Old Feb 14, 2009, 12:04 AM
Diggs is offline
Find More Posts by Diggs
Not your average DiggsyBear
Diggs's Avatar
Raleigh, NC
Joined Dec 2006
Wow, that motor looks massive!! But you did do a fine job of mounting it. I am telling you man, once this review is done, I want you to put on a LITE setup and give it a go. Completely different plane when it is ultra lite. So floaty, but still fast and easy to toss around. You will love how she floats too.
Diggs
Diggs is offline Find More Posts by Diggs
Old Feb 14, 2009, 05:53 PM
LiveSquid is offline
Find More Posts by LiveSquid
LiveSquid's Avatar
Joined Nov 2007
Hi, guys. I posted this over in another thread, but I figured it should probably actually go here.. I got my Swift 2 in yesterday's mail and in building it today Ive hit what I consider to be a considerable snag.
Quick question, please..
Did anyone else have an issue with the flexibility of the ailerons? Im using HS-55s as per the instructions' recommendations, but they don't do much to move them. I did paint the underside, would the paint be making it more stiff than it was?
Also, the z-bend in the pushrods arent wide enough to truly accommodate the control horns. Did anyone else have to make any adjustments? I had to mound them at a slight angle to get them to move freely on the z-bend. Would this be causing me problems with the movement of the ailerons?
Thanks for any assistance. Im getting a bit frustrated as I was expecting this to be a two hour process.
LiveSquid is offline Find More Posts by LiveSquid
Old Feb 14, 2009, 06:16 PM
GFBurke is offline
Find More Posts by GFBurke
allthingsthatfly.com
GFBurke's Avatar
USA, ID, Meridian
Joined Jan 2007
Be sure your trimmed out at 0
Use long servo arms
Put the pushrod in the top hole on the servo side
Put the pushrod in a lower hole on the control surface
GFBurke is offline Find More Posts by GFBurke
Old Feb 14, 2009, 06:55 PM
LiveSquid's Avatar
Joined Nov 2007
Alright. Ill make sure that I have mine configured that way. Thanks. You might be hearing from me again, though. lol.
Old Feb 14, 2009, 06:59 PM
twister782 is offline
Find More Posts by twister782
twister782's Avatar
Akron, Ohio
Joined May 2008
Don't get frustrated!!!!!!!!!!!! I was told that 60 million times. And it's true.
I sit back and think of all the stuff I learned when I bought a swift2. #1 is be patient. i was done with my build, just to watch it slam into the ground numerous times. now I can fly it great. #2 ask a lot of questions. these guys in here are very helpful. once you iron out your bugs. you will also be telling someone to not get frustrated. Did you support the control rod? are they flexing?
twister782 is offline Find More Posts by twister782
Old Feb 14, 2009, 07:47 PM
LiveSquid's Avatar
Joined Nov 2007
The rods would rather bend than push the dang ailerons. I went ahead and used a longer servo arm. My horns only have one hole, so I popped on a horn from my slow stick and its better but still no dice. Im considering (and maybe I shouldve done this already, but the instructions leave a bit to be desired) cutting the ailerons off and taping them back on so its easier for them to bend.
Old Feb 14, 2009, 07:59 PM
Diggs is offline
Diggs's Avatar
Raleigh, NC
Joined Dec 2006
NO, put the knife down and step away from the Swift!!!!!
I have had the problem several times and I am not sure what the actual cause of it is. Having the rod in the control surface the way down in the bottom hole makes it more difficult for the servo to push it. Also, you want to make sure the holes of the control horn are directly over the gap you were thinking of cutting. If they are too far forward or back, you're surface will not move up and down equal distances.
On my latest Swift II I installed micro control horns and it was much better, however your slow stick horns should have done the same thing. Are the rods straight? Did you use the tube over the rods? Do your servos buzz loud when trying to move the elevons or does the wire bend? If the wire is bending, you didn't use the tubing or you didn't glue the tubing down.
Diggs
Old Feb 14, 2009, 08:08 PM
LiveSquid's Avatar
Joined Nov 2007
lol. What I meant was to more or less re-hinge the ailerons. But I havent done that yet.
