Old Jan 29, 2007, 05:38 PM
endeavor_635650 is offline
Find More Posts by endeavor_635650
Crash Hard!!!
endeavor_635650's Avatar
Moultrie, Ga
Joined Jul 2004
I and MS composit both opted for the slowflyer prop. It is lightweight which is important for getting the correct center of gravity.
Brian
endeavor_635650 is offline Find More Posts by endeavor_635650
Old Jan 29, 2007, 08:12 PM
myrslakt is offline
Find More Posts by myrslakt
Rotorhead
Sweden
Joined Jan 2006
Originally Posted by db1
I'm sure the AXI performs better but a hundred dollars better??? The GWS setup was only $30.
The $130 is for the Swift II wing + AXi motor + JETI 12 amp brushless ESC...
And over here - in Europe - everything is always more expensive... That's just the way things are...
By the way, are there any parts in the (Swift) kit to mount outrunners in a pushing configuration?
myrslakt is offline Find More Posts by myrslakt
Old Jan 29, 2007, 11:31 PM
db1 is offline
db1
Find More Posts by db1
db1
don betz
db1's Avatar
United States, OH, Cincinnati
Joined Aug 2004
Oops! I guess it would help if I read a little more carefully eh? I guess I'm just excited by how much fun this plane is for so little money. SWIFT II = $35, 2 HS-55's = $20, GWS BL motor and ESC = $30, Corona rx $17, 3S TP910 = $28
db1 is offline Find More Posts by db1
Old Jan 30, 2007, 02:43 PM
Crash Hard!!!
Moultrie, Ga
Joined Jul 2004
Yes, it comes with everything you need to mount an outrunner. Still no end to the good news, eh.
Brian
Old Jan 30, 2007, 03:07 PM
myrslakt is offline
Rotorhead
Sweden
Joined Jan 2006
That's just great!
And now I'm pondering battery weight.
I already have some 7,4V Lipos, 850 mAh, 15C (12 amps)... they weigh about 45g.
The smallest 11,1V I can find are 1200 mAh, 10C (also 12 amps)... but their weight is 95g!
I get this feeling I would really need larger 2-cells and/or smaller 3-cells to balance this thing...
Brian, now is the time for you to chime in with some good news - like "It doesn't matter, this wing balances perfectly with batteries of any size or weight"
Please!
Old Jan 30, 2007, 06:30 PM
Crash Hard!!!
Moultrie, Ga
Joined Jul 2004
Well, the battery that I know of that balances the wing perfectly is a Thunder Power 3 cell 1320mah. The TP 3 cell weighs 85g. So I guess you could use whatever you want as long as you stay around 90g.
Brian
Old Feb 03, 2007, 11:24 AM
IceWind is offline
Find More Posts by IceWind
throw new IOPilotException();
IceWind's Avatar
Ireland, County Dublin, Dublin
Joined Feb 2005
Eh eh!
I forgot i started this thread!
It's cool to see much action around this cool wing.
Mine is still flying, after i had a small accident with it and breaking in half one of the wings.
I was climbing with it after launch and it completly shutdown at middle, i think it was the esc that shutdown due to the heat or current. I was using a GWs esc-300.
But after some epoxy it's perfect again.
I haven't changed the motor, only the prop. I was using one from GWS but i notice that despite the low power of the brushed motor the prop bent at high speed. So i bought a APC, and now it's way better much more torque i'm having much more vert speed.
It's not unlimited vert but for a brushed motor it's a awesome performance.
Next stop is a brushless motor, despite i keep saying i'll not change i want to! I need more powerrrr.....
IceWind is offline Find More Posts by IceWind
Old Feb 04, 2007, 10:54 PM
sloonz is offline
Find More Posts by sloonz
sloonz's Avatar
Phoenix
Joined Aug 2006
Newb needs advice
Hey guys,
I was directed over here by Db1. I just finished building my Swift II Russian. It came in at 285g AUW(with lipo?). I set it up with parts I had lying around (except the motor& Rx). Specs for my wing are:
JGF 300DF 2200Kv
CC Thunderbird 18
TP 3s 1320 ProLite
TowerPro 9g servos
Corona 4ch Rx
So I headed to the park and tossed it in the air with no throttle. I couldn't believe it gilded so nicely. Tossed it a second time an applied power. She flew pretty good to my amazement. After some slight trimming on my 7CHP I flies nice and straight. I have a couple of questions though.
1. When I apply power it wants to climb. With no/little power it flies flat. What is the cause of this? I'm assuming the motor must not be at the correct angle? The motor mount is just glued flat to the top like everyone else's; exactly like the instructions say.
2. I'm running a JGF 30DF(2200Kv) with 6x3 and 5x4.3 GWS direct drive props. If I give it full throttle the prop blades go out of track (This is the best way for me to explain it as I'm a heli guy and this is my first plane). What could be the cause for this? I did have to drill the center of the prop out bigger to fit the prop on the prop adapter. I wasn't able to drill the hole perfectly strainght so it isn't perfectly true. Does this have something to do with the tracking or could it just be that I'm using the incorrect type of prop for this particular motor? I tried two different 6x3 and got the same results. I plan to try the 5x4.3 tomorrow.
