Old Jan 24, 2009, 10:55 PM
twister782 is offline
Find More Posts by twister782
twister782's Avatar
Akron, Ohio
Joined May 2008
Originally Posted by Atom1025
Hook it up and give us the numbers, run it for 30 seconds and keep an eye on the volts. They will sag some but if it drops majority then you have an issue.
Reading the ratings from the site that motor should provide ample thrust....
how do i hook it up? not sure what you mean. I have a meter that i can clip around 1 wire and it gives me a reading. is that what you want? 1/2 throttle ?
full throttle for 30 sec i think is way to much
twister782 is offline Find More Posts by twister782
Old Jan 25, 2009, 07:32 AM
mthomas is offline
Find More Posts by mthomas
Hi I am Mark & I am an addict
mthomas's Avatar
USA, KY, Louisville
Joined May 2007
Is that the right kind of prop to use a a direct drive on this wing? I sue the APC props like Rosster shows and never had a problem with thrust
Mark
mthomas is offline Find More Posts by mthomas
Old Jan 25, 2009, 08:22 AM
Atom1025 is offline
Find More Posts by Atom1025
Fly me to the moon...
Atom1025's Avatar
Sacramento
Joined Jun 2005
Sorry, incorrect wording on my part, I meant wattmeter.
http://www.astroflight.com/index.php...sbqt8f0c2nji23
The reason I suggested 30 secs is to see if your battery is holding up to the task or dropping voltage dramatically.
Atom1025 is offline Find More Posts by Atom1025
Old Jan 25, 2009, 09:41 AM
Rosster is offline
Find More Posts by Rosster
I'll Fly Anything...
Michigan
Joined Apr 2006
Let's clear the air here on weight. I run this airplane @ 12.2oz. It floats. If the CG is correct, there will be no issues there. 14oz is but a pittance. 9oz is fine, but that is done with the battery pack. I run a 1000mah 3S Dualsky pack and get nearly 15 minutes of flight time! I could run a 600mah 3S Dualsky, but then my airplane would be off on CG. So I don't.
Looking at Twister's prop, it looks like he's in the right spot and it's turning in the right direction. If he's got two batteries and gets the same results as far as thrust, then there is no problem.
Twister, a Wattmeter goes between the battery and the Speed Control. It will give you a picture of what sort of energy is travelling between the battery and the rest of the system. Astro Flight makes a fantastic one. You make adapters to suit the connectors. Having the right connectors, you can use this thing to measure what's happening between a source and a load. That could be servos, receivers, etc. It's a great diagnostic tool. Some people go so far as to use a miniaturized one for on-board measurements!
Do check the CG. I would love to see a video where I could hear what the motor sounds like - the prop, I mean.
This should be a no-brainer! You shouldn't be having this trouble! So it's kind of maddening, in a way! But we'll get there!
Rosster is offline Find More Posts by Rosster
Old Jan 25, 2009, 09:58 AM
twister782's Avatar
Akron, Ohio
Joined May 2008
no I dont have a meter like that. I have a amp/volt meter. If i clamp it around 1 of the motor wires it will give me a amp reading.
Old Jan 25, 2009, 10:09 AM
twister782's Avatar
Akron, Ohio
Joined May 2008
maddening is not the word. But i will be nice. Let me say this. I want to thank every1 for all there help. every1 has been very helpful.I will make a video right now
hope it works
Old Jan 25, 2009, 10:24 AM
Rosster is offline
Michigan
Joined Apr 2006
Twister,
You want to (and you'll need three or four hands for this) put this unit between the battery and the rest of the system. We're looking for a voltage drop.
Since your ESC isn't cutting out (Making the motor stop in mid-flight) I don't think we have to worry about amps for now.
However, you have indicated in the past that the motor doesn't cut out, and that there is sufficient power and the power doesn't change throughout the flight.
To my knowledge, you have not had a single successful flight with this Swift II yet, and have only managed to strike the ground after a hand launch.
Correct?
Old Jan 25, 2009, 11:11 AM
twister782's Avatar
Akron, Ohio
Joined May 2008
Originally Posted by Rosster
Twister,
Correct?
It has flown but i really struggle with it. I know from videos I have seen it is not right
Old Jan 25, 2009, 11:13 AM
twister782's Avatar
Akron, Ohio
Joined May 2008
the video is to large. it will not except the video. I can email it to you
Old Jan 25, 2009, 11:27 AM
twister782's Avatar
Akron, Ohio
Joined May 2008
hope this works here is the video of motor sound
Old Jan 25, 2009, 12:58 PM
More Trim is offline
Find More Posts by More Trim
More Trim
More Trim's Avatar
Raleigh NC
Joined Jan 2007
Thought you might be interested in this. http://2dogrc.com/ecommerce/os/catal...ky-p-2358.html This is the one I just purchased. IT will do a lot of things. Take a look at the site and see what ya think,
More Trim
More Trim is offline Find More Posts by More Trim
Old Jan 25, 2009, 01:05 PM
Rosster is offline
Michigan
Joined Apr 2006
Twister,
the only way I've managed to get videos on here is linking to the youtube video I have put up. I've got one there for the Swift II with a young man jumping it!
At any rate, anything less than 10MB will get through. Have a look at your Private Messages, you'll see my email address there.
Old Jan 25, 2009, 01:13 PM
twister782's Avatar
Akron, Ohio
Joined May 2008
no messages
FlyingLakland is offline
Find More Posts by FlyingLakland
Sideslip!
FlyingLakland's Avatar
United States, CA, Camarillo
Joined Jul 2008
haha that was you? i saw that vid. in the soccer place
FlyingLakland is offline Find More Posts by FlyingLakland
Old Jan 25, 2009, 01:15 PM
twister782's Avatar
Akron, Ohio
Joined May 2008
I saw that vid too it was great
Discussion Good setup for a MSComposit Swift II ? myrslakt Foamies (Kits) 4 Oct 10, 2009 02:30 PM
Video Swift II Maiden Sim69 Electric Plane Talk 3 Jan 27, 2007 11:32 PM
Sold Swift II Airbrush line British Scheme Twinkletoze Aircraft - Electric - Airplanes (FS/W) 0 Jan 05, 2007 10:58 PM
Discussion Swift II from MS Composit? db1 Flying Wings 14 Dec 11, 2006 07:13 PM
Discussion My Swift II + Question highboy Flying Wings 2 Nov 29, 2006 11:05 AM
