Feb 16, 2009, 04:30 PM
Indianapolis, IN
Joined Sep 2001
2 points, which you may have already tried or thought about:
- Exercise the joint, bending the elevon back and forth several times to loosen the hinge. Make sure there is nothing stuck in the crack, like a booger from the hot-wire cutting.
- Make the arm on the servo as short as possible, to use the maximum throw, rather than turning the endpoints down. This will give you the maximum available torque. On the HXT90's, I'm a hole in from the end on the single arm IIRC.
