Old Jul 13, 2006, 07:51 PM
cart213 is offline
Find More Posts by cart213
Joined May 2006
A123 is introducing li-ion battery packs for R/C
http://forums.radiocontrolzone.com/s...d.php?t=222362
Check it out! This looks to be very promising. Dave, are you going to be selling these???
cart213 is offline Find More Posts by cart213
Old Jul 13, 2006, 08:18 PM
ormandj is offline
Find More Posts by ormandj
Über Geek
Kaneohe, Hawaii
Joined Feb 2006
Wow. If all those claims are true, and I can somehow slam one of those into my Rex (I'd even buy a Rex 600 if those batteries aren't absurdly priced) I'll be buying dozens. 15 minute charge time?? Whoa. Can any of this stuff be verified? If cells like this exist, I have no idea why laptops are still using the crap batteries they use, with the hours of charging, etc. Electric cars could even become a realistic endeavour!
ormandj is offline Find More Posts by ormandj
Old Jul 13, 2006, 08:47 PM
Microbatman is offline
Find More Posts by Microbatman
Microbatman's Avatar
United States, TX, Argyle
Joined Jan 2005
265 Grams for 2300 Mah
At least they are using the word "brick" in their marketing
Maybe a good aplication in the Ground and Water market
But I do not think that nearly double the weight of todays 20C's is a good trade to get to a 30C continious rating.
Maybe the chemistry is better.
Would be curious to see how they would compare in similar containers.
Microbatman is offline Find More Posts by Microbatman
Old Jul 13, 2006, 10:42 PM
65535 is offline
Find More Posts by 65535
"Fix it till it's Broken"
Irvine, CA
Joined Jun 2006
The reason others aren't using them is because companies look for cells they can mold into certain shapes round cells aren't very good for them. When A123 does flat cells and otherwise then they can. BTW lower charge rates help the poor little LT batteries.
65535 is offline Find More Posts by 65535
Old Jul 13, 2006, 10:55 PM
rpage53 is offline
Find More Posts by rpage53
Boffin
rpage53's Avatar
Victoria, BC, Canada
Joined Apr 2001
They are lithium ion phosphate cells which are much safer. They can be overcharged without fire (unlike lithium ion cobalt LiPo) and aren't destroyed by discharging too low. They should also last many times longer than LiPo, but we don't have any real world tests yet.
For weight, they are better than NiMH.
Rick.
rpage53 is offline Find More Posts by rpage53
Old Jul 13, 2006, 11:18 PM
waterdog49 is offline
Find More Posts by waterdog49
HammerHead H2o Racing
Deltona, Florida
Joined Jun 2006
good for ground and water
we've been testing them in r/c boat applications for a couple months now and are very impressed with the Li-Ion M1 cells from a123...
we can run in [parallel packs] at less weight than equal voltage sub-c's in series...
we've been get'n an honest 4200 mAh of run time and in side by side tests done things with these cells that would have vented/cooked equal voltage sub-c's...
i'm not a flyer so can't comment to that end...
but as r/c boaters we see these cells as superior in a number of areas than the current crop of NiMh 1.2v sub-c cells we've been using..
Ron
waterdog49 is offline Find More Posts by waterdog49
Old Jul 14, 2006, 02:19 PM
bradpaul is offline
Find More Posts by bradpaul
USA, FL, Apopka
Joined Dec 2000
Anybody have an idea of how effective the idea of using a transformer (Hypersonic Turbo) to step up the voltage will be? The weight penality seems to be 35 grams?
Just how effecient and able to react to variable power loads would that be?
Brad
bradpaul is offline Find More Posts by bradpaul
Reply With Quote  (Disabled)
Old Jul 14, 2006, 07:00 PM
arx_n_sparx is offline
Find More Posts by arx_n_sparx
Dismembered Member...
arx_n_sparx's Avatar
Niagara Falls/Toronto area
Joined Dec 2003
Brad
Brad: Effective? No way! There's no way that you can pump serious current through a DC/DC step up - not at 35 grams, anyways. If you want to bump up the voltage, add cells to the pack.
the *other* Brad
arx_n_sparx is offline Find More Posts by arx_n_sparx
Old Jul 14, 2006, 07:03 PM
65535 is offline
Irvine, CA
Joined Jun 2006
Just buy more cells. It will require less current anyways.
Old Jul 14, 2006, 07:39 PM
bradpaul is offline
USA, FL, Apopka
Joined Dec 2000
That's what I thought...... wonder why a123 decided to offer that capability? Perhaps they are overly concerned with the 3.6v per cell compared to 4.2v per cell with Lipo.
Brad
Old Jul 14, 2006, 08:16 PM
Joined Dec 2003
Brad: Do you have a link to that "Hypersonic Turbo"?
Old Jul 14, 2006, 09:46 PM
cadmonkey is offline
Find More Posts by cadmonkey
Rank Amateur
cadmonkey's Avatar
Maumee, Ohio
Joined Sep 2005
It's in post #2 of the link in post #1 here. Say that 5 times fast...
cadmonkey is offline Find More Posts by cadmonkey
Old Jul 14, 2006, 10:55 PM
65535 is offline
Irvine, CA
Joined Jun 2006
with 30.5C continuus discharge and 15 minute charge they would be great for flash bulbs in cameras. The problem I see is the useless nexx of such high discharge rates as I see it the more C you use the less runtime you have sure it raises the cieling but honestly don't buy higher C if you can get higher Capacity.
Old Jul 14, 2006, 11:39 PM
m2energysolution is offline
Find More Posts by m2energysolution
Dearborn, MI
Joined Apr 2006
Cart213,
Good info. This is great! More choices for modelers!
I can't really say what have planned yet...it is not from A123... (Who knows... what I have planned might be a flop and burn a hole in the o'wallet ... One can not really tell at this stage...)
Dave
m2energysolution is offline Find More Posts by m2energysolution
Old Jul 15, 2006, 05:09 PM
rpage53 is offline
Boffin
rpage53's Avatar
Joined Apr 2001
Right idea, but they want to tailor the voltage to match NiMH packs for car and boat racers. They have spent a fair bit of time getting the right motor and prop and don't want to start again with a new set of voltages.
The transformer is not a useful accessory for fliers.
Rick.
Discussion Manufacture battery pack for R/C toy xxdong5211 Australia 0 Jul 25, 2006 04:42 AM
ESC for 7.4V Li-ion battery hty Batteries and Chargers 1 Apr 26, 2004 02:31 AM
Question Current/ Amp Measurement for R/C Battery Packs Benster Parkflyers 2 Oct 06, 2003 05:04 AM
For Sale: Wingo Plane and Qualcomm Li-Ion battery hitechguy2000 Aircraft - Electric - Airplanes (FS/W) 10 Sep 25, 2003 01:17 PM
Rechargeable Alkaline batteries good for R/C packs??? TopGun Power Systems 2 Sep 27, 2001 11:03 PM
