Old Jul 13, 2006, 08:04 PM
rotccapt is offline
Find More Posts by rotccapt
that tree ate my plane
rotccapt's Avatar
oklahoma city oklahoma
Joined Apr 2004
half gallon of bad fuel???
i have a what used to be a gallon of omega 15 that has gone bad on me and i was wondering if there was any way to usethe remainder of fuel. it will not run in my magnum 61. will it run in my os 20? or do i have a half gallon of weed killer?
rotccapt is offline Find More Posts by rotccapt
Old Jul 13, 2006, 08:15 PM
ctdahle is offline
Find More Posts by ctdahle
Flying RC since 1974
Del Norte, Colorado
Joined Dec 2002
What is "bad" about it? If it was a gallon and has reduced itself to 1/2 a gallon by evaporation, you have weed killer. The methanol and nitromethane are mostly gone, and there is really no point in trying to ressurect it.
If it has lots of little white floaty specks in it, the castor oil has turned rancid, but it will still work ok for sport flying as long as you don't try to filter it. The rancid oil will more or less liquify when it gets into the hot engine. Keep your motor a bit rich, your exhaust will just be really stinky.
Weed killer would probably be the best application though.
ctdahle is offline Find More Posts by ctdahle
Old Jul 13, 2006, 08:34 PM
rotccapt is offline
rotccapt's Avatar
Joined Apr 2004
i have used half of the fuel and now it has sat for about a year and now it wil not sustain full throttle for more than 2 minets or so. and there are no white bubbles.
Old Jul 14, 2006, 06:39 AM
Robert Bauer is offline
Find More Posts by Robert Bauer
Dushore Pa. & Arcadia Fl.
Joined Jun 2002
I have used fuel that was stored (NOTE stored means : sealed in a cool place) for many years.( over 5 ) without any loss of performance that I could detect. If it was left open in the hot garage, throw it out.
Robert Bauer is offline Find More Posts by Robert Bauer
Old Jul 14, 2006, 07:00 AM
ctdahle is offline
Del Norte, Colorado
Joined Dec 2002
I agree with Robert. If you had it stored with the lid on, it should be fine. I suspect you have a tuning problem. I've been worse than Robert, I bought a gallon in 1983 (for $7.00!) used half and then left the bottle in my dad's furnace room until 1998. It still worked fine.
Old Jul 14, 2006, 02:59 PM
spitfire123 is offline
Find More Posts by spitfire123
jimi hendrix
Joined Apr 2006
give the fuel a good shake and try again
spitfire123 is offline Find More Posts by spitfire123
Old Jul 14, 2006, 05:00 PM
rotccapt is offline
rotccapt's Avatar
Joined Apr 2004
thanks it was stored in a hot garage. it worked for the first few fligts but now it doesent i will try shaking it up.
Old Sep 04, 2007, 07:55 AM
jorgeron is offline
Find More Posts by jorgeron
Joined Apr 2004
bad Orion fuel
changed to a new unopened gallon of Orion 10% and engine performance went from great to unuseable. problem is with the fuel. tried a buddys fuel ( Orion also) and problem completely disappeared.
jorgeron is offline Find More Posts by jorgeron
Old Sep 04, 2007, 12:27 PM
gwinhh is offline
Find More Posts by gwinhh
Beaumont tx
Richen it up a bit. the flecks may be cloggin the ventura.
howell
gwinhh is offline Find More Posts by gwinhh
Question Bad fuel? MattBred Engines 8 Jun 18, 2006 04:44 PM
Running half throttle: Is it bad? 2Sunny Beginner Training Area (Aircraft-Electric) 16 Nov 24, 2005 03:27 AM
If you think $3.00 a gallon is bad..... lakedude Life, The Universe, and Politics 82 Sep 02, 2005 03:04 PM
