Soar-on
Soar-on's Avatar
Marysville, WA
Joined Feb 2006
This isn't the best tip - many of the others in this thread are far more useful.
But, since I didn't see it posted:
When you need to level out the foam in the bottom of a servo well, use one of the wire brush attachments for your dremel router. It'll "whisk" away just the foam you need to remove in a hurry.
Soar-on is offline Find More Posts by Soar-on
Old Mar 29, 2007, 03:37 PM
RCTyp is offline
Find More Posts by RCTyp
Smashes Things
RCTyp's Avatar
Montpelier, VA
Joined Feb 2005
I bet that person went far in life
Typ
RCTyp is offline Find More Posts by RCTyp
Old Mar 29, 2007, 04:47 PM
datafry is offline
Find More Posts by datafry
Rookie Builder
Joined Feb 2007
Then experiment with something you can afford to lose then something you can't.
datafry is offline Find More Posts by datafry
Old Mar 29, 2007, 05:33 PM
PaulVi is offline
Find More Posts by PaulVi
resU deretsigeR
PaulVi's Avatar
Dublin Ca
Joined Aug 2004
Always take the wife to lunch before that new airplane shows up un the porch. She will be less willing to chase you down if she is full..
Dinner and Dancing is good for when you make those large Lipo buys...
Basicly you should spend at least as much on lunch or dinner as your parts order costs that way you can always say it cost less than the meal we just had..
PaulVi is offline Find More Posts by PaulVi
Old Mar 29, 2007, 07:08 PM
tailskid2 is offline
Find More Posts by tailskid2
tailskid2's Avatar
USA, AZ, Phoenix
Joined May 2003
PaulVi, those are words of wisdom!!!!
tailskid2 is offline Find More Posts by tailskid2
Latest blog entry: VQ 112" Beaver
Old Mar 29, 2007, 08:41 PM
Pete H is offline
Find More Posts by Pete H
I'm just a CAD at heart
Perth, Australia
Joined Mar 2003
Hi Guys,
First time I've read this thread and many wise words (and much humour).
One of the best tips I ever had was cut slightly over size and sand down to correct. Much better than trying to cut to the line.
Also, always change to old clothes, even if it is 'just for five minutes before ..' - the glue only spills on the suit! (don't ask)
Pete H
Pete H is offline Find More Posts by Pete H
Old Apr 13, 2007, 03:30 PM
althomas101 is offline
Find More Posts by althomas101
Woodbine, MD
Joined Aug 2006
Always carry your plane tail first otherwise when you leave the house you might leave the tail behind.
As for a building board I use a level glass table with 1 1/2 inch pink foam board for the T pins. The glass is impervious to all glues just scrape off with a razor blade, and the foam is rigid, flat, and makes a good wing core or fuselage in a pinch.
I agree that a torch and music wire make an excellent drill bit, just practice first on scrap because it melts through balsa like it is butter. I always use this method for mounting control horns glue the horn in place with CA, music wire drill the screw holes and mount the backer plate. It works better than marking the holes and drilling the control surface then hope you made them straight otherwise the backer won't go on with out rounding the holes out.
Never use EZ connectors for anything other than Throttle! Ask me how I know.
althomas101 is offline Find More Posts by althomas101
Old Apr 16, 2007, 08:18 AM
customcarmaker is offline
Find More Posts by customcarmaker
I have two speeds fast and WFO
customcarmaker's Avatar
United States, IN, Vincennes
Joined Jul 2006
Originally Posted by CAFplanekid
Build to fly, not to crash.
When inverted, down is up, and up is expensive.
This is all too true. It is also very hilarious.
customcarmaker is offline Find More Posts by customcarmaker
Old Apr 21, 2007, 07:13 PM
scottoty is offline
Find More Posts by scottoty
Joined Mar 2006
light weight spackling
light weight spackling local hardware store, fills nail hole sheet rock repair.
the container is not empty, just light
I have used it for a while. Works on balsa gaps, and really well to fill the holes on EPP foam .
poor mans ballast your kids clay!!!
scottoty is offline Find More Posts by scottoty
Old Apr 25, 2007, 01:16 AM
Joined Jul 2006
Here's one i have learned the hard way or messy way. If you dip or chew tobacco spit into a pop bottle not an open cup. If you knock over the bottle no big deal but if you knock over the cup.... you get the idea. Here's another good tip. When scratch building make a small profile version and do test glides to see if the plane will even fly.
Old May 10, 2007, 06:28 AM
Smokin' Beaver is offline
Find More Posts by Smokin' Beaver
Registerd Beaver
Smokin' Beaver's Avatar
Australia, WA, Warwick
Joined Jul 2003
Covering Balsa sheet
Recently had a good experience covering balsa sheeting with tissue paper applied with 50/50 PVA/Water.
Little mess, cheap materials - no power tools, no stinky chemicals, water clean up. (A wife & family friendly job)
Same technique as the brown paper/foam, you can massage it with your finger around the most difficult compound curves.
Takes acrylic or enamel paints really well , also dopes & resins.
You can sand out mistakes (can't do that with Solite)
great stuff.
Smokin' Beaver is offline Find More Posts by Smokin' Beaver
Old May 13, 2007, 02:50 AM
dpot is online now
Find More Posts by dpot
dpot's Avatar
France, Auvergne, Lapalisse
Joined Dec 2005
for perfect joints
123
dpot is online now Find More Posts by dpot
Old May 13, 2007, 04:54 PM
Vegas_flyer is offline
Find More Posts by Vegas_flyer
Vegas_flyer's Avatar
Joined Aug 2006
nice tip
Vegas_flyer is offline Find More Posts by Vegas_flyer
Old May 30, 2007, 05:28 PM
Chrono is offline
Find More Posts by Chrono
aeronautic freak
Chrono's Avatar
Lima, Perú
Joined Mar 2007
How 'bout:
1) Look where you put your fingers.
2) Sheathe your knife before leaving it on the table.
3) Always unplug the soldering iron.
4) Keep things simple (mostly used on design).
Chrono is offline Find More Posts by Chrono
Have you ever done something THIS stupid ? ChrisP Electric Plane Talk 57 May 06, 2015 01:27 PM
Question whats the best single strator cdrom you ever made? thenetpoet Power Systems 8 Oct 27, 2005 02:21 PM
Have you ever "Got a free one" AustinTatious Sailplane Talk 6 Aug 27, 2004 04:38 AM
Sarted building gws p-51. Whats the best tip you have for me? Thanks! liaudio Parkflyers 10 Feb 12, 2003 10:37 PM
August EFI, Which one of you guys got my missing pages Ken Lapointe Electric Plane Talk 14 Aug 01, 2001 12:38 AM
