Old Dec 12, 2012, 08:23 AM
Foam Snow
Joined Aug 2011
Took a bad hit this morning, fibre tape came loose and jammed up the motor, which snapped the motor mount and the prop ripped 1/4 through the wing. Not sure if it's salvageable... HoryzonHD also killed.
heinduplessis is offline Find More Posts by heinduplessis
Old Dec 14, 2012, 10:47 AM
Foam Snow
Joined Aug 2011
She's up and running again! Better than ever. Ordered another 2 Swifts and mid section
Old Dec 14, 2012, 12:08 PM
throw new IOPilotException();
IceWind's Avatar
Ireland, County Dublin, Dublin
Joined Feb 2005
Good to hear that!
And that is why I really like foam planes/wings.
IceWind is offline Find More Posts by IceWind
Old Dec 14, 2012, 01:55 PM
Foam Snow
Joined Aug 2011
Originally Posted by IceWind View Post
Good to hear that!
Thanks, foam all the way..
My mistakes were not making it rigid enough, spoiling the aerofoil with gadgets and taking liberties with the CG. All good now.
Old Dec 15, 2012, 03:06 PM
hass-alfed and bass-ackwards
carlsoti's Avatar
United States, AZ, Chandler
Joined Jun 2008
I've got a Hacker branded Swift II that I won in a raffle nearly a year ago. I finally got around to finishing it out. I went for a lightweight set-up, using a berg 4, 5g HTX servos, a hacker x-12 ESC, a "blue Wonder" style 1700kv motor spinning a GWS 7x3.5 prop, with a 3S 1050mah rhino providing motivation.
It tips the scales at 294g, or about 10.4 oz AUW.
I could probably shave that .4 oz off by tidying up extra wires, etc, but I think I'll wait to see how it flies, first.
This is my first flying wing, so I'm apprehensive about the maiden, but I'm off to do it anyways. Wish me luck!
:EDIT: Success! With the wing on the nose-heavy side of the recommended CG range, a firm toss into the wind from the top of a water retention basin was all that was needed to get this wing flying. It was supposed to be a simple glide test, but after a second or two of it doing nothing unexpected, I cracked the throttle open, and off she went. I didn't even bother to trim it, as the turbulence from the wind would make that endeavor fruitless.
As expected, it's not a rocket, but with more than 1:1 power to weight, it goes exactly when you say go, it just takes a while for it to get where it's going. With it's low top speed, low rates won't be needed by me. It's got plenty of elevator but lacks the "drill bit" style roll rate some are used to having on a flying wing, but it's still plenty sporty.
I realized when I got home that, though fully charged, the battery I used has seen better days. With a resting voltage of 11.4, it drops to 9.7V under a "full load" of just less than 6 amps.
Once the weather smooths out, I'll swap the quarter in the nose for a nickle, and get it trimmed in. With any luck, I might even be able to catch a thermal or three with it!
carlsoti is offline Find More Posts by carlsoti
Old Dec 16, 2012, 06:39 PM
carlsoti's Avatar
Joined Jun 2008
Today I got confirmation that this wing is light enough to thermal. Unfortunately, it also lacks the mass to help move it around efficiently, leaving me to chase the thermal down-wind, losing all the gains in the process.
I also remembered about a little GWS 7060 Slow Fly prop I had laying around. I was hoping it might give the plane a little more pep. As it turns out, it just sucked up more amps, crushing the voltage of my worn out packs. I ended up at just over 80W, but no more speed, so I'll likely switch back to the 7x.3.5 for a bit over 60W, and better flight times.
Old Dec 28, 2012, 04:14 AM
Joined Dec 2012
I have a Swift II in a typical config. I noticed the other day when doing some low fly bys that it was rocking back and forth on lateral axis like it was fighting yaw.
Has anyone else seen this and is there a reason and a fix or just typical of a wing.
This is my first wing and it does fly great and takes a lot of abuse.
BD700 is offline Find More Posts by BD700
Old Jan 07, 2013, 07:16 PM
Firepower
Firepower's Avatar
North Brisbane, Australia
Joined Mar 2010
There are two things that normally cause what you described.
One is the c of g too far back or just flying too slow. If too slow maybe you were flying with the wind and your air speed was too slow even though you seemed to be flying quite fast..
