Old Mar 07, 2009, 03:56 PM
Truglodite is offline
Find More Posts by Truglodite
Registered Aircraft Offender
Truglodite's Avatar
Carmichael, CA
Joined Feb 2007
Originally Posted by erozion
Is it necessary to add carbon rods to stiffen the wing? if so which thickness and where?
What motor/batt combo are you planning on using?
The Swift I built for my buddy uses a relatively efficient and lightweight 180W setup, which I figured would flex quite a bit at WOT without reinforcements. Probably wouldn't be my first choice in power setups, but I had to make it work well, so I used reinforcements; an 11" long 1/8" tube across the root, 3/16" wide strips down the chord line, and Henrys/3m90 at the root to tie the chord spars together and stiffen the motor area. This brought the AUW to 10.7oz. I estimate I added 1oz with all the tape/fg/spars, but if I didn't reinforce I'm pretty sure the pilot would notice the effects of wing flex during harder turns, which would more so damper the fun IMO. (FWIW, I prefer pattern style flying)
On the other hand if I was given a 100W "floater" setup, I would've not used anything but a 1/2" tape strip down the LE for longevity, which would bring AUW to the 8oz range. With that kind of power and weight you just don't have enough loading to produce noticeable flex, so reinforcements are unnecessary. Also, with minimal excess power, extra weight is more noticeable to the pilot.
I'm no definitive expert on Swift's, but I know there are several better designs for a fast wing. Most ppl view the Swift as a wing that is best kept slow and light. That's why you see so many 100W ish setups without reinforcements.
Hope this helps you decide which way to go.
Kev
Truglodite is offline Find More Posts by Truglodite
Old Mar 07, 2009, 04:09 PM
GFBurke is offline
Find More Posts by GFBurke
allthingsthatfly.com
GFBurke's Avatar
USA, ID, Meridian
Joined Jan 2007
I'm @ 166w. No added spar.
Just a little reinforced tape on the LE of the wing.
GFBurke is offline Find More Posts by GFBurke
Old Mar 07, 2009, 04:29 PM
Truglodite's Avatar
Carmichael, CA
Joined Feb 2007
Hehe, I guess a better answer would have been: "No"
BTW, what setup are you using GFBurke, AUW?
Kev
[edit: FWIW, I'm getting about 16oz static thrust. I added detailed motor info to my original post. link]
Old Mar 07, 2009, 04:38 PM
GFBurke is offline
GFBurke's Avatar
USA, ID, Meridian
Joined Jan 2007
Well, I have yet to maiden too.. soo....
14.6A @166w with 8x4 GWS HD prop
308g RTF (with lipo)
Review is about done.
Old Mar 08, 2009, 03:01 AM
erozion is offline
Find More Posts by erozion
Australia, WA, Perth
Joined Feb 2009
im using a dual sky 1300 3s SL battery and a dualsky 2830ca 1450kv motor with 8x6 prop? it flies fine now but i can see alot of flex.
erozion is offline Find More Posts by erozion
Old Mar 08, 2009, 03:05 AM
GFBurke is offline
GFBurke's Avatar
USA, ID, Meridian
Joined Jan 2007
YIkes, that's pulling some As!
Mine is only a 1200KV, and I tested with an 8x6 prop:
18A @ 204w with 8x6 GWS HD prop
But only have a 15A ESC, so I bumped the prop down.
Old Mar 08, 2009, 03:08 AM
erozion is offline
Joined Feb 2009
it goes like a little rocket but just worried when the wind picks up i can see alot of flex in the wings. i have a 25amp esc
Old Mar 08, 2009, 07:55 PM
smokejohnson is offline
Find More Posts by smokejohnson
3D wannabe
smokejohnson's Avatar
USA, OK, Tulsa
Joined Nov 2006
Woohoooo!!! I love the Swift Man does that thing fly good. I'm not sure on my flight time yet but it is on video so when my buddy downloads it tonight we will see how long it was...it felt like around 10 minutes. Not unlimited vertical but more than enough to put a big ol' smile on my face . I'll provide a link to the video later.
smokejohnson is offline Find More Posts by smokejohnson
Old Mar 08, 2009, 07:56 PM
GFBurke is offline
GFBurke's Avatar
USA, ID, Meridian
Joined Jan 2007
Nice.
We sooo where about to toss the SII up. Had it in hand, HD cam rolling. BAM snow and hard wind.. wth..
Old Mar 09, 2009, 06:19 PM
3D wannabe
USA, OK, Tulsa
Joined Nov 2006
My flight time was not near as long as I thought...looks like it was around 6 minutes. I did spend most of the time at 3/4+ throttle but...I think I will lose the 4 quarters (almost an ounce) of dead weight in the nose and go with a larger pack.
James' Swift Maiden (6 min 52 sec)
Old Mar 09, 2009, 08:25 PM
More Trim is offline
Find More Posts by More Trim
More Trim
More Trim's Avatar
Raleigh NC
Joined Jan 2007
Did well. Good flying.
More Trim is offline Find More Posts by More Trim
Old Mar 10, 2009, 06:58 AM
3D wannabe
USA, OK, Tulsa
Joined Nov 2006
Thanks MT
Old Mar 10, 2009, 09:39 PM
twister782 is offline
Find More Posts by twister782
twister782's Avatar
Akron, Ohio
Joined May 2008
http://www.youtube.com/watch?v=u4toCV0kZTA
Smoke!!!! Way to go great flying!! nice job for a maiden. Gotta say that has to rank in the top 5 swift cameraman jobs I have seen. He follows the plane smooth and zooms in and out. great filming.
twister782 is offline Find More Posts by twister782
Old Mar 10, 2009, 09:48 PM
Diggs is offline
Find More Posts by Diggs
Not your average DiggsyBear
Diggs's Avatar
Raleigh, NC
Joined Dec 2006
Great maiden flight! How did you like it? Try some nice low and slow flybys once you get comfy with her and be amazed at how nice and slow it can fly.
Diggs
Diggs is offline Find More Posts by Diggs
Old Mar 10, 2009, 09:54 PM
donaldrtaylor is offline
Find More Posts by donaldrtaylor
Austin, TX, 78746
Joined Nov 2008
maiden flight of my new swift II
I am very new to rc. Have had a couple of easystars that have seen better days. I am not an experienced pilot. Mostly crash and rebuild even with the easystar which is supposed to be the best beginner plane. I have had poor results.
I built this little swift II about a week ago but its been windy ever since.
Took it out today and could not believe how easy it was to fly!!
It may not be a starter plane but when it is set up right it flys so easy and stable. It was truly a thrill. I'm sold.
donaldrtaylor is offline Find More Posts by donaldrtaylor
Discussion Good setup for a MSComposit Swift II ? myrslakt Foamies (Kits) 4 Oct 10, 2009 03:30 PM
Video Swift II Maiden Sim69 Electric Plane Talk 3 Jan 28, 2007 12:32 AM
Sold Swift II Airbrush line British Scheme Twinkletoze Aircraft - Electric - Airplanes (FS/W) 0 Jan 05, 2007 11:58 PM
Discussion Swift II from MS Composit? db1 Flying Wings 14 Dec 11, 2006 08:13 PM
Discussion My Swift II + Question highboy Flying Wings 2 Nov 29, 2006 12:05 PM
