Old Jul 11, 2006, 05:38 AM
NEWBIEHELI is offline
Find More Posts by NEWBIEHELI
cumberland, RI
Joined Jan 2005
will this work as a power suppy for a hot wire foam cutter
I have a regulated power supply
120vAC input, 13vDC output, rated for 10A
if I wire a ceiling fan speed controler to a receptacle
and plug in the power supply and use the speed controler
to control the input to the power supply
then wire the output of the power supply to my cutting wire
this should control the temp. of the cutting wire
has anyone tried this?
will it work?
NEWBIEHELI is offline Find More Posts by NEWBIEHELI
Old Jul 11, 2006, 07:22 PM
arx_n_sparx is offline
Find More Posts by arx_n_sparx
Dismembered Member...
arx_n_sparx's Avatar
Niagara Falls/Toronto area
Joined Dec 2003
There are much simpler ways of doing this. The ceiling fan speed control is a good start - all you'd need then is a 120/24V transformer good for 4 amps or so. Try this: http://www.allelectronics.com/cgi-bi..._4_AMPS_.html#
The hook up is pretty simple.
Brad
arx_n_sparx is offline Find More Posts by arx_n_sparx
Old Jul 12, 2006, 06:32 AM
Gene Bond is offline
Find More Posts by Gene Bond
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
If the power supply is regulated, it will fight your attempt to lower the ouput voltage by lowering the input... If it's switch-mode, some fireworks could result... or silent death. The dumb transformers and/or simple battery chargers are a better choice.
Gene Bond is offline Find More Posts by Gene Bond
Old Jul 12, 2006, 06:39 AM
cumberland, RI
Joined Jan 2005
Thanks Brad and Gene
I think I will buy a transformer and wire it up the way Brad shows it.
Thanks for the help
Old Jul 13, 2006, 01:43 PM
Arthur P. is offline
Find More Posts by Arthur P.
Hoofddorp, Netherlands
Joined Sep 2004
I use a big transformer based 12V lab power supply with a simple halogen lamp dimmer and volt-meter built into the same casing. Works fine.
Arthur P. is offline Find More Posts by Arthur P.
Old Jul 13, 2006, 05:58 PM
Joined Dec 2003
12 volts won't get you far - if you are looking for a long bow. I'd guesstimate a max of 36 inches. My long bow is about 56 inches. I have a shorter one and a "scroll saw" vertical wire table as well.
It's the current that does the work. The voltage is the "pressure" to push the current thru the wire.
The other thing that will throw things off is the type of wire you use. NiChrome has higher resistance than stainless steel - you might end up shorter than 36" if you use NiCr. Stainless steel - either solid or stranded - is best IMO. It can take much more tension as well. Recommended size is .015 to .020 inch. Try here:
http://www.cabelas.com/cabelas/en/te...equestid=49376
Brad
Brad
Old Jul 13, 2006, 09:32 PM
BlazerB52 is offline
Find More Posts by BlazerB52
BlazerB52's Avatar
Fenton,MO USA
Joined Aug 2005
I've been using this setup for cutter below.
I use car battery charger(6v 2amp for bow cutter below) plugged into router speed controller.
Both were bought on sale at harbourfreight.com
Want to try a bow setup for wing cores to see if unit will handle length.
Does anybody have input if he can use this setup if he goes to 12v 6amp on charger setting and control heat with speed controller.
Guess this question is also for my benefit too.
BlazerB52 is offline Find More Posts by BlazerB52
Old Jul 14, 2006, 01:22 AM
tobiasp is offline
Find More Posts by tobiasp
Sydney, Australia
Joined Aug 2004
Foam Cutter supply
Try looking at http://www.willingtons.com/mymac/mmacphome.htm ther is a good design for controling the cutter wire current, it worked fine for me.
TP
tobiasp is offline Find More Posts by tobiasp
Will this work as a power supply? cat5 Batteries and Chargers 6 Nov 19, 2005 12:40 PM
Batt charger as power/thermal source for hot wire foam wing cutting bow? - UK Steve Wrona Foamies (Kits) 3 Feb 29, 2004 03:07 PM
Will this work as power supply? jhas Batteries and Chargers 2 Sep 06, 2003 08:06 PM
Cheap power supply for hot wire cutter ferradas Hand Launch 23 Feb 04, 2003 07:25 PM
Will this work as a slow charger to condition Nimh packs??? flipnidaho Batteries and Chargers 4 Jan 25, 2003 03:10 PM