The rods are straight. I used the longest arm supplied with the HS-55s. When I used the long arm and the short control horn I held the tube down against the Swift. I dont want to glue them until I have it all sussed out. It pushed more, but still the rod bent. Im only changing one side for now until I get it right. Using the longer horn from the slowstick the rod is at least an inch above the body of the swift. If I press it to the body, the rods will flex a lot. Is that gonna be okay?
sigh.. I dont know whats the deal. But dammiut, I want it to work. NOW. lol
Oh, as for the other questions and suggestions.. I am at zero trims, but I am using a small amount of subtrim. The servos are not binding.
It was easier to get the T-rex 500 in the air. That just doesnt seem right. lol
Went ahead and pressed the tube down and held it in place. Its much better but I dont seem to get a whole lot of throw. And the servo does bind at the very top and bottom of the elevator stick.
Old Feb 14, 2009, 08:14 PM
Diggs is offline
Diggs's Avatar
Raleigh, NC
Joined Dec 2006
Tac the tube down with a spot of hot glue. Then see if you can push the wire and move the surface. If it is bending, no biggie, the tube should hold it in place once you attach it to the wing. But if it is hard for you to move the surface when pushing on the wire with your hand, something aint right.
Diggs
Old Feb 14, 2009, 08:16 PM
LiveSquid's Avatar
Joined Nov 2007
I went ahead and pressed the tube down and held it in place. Its much better but I dont seem to get a whole lot of throw. And the servo does bind at the very top and bottom of the elevator stick.
Ill see if its difficult to move by hand as you suggested.
Thanks a lot for the time and the help.
Old Feb 15, 2009, 09:06 PM
LiveSquid's Avatar
Joined Nov 2007
Okay, its definitely better. But how much throw do you guys get? 30 degrees? 1/2 inch?
Now that Im using longer arms and horns, my pushrods are about 1/2" above the body of the Swift (when looking at the underside). Should I glue the tubes down? Maybe I should mount some foam between the body and the tube?
Thanks again!
Old Feb 16, 2009, 10:34 AM
GFBurke is offline
GFBurke's Avatar
USA, ID, Meridian
Joined Jan 2007
I'm in the same boat. But found a solution even in using the stock horns.
Mount the horns as per the instructions.
Put the plane upside down with the control surfaces under it (so it's holding the surfaces folded under it)
Go to sleep. Wake up in 8hrs
Now feel.
Old Feb 16, 2009, 10:42 AM
LiveSquid's Avatar
Joined Nov 2007
Well, heck. Ill try it.. But part of the problem is that when using the stock horns the pushrod ends up touching the plane and then it cant move the flap anymore. I'll prolly just move the arms and horns to the top so the distance over the body wont matter when I land.
Thanks for the tip!
So, check out my underside. No, not mine! The plane's! Painted for better visibility and a nice wide (95mm) stripe to determine orientation. Put the stripe on the proper side to utilize the 'red right returning' adage.
Old Feb 16, 2009, 02:25 PM
More Trim is offline
Find More Posts by More Trim
More Trim
More Trim's Avatar
Raleigh NC
Joined Jan 2007
I like the paint design. And also the way the motor is mounted in the rear of the mount, that is cool . I have to try that on the next one.
Thanks for the tip!
More Trim is offline Find More Posts by More Trim
Old Feb 16, 2009, 02:30 PM
LiveSquid's Avatar
Joined Nov 2007
The motor pics arent mine. Theyre from GFBurke's post. But thanks for the compliment on the paint.
Discussion Good setup for a MSComposit Swift II ? myrslakt Foamies (Kits) 4 Oct 10, 2009 02:30 PM
Video Swift II Maiden Sim69 Electric Plane Talk 3 Jan 27, 2007 11:32 PM
Sold Swift II Airbrush line British Scheme Twinkletoze Aircraft - Electric - Airplanes (FS/W) 0 Jan 05, 2007 10:58 PM
Discussion Swift II from MS Composit? db1 Flying Wings 14 Dec 11, 2006 07:13 PM
Discussion My Swift II + Question highboy Flying Wings 2 Nov 29, 2006 11:05 AM
