Old Mar 01, 2009, 02:51 PM
TyFlies is online now
Find More Posts by TyFlies
And Repairs
TyFlies's Avatar
Grapevine, TX
Joined Jan 2009
Twister,
Post the question in the Batteries and Chargers formum and you'll get more charger opinions than you can shake a stick at. My guess is they'll say that you should step up to the $70 range as a minimum. The Parkzone balancing charger for $29.00 is pretty good considering that it does have a balancing lead. Model PKZ1040. But it's DC (cigarette lighter plug) , slow, and no read-out. I recently upgraded to the Triton EQ, but it's in the $120 range. Good luck.
TyFlies is online now Find More Posts by TyFlies
Old Mar 01, 2009, 04:06 PM
Atom1025 is offline
Find More Posts by Atom1025
Fly me to the moon...
Atom1025's Avatar
Sacramento
Joined Jun 2005
Originally Posted by twister782
ok how about a recommendation?
FMA cellpro 4s
Atom1025 is offline Find More Posts by Atom1025
Old Mar 01, 2009, 04:42 PM
rwthomas1 is offline
Find More Posts by rwthomas1
Wakefield, RI, USA
Joined Jan 2009
Turnigy Accucell 6 is very well liked and only $37. Even with shipping it should be about $50. I have an Accucell 8 that is just a higher powered version as I like to parallel charge. Very easy to use and will charge any battery chemistry. www.hobbycity.com RT
rwthomas1 is offline Find More Posts by rwthomas1
Old Mar 01, 2009, 06:45 PM
Farnsrocket is offline
Find More Posts by Farnsrocket
PM sent!
Farnsrocket is offline Find More Posts by Farnsrocket
Old Mar 02, 2009, 12:59 PM
wrugen is offline
Find More Posts by wrugen
Joined Feb 2006
Crap crap crap And more crap I was being nice lol I need a new charger for lipo's
the 1 I had was a cheap E sky I dont trust them anymore. I have swelled 2 packs because of over charging. I am a lot ticked. Past peaved. Ok what is a good lipo charger for under 50 bucks? I know it is off topic. but if I say i need a new charger so I can fly my swift 2, doe's that help?
Try FMA Cellpro! Azar recomenrd it and I bought 2! Love em.
Right at 50$ but you do need the adapter for your battery type.
wrugen is offline Find More Posts by wrugen
Old Mar 02, 2009, 02:09 PM
GFBurke is offline
Find More Posts by GFBurke
allthingsthatfly.com
GFBurke's Avatar
USA, ID, Meridian
Joined Jan 2007
cellpro4>
hobbycity has 12v/5A power bricks for $8.
Dean them all up. Cig lighter to dean..
weeee
GFBurke is offline Find More Posts by GFBurke
Old Mar 02, 2009, 04:57 PM
donaldrtaylor is offline
Find More Posts by donaldrtaylor
Austin, TX, 78746
Joined Nov 2008
question about motor for Swift II
I have this motor left over from another project. Can I use it on a swift II and what prop should i run? thanks for your help
donaldrtaylor is offline Find More Posts by donaldrtaylor
Old Mar 02, 2009, 04:58 PM
Austin, TX, 78746
Joined Nov 2008
HXT 2030 (130S) 3500kv Brushless Inrunner
Motor Size: 2030 (130Short)
Speed: 3500kv
ESC Required: 15A
Voltage Range: 6~12v
No Load Curr: .6A
Max Load: 14A
Diameter: 20.2mm
Front Mounting Hole Distance: 16mm
Front Mount Thread Size: M2.5
Shaft Diameter: 2.3mm
Shaft Length: 15mm
Weight: 53g
100g 19
opps forgot to "paste"
Old Mar 02, 2009, 05:10 PM
More Trim is offline
Find More Posts by More Trim
More Trim
More Trim's Avatar
Raleigh NC
Joined Jan 2007
That is a bit big. I am using a blue wander 1500 kv. And a GWS 7060 with a 610 3c batt. You can get the motor and the esc at Hobby City. I think the esc I have is a 10 amp. I would have to look at it to see. But hope this will help you out.
Speed: 3500kv
ESC Required: 15A
No Load Curr: .6A
Max Load: 14A
Diameter: 20.2mm
Shaft Length: 15mm
Weight: 53g
100g 19
More Trim is offline Find More Posts by More Trim
Old Mar 02, 2009, 06:17 PM
RICH S is offline
Find More Posts by RICH S
Joined May 2000
New Dragon
Built another one, little MP Jet outrunner 760-D, Graupner 8X6 prop, 8 amp Jeti ESC ,and Hitec HS-55's. All up wgt w/ 850 MAH lipo is around 10 oz. This is one nice slowflyer, that will handle wind great, and great MPG on the batts.
RICH S is offline Find More Posts by RICH S
Old Mar 03, 2009, 11:15 AM
kz4q66 is offline
Find More Posts by kz4q66
Blackhawk
United States, TX, Fort Worth
Joined Jan 2007
I would like to know if the Swift II will fly with this motor
The Power Up 400 is a 1.8 ounce 1050KV outrunner brushless.
kz4q66 is offline Find More Posts by kz4q66
Old Mar 03, 2009, 12:00 PM
Atom1025 is offline
Atom1025's Avatar
Sacramento
Joined Jun 2005
Not a good choice. I recommend something in the 1oz range with 1300-1500kv. Immediate examples would be the blue wonder, or the customcdr cool wind.
It would fly with that motor but you would be missing out on what the plane is designed to do.
Old Mar 03, 2009, 01:52 PM
kz4q66 is offline
Blackhawk
Joined Jan 2007
I had this motor, The 2712-17 is a '300 class' 1700KV, it a little higher kv then you recommened but I think it will be OK with 7" prop.
Old Mar 03, 2009, 02:11 PM
Atom1025 is offline
Atom1025's Avatar
Sacramento
Joined Jun 2005
http://www.headsuprc.com/servlet/the...lectric/Detail
If thats it then its a good choice. You can run an 8x4 but it does get hot. With throttle management the 8x4 will do but caution should be taken. It may not sustain long full throttle flights. This is assuming your running 3s.
Check near the bottom of that link and it shows different props/performance.
Adam
Old Mar 04, 2009, 08:22 AM
dekan is offline
Find More Posts by dekan
D'oh.. Dumb Left Thumb
dekan's Avatar
London, UK
Joined Nov 2006
The Suppo 2208-12T 1800Kv motor works fine on my Raven which has a similar layout to the Swift.. It weighs 1.27 oz or 36g about 120W on a 3S lipo.
I use a 6X4 Apc prop , 18A esc , Corona 4 Ch rx with Azarr mini Aerial and 2 x Esky 7.5g digital servos. AUW with a 1000mA Loong Max 3s battery is 324g
I would have thought you would need to keep your Swift pretty light to use a 1500-1700Kv BW
This my no name version
http://www.giantcod.co.uk/a220812-18...leajtj17am3f82
dekan is offline Find More Posts by dekan
Discussion Good setup for a MSComposit Swift II ? myrslakt Foamies (Kits) 4 Oct 10, 2009 02:30 PM
Video Swift II Maiden Sim69 Electric Plane Talk 3 Jan 27, 2007 11:32 PM
Sold Swift II Airbrush line British Scheme Twinkletoze Aircraft - Electric - Airplanes (FS/W) 0 Jan 05, 2007 10:58 PM
Discussion Swift II from MS Composit? db1 Flying Wings 14 Dec 11, 2006 07:13 PM
Discussion My Swift II + Question highboy Flying Wings 2 Nov 29, 2006 11:05 AM