Firepower is offline Find More Posts by Firepower
Old Jan 23, 2013, 12:52 PM
Czech Republic, Hlavní město Praha, Prague
Joined Jan 2013
Hi, I'm building my first Swift and I do not like a tiny bit those original winglets. Has anyone tried Ritewing style winglets on his Swift? Thanks
Majki is offline Find More Posts by Majki
Old Jan 23, 2013, 01:10 PM
United States, FL, Palm Beach
Joined Jan 2011
You can try whatever you want, there's no 'wrong' way. If it doesn't fly right, just try again.
viper522 is offline Find More Posts by viper522
Old Jan 23, 2013, 01:30 PM
Home of A-10 - Farmingdale NY
boiko's Avatar
United States, NH, Londonderry
Joined Dec 2006
A good fast setup for a Swift II..?
I know the Swift II is not really designed to be a fast wing.....for that I would fly my Ritewing or F-27Q.
But what suggestions do you guy's have for a faster setup (Motor,Prop and ESC) on the Swift II.
Within reason, what would be a good fast Swift II setup?
-mike-
boiko is offline Find More Posts by boiko
Old Jan 26, 2013, 04:52 AM
Firepower
Firepower's Avatar
Joined Mar 2010
-mike-
I was sick of the problems with my smaller motor on the Swift 2 so am currently installing a RC Timer 2836-6 1500kv. I have one on a HEAVY ElleBee with a 3000mah LiPo and it makes it go a reasonable speed and that is a bigger wing.
http://rctimer.com/index.php?gOo=goo...1&productname=
I am just going to do the AMP readings now and see how the c of g goes. I am not after a fast wing as I will be doing FPV but it should go quite fast. If I want faster I suppose I could go from a 3S to 4S LiPo. That would be fast and the motor can take it.
But if you want fast I would get a motor no heaver than mine but a 2700kv one. The reason I liked the RC Timer motor was it was very quiet compared to the 2500kv motors we were using.
Someone else may be able to provide details of a fast full setup.
Old Jan 26, 2013, 01:42 PM
UAV.APM's Avatar
United Kingdom, England
Joined Jan 2013
Hi guys, I've only flown my Swift for about 2 hours and already my ailerons have broken from the constant movement. They were very thin from the offset but I was expecting it to last a little longer then only 2 hours flight time.
Does anyone have any recommendations for a stronger wing setup that wont just fall apart on me? I was thinking more of a surf board type material if such a thing exists?
UAV.APM is offline Find More Posts by UAV.APM
Old Jan 27, 2013, 01:44 PM
S.E. Michigan
Joined Feb 2006
My elevons broke free too but only after a good long time and plenty of crashes. I just taped them all the way across with Blenderm and then added 3 or 4 strips running front to rear per side. These front to rear hinges are one inch in width.
A friend makes hinges on his EPP planes by using Welder glue. He learned this method when he built a 3D Hobbies foamie. Suggest you check their web site. It may not sound like it would work but he's been flying that plane for 2 seasons now and they are perfect. They look good too because you hardly notice them.
Lost_Dawg is offline Find More Posts by Lost_Dawg
Old Jan 29, 2013, 05:11 AM
Firepower
Firepower's Avatar
Joined Mar 2010
Some people cut them off from new as they do not like the foam hinge and tape them on.
I just use wide fiberglass tape on top and bottom of the wing on most of my bigger planes. Lost_Dawg just mentioned he uses Blenderm tape which is lighter and you can hardly notice it on the wing. On the mini wings like MiniSwift the fiberglass tape is too heavy so I use Blenderm tape. hobbyking.com now sell Blenderm tape as it is expensive from the chemist. http://www.hobbyking.com/hobbyking/s...win_Pack_.html
When taping the underside of the wing you must put the elevon up fully before you put the tape on and when doing the top have the elevon down as far as possible. HK have different sizes of fiberglass tape. Here is a 24mm one. I use the 50mm on elevons.but could go a bit smaller. Some use the narrow one and just put three strips to hold on the elevon but I go full length.
http://www.hobbyking.com/hobbyking/s...m_x_50mtr.html
I also just worked out if the tape does not stick spray on contact adhesive on the foam and if you put the tape on when the contact is still wet, it is very hard to get off which is good.
Discussion Good setup for a MSComposit Swift II ? myrslakt Foamies (Kits) 4 Oct 10, 2009 02:30 PM
Video Swift II Maiden Sim69 Electric Plane Talk 3 Jan 27, 2007 11:32 PM
Sold Swift II Airbrush line British Scheme TreeFlyer Aircraft - Electric - Airplanes (FS/W) 0 Jan 05, 2007 10:58 PM
Discussion Swift II from MS Composit? db1 Flying Wings 14 Dec 11, 2006 07:13 PM
Discussion My Swift II + Question highboy Flying Wings 2 Nov 29, 2006 11:05 AM
