This thread is privately moderated by the wiz, who may elect to delete unwanted replies.
Old Dec 26, 2006, 08:05 AM
Murocflyer is offline
Find More Posts by Murocflyer
Promoting Model Aviation...
Murocflyer's Avatar
United States, CA, Tehachapi
Joined Nov 2005
Snake Bends in lieu of Z-bends.
Frank
Murocflyer is offline Find More Posts by Murocflyer
Old Dec 28, 2006, 08:07 PM
artsmith is offline
Find More Posts by artsmith
Dunedin, New Zealand
Joined Dec 2006
building-boards
A reply to GWSLAWNDART regarding the 'ideal' building-board. Obtain some warp-free 'base' material and glue a matrix of cork floor-tiles to it. When the tile-cement has dried, use an orbital-sander to take off any high-spots. Varnish or not, at your discretion. This thickness of cork-tiles holds all gauges of pins really well, even the very thin 'dressmakers' variety (eg 'glass-headed'). If the backing is somewhat harder plywood or similar, the pin-points may be trapped in that. I have used a similar board to this for years. it's inherently self-healing and in the event of a 'ding', say while drilling, the faulty spot is easily able to be removed by a piece of sharpened brass tube.
Cut an identical 'replacement' part from an undamaged tile using the same cutter, sand off any high-spots after gluing-in, and you are back in business. If you want something which really 'holds' pins, go for the largest obtainable size of chef's LDPE cutting-board. This holds pins 'like there's no tomorrow' and is ideal for those laminating-jobs which really place stress on the pins.
'artsmith'
artsmith is offline Find More Posts by artsmith
Last edited by artsmith; Dec 28, 2006 at 08:10 PM. Reason: bad spacing on original copy
Old Jan 03, 2007, 07:38 PM
xtian999 is offline
Find More Posts by xtian999
NeveroddoreveN
Joined Oct 2006
This is from Jeff Raskin: Since Legos blocks are made to very high tolerances, precision jigs can be made with them. Good for marking, cutting, gluing, whatever.
xtian999 is offline Find More Posts by xtian999
Old Jan 03, 2007, 07:44 PM
xtian999 is offline
NeveroddoreveN
Joined Oct 2006
I picked this up on working construction: Better than band-aid for cut is ca. just clean wound, squirt into cut and hold closed. Great for minor cuts.
Old Jan 11, 2007, 11:27 PM
sloperb is offline
Find More Posts by sloperb
Auburn, WA
Joined Nov 2005
This is a flying tip, not a building tip, but a long-time glider flyer helped me fly a glider the first time and his advice was:
Make sure you're three mistakes high before you try something new or risky.
sloperb is offline Find More Posts by sloperb
Old Jan 12, 2007, 05:54 AM
rwright142 is offline
Find More Posts by rwright142
Building a Corsair
rwright142's Avatar
Indianapolis, IN
Joined Jan 2006
I don't know if CA is the same as SuperGlue, but if so then you are spot on. SuperGlue was used in Vietnam for wounds.
rwright142 is offline Find More Posts by rwright142
Old Jan 12, 2007, 07:03 AM
thomanie is offline
Find More Posts by thomanie
thomanie's Avatar
Trondheim, Norway
Joined Jun 2003
Simple and effective fin alignment
Originally Posted by lammy1000
I always get worried about aligning the vert and hor stabs, wings etc. Any best building tips there?
Best tip for aligning the fin I ever got was to use a piece of string from a T-pin at the firewall, looped around the fin, and back up to the firewall again. Very slight adjustments will easily show if the fin is straight or not.
I've used it many times, and it is dead simple and extremely effective.
Use it with Jims squaring process for fin to stab alignment and you'll have a winner every time!
Here's a picture of the process from one of my builds.
Thomas
thomanie is offline Find More Posts by thomanie
Old Jan 12, 2007, 10:59 PM
Darth_Z is offline
Find More Posts by Darth_Z
Cartwheels = A New Plane
Darth_Z's Avatar
Mediapolis, IA
Joined Feb 2006
Sand lightly and slowly. Checking ever few strokes.
Darth_Z is offline Find More Posts by Darth_Z
Old Jan 13, 2007, 09:41 AM
sa-woody is offline
Find More Posts by sa-woody
X - USAF X - FAA
Santa Ana, CA
Joined Dec 2004
When measuring covering covering material use a straight pin (leave it in the material) in lieu of a pencil or a pen. Align the straight edge with the pins and you will have the perfect cut every time.
I have kept CA and Epoxy in the freezer for very long periods of time with no adverse affects. I have used Pacer CA that was 8 years old in several models. I am currently using epoxy that I have kept in the freezer for 11 years.
sa-woody is offline Find More Posts by sa-woody
Old Jan 13, 2007, 07:13 PM
xtian999 is offline
NeveroddoreveN
Joined Oct 2006
Once I picked up a metal splinter in my eye from riding a motorcycle w/o eye protection. Here's how the eye Doctor got it out without touching my eye: He placed a very strong magnet close to my eye and it came right out! I'll bet this works on fingertips too.
Old Jan 13, 2007, 07:17 PM
xtian999 is offline
NeveroddoreveN
Joined Oct 2006
I know of a way to remove almost any kind of glue or paint from blue jeans: Mix Goof Off and Shout 50/50 and rub in then wash. It works miracles.
Old Jan 13, 2007, 07:20 PM
xtian999 is offline
NeveroddoreveN
Joined Oct 2006
Some people store batteries, glue, film, etc. in the refrigerator. Here's a simple tip: Put them in a ziplock bag before you put them in and leave them in the bag for a while after you pull them out and you won't have to worry about condensation ruining them.
Old Jan 13, 2007, 07:24 PM
xtian999 is offline
NeveroddoreveN
Joined Oct 2006
Here's a new one I just discovered: When joining two sheets of material with ca, use a small spray bottle. The ca will go on much more evenly and free from excess drips.
Old Jan 13, 2007, 09:03 PM
Smooth Spanky is offline
Find More Posts by Smooth Spanky
Hack of all trades...
Smooth Spanky's Avatar
Detroit, Michigan
There was an earlier thread on this forum about a twist to this. In addition to storing in the firdge, people have suggested puting CA glue inside a plastic container partially filled with silica gel. It's supposed to keep glue good for LONG periods of time.
Smooth
Smooth Spanky is offline Find More Posts by Smooth Spanky
Old Jan 15, 2007, 07:27 AM
PurpleHaze is offline
Find More Posts by PurpleHaze
The Clogg Master
Joined Dec 2006
Don't try this if you have any vietnam war left overs stuck in your brains
PurpleHaze is offline Find More Posts by PurpleHaze
Have you ever done something THIS stupid ? ChrisP Electric Plane Talk 57 May 06, 2015 01:27 PM
Question whats the best single strator cdrom you ever made? thenetpoet Power Systems 8 Oct 27, 2005 02:21 PM
Have you ever "Got a free one" AustinTatious Sailplane Talk 6 Aug 27, 2004 04:38 AM
Sarted building gws p-51. Whats the best tip you have for me? Thanks! liaudio Parkflyers 10 Feb 12, 2003 10:37 PM
August EFI, Which one of you guys got my missing pages Ken Lapointe Electric Plane Talk 14 Aug 01, 2001 12:38 AM
