Old Feb 26, 2009, 05:44 PM
Diggs is offline
Find More Posts by Diggs
Not your average DiggsyBear
Diggs's Avatar
Raleigh, NC
Joined Dec 2006
Originally Posted by rwthomas1
Hello All,
Looking to build a Swift II on the cheap. That means Hobby City for the gear. Anyone have a "recipe" for HC recommended gear for the Swift II? Motor, esc,lipo, prop would be great. Servos too if you think of it. TIA, RT
This is what I am using and I love how my latest turned out. It is ultralight, and only needs a Rhino 3S 610 lipo to balance it out.
Blue Wonder 1700kv
HXT 9 gram servos
GWS 7060 slowfly prop, but I want to try a 7035HD
TowerPro 12amp ESC
Rhino Lipo 3S 610mah
Spektrum AR6100e
I got it all at HC with the exception of the RX.
Gene Bond is using the 1500Kv blue wonder and a larger lipo, but 2S. I am sure that would work well also, but I just like the punch of a 3S pack. However you go, I have enjoyed mine much more when it was lite!!
Diggs
Diggs is offline Find More Posts by Diggs
Old Feb 26, 2009, 06:18 PM
rwthomas1 is offline
Find More Posts by rwthomas1
Wakefield, RI, USA
Joined Jan 2009
I may be a complete dolt but I have searched the HC site and cannot find anything specifically called a "blue wonder"..... Ya, I'm "that guy", need it spelled out for me! Thanks for the responses so far!
What do these thing fly like anyway? Have a Hyperflea and love it. Also have MPXT, MSCom Citabria, etc. RT
rwthomas1 is offline Find More Posts by rwthomas1
Old Feb 26, 2009, 06:25 PM
Farnsrocket is offline
Find More Posts by Farnsrocket
http://www.2dogrc.com/ecommerce/os/c...=&currency=USD
Farnsrocket is offline Find More Posts by Farnsrocket
Old Feb 26, 2009, 06:42 PM
LiveSquid is offline
Find More Posts by LiveSquid
LiveSquid's Avatar
Joined Nov 2007
I have this motor that Ive used on another foamie and love it.
https://www.gravesrc.com/ProductDeta...Code=BPA2212-6
"A powerful high RPM motor for high-speed flying wings... up to 100 grams (35 oz) using 2 or 3 li-poly cells. Manufacturer recommends a 7 x 5 prop on 2 cells, and a 5 x 5 or 6 x 4 prop on 3 cells. We suggest propping for around 200 watts continuous power. Expect to pull 18 to 20 amps on 3 cells with a 5 x 5 prop. Use with a 25 amp or greater ESC. An excellent higher-powered replacement for Speed 400/480 motors in park-flyer sized prop jets and flying wings."
LiveSquid is offline Find More Posts by LiveSquid
Old Feb 26, 2009, 07:28 PM
Diggs is offline
Diggs's Avatar
Raleigh, NC
Joined Dec 2006
Nope, sorry, they aren't called blue wonders on that site. But many know of it as the blue wonder 24 gram CDrom style outrunner.
1700
http://www.hobbycity.com/hobbycity/s...idProduct=5208
1500
http://www.hobbycity.com/hobbycity/s...idProduct=4859
1300
http://www.hobbycity.com/hobbycity/s...idProduct=2069
The alternative 1500
http://www.hobbycity.com/hobbycity/s...s_Motor_1500kv
Alt 1300
http://www.hobbycity.com/hobbycity/s...s_Motor_1300kv
Alt 1700
http://www.hobbycity.com/hobbycity/s...s_Motor_1700kv
I would suggest either of the 1500 or 1700's for the swift II.
Tower Pro ESC
http://www.hobbycity.com/hobbycity/s...eed_Controller
9 Gram servos
http://www.hobbycity.com/hobbycity/s...ec_Micro_Servo
Rhino 610
http://www.hobbycity.com/hobbycity/s...0C_Lipoly_Pack
That should be all you need for it. PLEASE, don't modify your swift II. It does NOT need a lot of extra tape or carbon spars. Keep it lite lite lite and you will be happy with it. Use a 7060 or 7035 GWS prop with the 1700 or an 8040 on the 1500 motor and you will have plenty of thrust and draw around 7~8 amps and have plenty of speed to boot. The only mod you will need is to enlarge or create larger cut outs for some of the components like the ESC or your RX. I cover those with strapping tape, or white duct tape and that is all I use. Two of my buds fly this exact same setup and LOVE how theirs flys and floats. Go heavy, and you lose the slow float that it can do. Also keeping it lite means you are less likely to break it from a crash.