I'm new to planes but I have to say that this wing is super easy to fly however, it doesn't have enough power for my taste. My Trex450 flies faster than this thing! It cant even get any vert. Probably due to the prop issues I'm having though. Do you think the 5x4.3 will work better and give me more speed?
Thanks for the input.
Sloonz
sloonz is offline Find More Posts by sloonz
Old Feb 05, 2007, 02:16 PM
sloonz is offline
sloonz's Avatar
Phoenix
Joined Aug 2006
Alright, I tried the 5x4.3 today and it now can fly WOT. It's faster but I still want more. It now has some vert but I need more of that too.
I inspected the 6x prop and found that is must have been bending under WOT. The plastic is white in color (the prop is black) at the base of blade where it connects to the center. I think I might need a fiber prop.
Old Apr 24, 2007, 02:31 AM
IceWind is offline
IceWind's Avatar
Joined Feb 2005
Hi everyone!
My swift it's still flying and very well!
I kept my setup, despite being low, the brushed speed 400 and a APC 5.5x4.5 prop.
And it does wonders, the noise it makes flying most of the ppl thinks i'm using a brushless motor!
GWS props that bend!!! no more!
Old May 14, 2007, 02:44 AM
Hydrocat is offline
Find More Posts by Hydrocat
hydrocat
Worcester Western Cape South Africa
Joined Feb 2006
First Wing
Hi All
Got my fisrt wing this w/end and kitted it as follows:
- Bp21 outrunner
- Bp15 controller
- GWS 8043 soft prop
- 8x 750mah Nmh cells
- 2x Eflite 5g servos
The Swift II builds in minutes and I was surprised with its stability and roll rate (even at recommended throughs), but expected a lot more performance.
As is.....it's a nice park flier, but it needs at lot more attitude. Maybe a 3 cell lipo and a smaller prop. What do you think?
I did not like the cut outs for all the equipment on the bottom, and moved the wiring and control horns & rods to the top, to keep it out of harms way.
Hydrocat is offline Find More Posts by Hydrocat
Old May 14, 2007, 06:45 AM
RICH S is offline
Find More Posts by RICH S
Joined May 2000
Originally Posted by Hydrocat
Hi All
- Bp21 outrunner
- Bp15 controller
The Swift II builds in minutes and I was surprised with its stability and roll rate (even at recommended throughs), but expected a lot more perforformance.
Nice job on moving those control rods on top, I should have done this on mine. I used a 300 e-flight outrunner, 7X5 prop, and a 3 cell 1320 lipo and it was not bad, nothing blitering speed ,but zippy for a parkflyer. I don't think you could put too much power on these without adding a spar or stiffening the airframe some. Try the lipos, it'll give it a lot more punch, those NiMH are heavy as well. I've also used the DN 900 3 cells, only around $20, they work well on these little planes also.
RICH S is offline Find More Posts by RICH S
Old May 15, 2007, 01:11 PM
tioli is offline
Find More Posts by tioli
Peace
tioli's Avatar
Kona, Hawaii
Joined Aug 2005
I outfitted mine with a 400 outrunner, an 1800mAh lipo and an 8x6 prop. It'll climb to the clouds in a few seconds. As Rich said, I had to add carbon spars...
tioli is offline Find More Posts by tioli
Old Jun 10, 2007, 12:09 PM
HerrHal is offline
Find More Posts by HerrHal
Joined Aug 2006
Swift II Wing - proper setup
Seems to be a lot of suggested setups. I just ordered one and have the following "spare parts" on hand. Can anyone recommend what combination of these spares I should use for some slow to medium performance? or, what I need to get to compliment what I have? - I am new to wings:
I have these "parts"
E-flite 370 brushless - 1360 kv motor, draws 9-10 amps
Eskay 400xt motor - 950 Kv, draws 10-12 amps
18 amp brushless ESC with 2 amp bec
E-flite S-75 micro servos - 17.2 oz/in torque
Spektrum DX 6 TX & Rx.
Also what prop to use ?
Thanks Hal
HerrHal is offline Find More Posts by HerrHal
Old Jun 13, 2007, 09:34 PM
RICH S is offline
Joined May 2000
Thanks Hal
The servos are fine, if the Esky motor is an outrunner I'd use that with a 7X5 prop. I use a 300 size outrunner on 3 cell lipo's and it makes for a nice parkflyer, not too fast but very zippy. The Swift is not a bullet like a brushless zagi type wing, it's main advantage (I think) is it can fly very slow, and turn very close in, it can be flown indoors easily. The Rx should be ok as well.
Discussion Good setup for a MSComposit Swift II ? myrslakt Foamies (Kits) 4 Oct 10, 2009 02:30 PM
Video Swift II Maiden Sim69 Electric Plane Talk 3 Jan 27, 2007 11:32 PM
Sold Swift II Airbrush line British Scheme Twinkletoze Aircraft - Electric - Airplanes (FS/W) 0 Jan 05, 2007 10:58 PM
Discussion Swift II from MS Composit? db1 Flying Wings 14 Dec 11, 2006 07:13 PM
Discussion My Swift II + Question highboy Flying Wings 2 Nov 29, 2006 11:05 AM
