Old Feb 18, 2009, 02:06 PM
LiveSquid's Avatar
Joined Nov 2007
Hey, I already have Shoe Goo II. Thats convenient. Maybe Ill skip the mount modifications, then.
LiveSquid is offline Find More Posts by LiveSquid
Old Feb 18, 2009, 02:27 PM
allthingsthatfly.com
GFBurke's Avatar
USA, ID, Meridian
Joined Jan 2007
Well, measure up your prop. See how far you can scoot it before mounting. (you know... like I didn't...)
My kv is only 1200. So I need(want) to run a larger prop.. but now I may have to cut my wing so the prop doesn't hit it.
GFBurke is offline Find More Posts by GFBurke
Old Feb 18, 2009, 09:31 PM
GFBurke's Avatar
USA, ID, Meridian
Joined Jan 2007
I shot myself in the foot. Pic shows an 8in prop.
Exit plan?
- use a smaller prop
- put the motor on the back with the large screw adapter and drill out the props (more weight)
- cut out some EPP to make the prop fit
Old Feb 18, 2009, 09:48 PM
Not your average DiggsyBear
Diggs's Avatar
Raleigh, NC
Joined Dec 2006
I don't' see that mount coming off easily. And if you do, it is surely going to scar up that nice scheme on top of the wing
This is what I would do.
http://www.headsuprc.com/servlet/the...lectric/Detail
Install that on the rear of the mount with the included firewall mount and use a GWS7060 sf prop.
Only other options, Cut the fuse to fit the prop, but dude..... I have no idea what that will do to its glide and flight characteristics. It wouldn't be a fair review of the plane doing that mod.
Diggs
Diggs is online now Find More Posts by Diggs
Old Feb 18, 2009, 09:53 PM
Fly me to the moon...
Atom1025's Avatar
Sacramento
Joined Jun 2005
Yep do as Diggs says. Dont cut it.
Atom1025 is offline Find More Posts by Atom1025
Old Feb 18, 2009, 09:54 PM
GFBurke's Avatar
USA, ID, Meridian
Joined Jan 2007
yeah ok, I'll mount her on back.. bleh..
Old Feb 19, 2009, 10:25 PM
LiveSquid's Avatar
Joined Nov 2007
I'll keep mine stock I suppose. Im not an accomplished pilot by any means so an easier, less nimble setup is perfect for me now.
Old Feb 19, 2009, 11:12 PM
GFBurke's Avatar
USA, ID, Meridian
Joined Jan 2007
I've got the 8x4 and 8x6 HDs in. Thought I ordered 7x but oops.
Think I'll try out the 8x6.
Old Feb 20, 2009, 06:21 AM
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
After having the TE foam get eaten by the prop on a very bad crash, I went ahead and notched it out in the corners.
Gene Bond is offline Find More Posts by Gene Bond
Old Feb 20, 2009, 09:08 AM
GFBurke's Avatar
USA, ID, Meridian
Joined Jan 2007
I was watching some flightpass and noticed most every swiftII had notches or cut out the back for the prop.
Old Feb 20, 2009, 09:44 AM
LiveSquid's Avatar
Joined Nov 2007
Were they just using larger props, or did they have the motors mounted farther (further?) up toward the nose? Could you tell?
Old Feb 20, 2009, 10:10 AM
Hi I am Mark & I am an addict
mthomas's Avatar
USA, KY, Louisville
Joined May 2007
My prop runs even with the elevon hinge line.. so that is about 8 1/2" between the two.. I had used an 8x6 on my previous Swift II when running a 370 outrunner.
I haven't notched the trailing edge of either wing, just put a little strapping tape there in case of a blade strike since I am using a prop saver on it..
Mark
mthomas is offline Find More Posts by mthomas
Old Feb 21, 2009, 04:56 AM
D'oh.. Dumb Left Thumb
dekan's Avatar
London, UK
Joined Nov 2006
This a Raven made by FlyingWings a UK company that specialise in Epp planes. It is a very similar shape and size to a Swift.
http://www.flyingwings.co.uk/store/p...93bd7d5c94cee4
It is made of a very hi density German Epp..Its so stiff that no CF spar is needed
I built mine from what flyingWings call a core kit (Foam only) its a very low cost kit about $22 at the current exchange rate http://www.flyingwings.co.uk/store/p...roducts_id=649
Mine has a no Name verison of the Supp 2208-12T 1800Kv motor, 6X4 Apc prop , 18A esc , Corona 4 Ch rx with Azarr mini Aerial and 2 x Esky 7.5g digital servos. AUW with a 1000mA Loong Max 3s battery is 324g
It flys very well... fast or slow the glide is very good. In fact just like a big version of my Mini Swift
dekan is offline Find More Posts by dekan
Old Feb 21, 2009, 02:09 PM
3D wannabe
smokejohnson's Avatar
USA, OK, Tulsa
Joined Nov 2006
Here are some pics of my progress. I should have it RTF tomorrow.
smokejohnson is offline Find More Posts by smokejohnson
Old Feb 21, 2009, 02:13 PM
LiveSquid's Avatar
Joined Nov 2007
Nice. I couldnt get my control horns to mount straight like yours. The zbend on my pushrods isnt wide enough to accommodate the width of the horn.
How do you like that Rhino battery? I was going to get a couple but Ive had mixed results with Zippys.
Discussion Good setup for a MSComposit Swift II ? myrslakt Foamies (Kits) 4 Oct 10, 2009 02:30 PM
Video Swift II Maiden Sim69 Electric Plane Talk 3 Jan 27, 2007 11:32 PM
Sold Swift II Airbrush line British Scheme TreeFlyer Aircraft - Electric - Airplanes (FS/W) 0 Jan 05, 2007 10:58 PM
Discussion Swift II from MS Composit? db1 Flying Wings 14 Dec 11, 2006 07:13 PM
Discussion My Swift II + Question highboy Flying Wings 2 Nov 29, 2006 11:05 AM