It will be similar to your hyperflea, but floaty. You can take it out and just chase thermals if you like. I got an hours flight on my first one, which was much heavier with a 3S 1000 lipo just floating in the wind and lift. But it is still fun fast and low, or slow and low. Doesn't high alpha like the fleas and flys, but it is more locked in / precise IMO.
Diggs
Old Feb 26, 2009, 11:26 PM
Wakefield, RI, USA
Joined Jan 2009
Thanks for all the great input! LHS has the Swift on the shelf. No one knows what to do with them so they sit there. Cheap too, @$35. Order will be placed this weekend! Will post when airborne. RT
Old Feb 27, 2009, 08:11 AM
Diggs is offline
Diggs's Avatar
Raleigh, NC
Joined Dec 2006
Wow, that is a good deal on them. I would buy two One for day, the other for night with some light wire!
Diggs
Old Feb 27, 2009, 09:17 AM
tashley is offline
Find More Posts by tashley
Aerial Images of Texas
tashley's Avatar
The Texas Gulf Coast where hurricanes come to play
Joined Aug 2003
I just picked up a pair at my lhs for 25 each.
tashley is offline Find More Posts by tashley
Old Feb 27, 2009, 09:27 AM
dekan is offline
Find More Posts by dekan
D'oh.. Dumb Left Thumb
dekan's Avatar
London, UK
Joined Nov 2006
Mine sells them for $10 each..... but only when he's out of stock
dekan is offline Find More Posts by dekan
Old Feb 27, 2009, 09:51 AM
LiveSquid's Avatar
Joined Nov 2007
Diggs
That would be cool... I put leds on my Slow Stick, I dont see why I cant do that to this one too.. After I repair it, I mean. Get this, I havent flown it and I already need repairs. I was 100% RTF, put on a prop and throttled up a bit to see which way it was thrusting. Then the prop came loose and ripped out one of my horns, bent my pushrod, and tore out foam at the corner of the aileron. Im just a little annoyed. Peeved, maybe.
But LEDs will be the first mod after a successful flight. Or wire. I know how to do LEDs to wire to a 9V battery, but Ive never used EL wire.
Old Feb 27, 2009, 07:11 PM
Diggs is offline
Diggs's Avatar
Raleigh, NC
Joined Dec 2006
El Wire is simple, but it needs a little inverter which will add some weight. Just parallel the LEDs or the El wire into your flight pack and don't bother with another heavy power source.
Diggs
Old Mar 01, 2009, 02:18 PM
twister782 is offline
Find More Posts by twister782
twister782's Avatar
Akron, Ohio
Joined May 2008
Does he give rainchecks? lol
twister782 is offline Find More Posts by twister782
Old Mar 01, 2009, 02:24 PM
twister782's Avatar
Akron, Ohio
Joined May 2008
Crap crap crap And more crap I was being nice lol I need a new charger for lipo's
the 1 I had was a cheap E sky I dont trust them anymore. I have swelled 2 packs because of over charging. I am a lot ticked. Past peaved. Ok what is a good lipo charger for under 50 bucks? I know it is off topic. but if I say i need a new charger so I can fly my swift 2, doe's that help?
Old Mar 01, 2009, 02:27 PM
LiveSquid's Avatar
Joined Nov 2007
a /good/ charger for under $50? You got me, man. As far as I know there arent any.
Old Mar 01, 2009, 02:31 PM
twister782's Avatar
Akron, Ohio
Joined May 2008
ok how about a recommendation?
Discussion Good setup for a MSComposit Swift II ? myrslakt Foamies (Kits) 4 Oct 10, 2009 02:30 PM
Video Swift II Maiden Sim69 Electric Plane Talk 3 Jan 27, 2007 11:32 PM
Sold Swift II Airbrush line British Scheme Twinkletoze Aircraft - Electric - Airplanes (FS/W) 0 Jan 05, 2007 10:58 PM
Discussion Swift II from MS Composit? db1 Flying Wings 14 Dec 11, 2006 07:13 PM
Discussion My Swift II + Question highboy Flying Wings 2 Nov 29, 2006 11:05 AM
