Old Jun 12, 2012, 12:33 PM
Aero Andy is offline
Find More Posts by Aero Andy
ExPat
Aero Andy's Avatar
Spain, Murcia, Mazarrón
Joined Apr 2010
Originally Posted by tk240381 View Post
Somewhere in Europe you can get a hold of the Emax motors?
Originally Posted by danny.act View Post
Hi tk
Danny's right brc have that motor and a good range of other parkfly motors, but I bought some 2812's from Giant Shark (Giantcod) in the UK, the same motor but cheaper. £4.91 each ...
http://www.giantshark.co.uk/cf2812-1...otor-p-52.html
Aero Andy is offline Find More Posts by Aero Andy
Old Jun 12, 2012, 04:51 PM
stuglas69 is offline
Find More Posts by stuglas69
Joined Jul 2010
I am about to order my swift along with the following,
HXT900 servos
Spektrum orange rx
3mm prop saver
Turnigy nano tech 850mah 3s
Hobbyking ss 25-30a ESC
1534kv brushless motor
stuglas69 is offline Find More Posts by stuglas69
Old Jun 12, 2012, 07:32 PM
flitelab is offline
Find More Posts by flitelab
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
That is a small lipo for a swift ii. I run 1500-2200 packs on my popwing which is similar size. Unless your going for a really light setup maybe.
flitelab is offline Find More Posts by flitelab
Site Sponsor
Old Jun 12, 2012, 07:52 PM
Joined Jul 2010
yes, I am wanting a lighter setup because I am planning to put my GoPro camera on the plane.
Old Jun 14, 2012, 04:10 PM
tk240381 is offline
Find More Posts by tk240381
Norway, Oslo
Joined Apr 2011
Any HobbyKing equivalents for the motors suggested?
tk240381 is offline Find More Posts by tk240381
Old Jun 14, 2012, 11:04 PM
ExPat
Aero Andy's Avatar
Joined Apr 2010
Hi tk
Hobby King sell that 2812 motor also. http://hobbyking.com/hobbyking/store...idproduct=5423
Andy
Old Jun 17, 2012, 09:27 AM
RCICE is offline
Find More Posts by RCICE
RCICE's Avatar
Joined Oct 2010
Hi, i am looking to build a swift to do some aerial whit my gopro, now i don't want any super vertical but i has to be able to care the gopro around nice, so would this motor work http://www.hobbyking.com/hobbyking/s...er_1450kv.html whit a 7x4 prop, 3s and a 30a esc?
RCICE is offline Find More Posts by RCICE
Old Jun 17, 2012, 10:18 AM
ExPat
Aero Andy's Avatar
Joined Apr 2010
Yes that's a great motor for the Swift. A 7x4 prop would be perfect, and if you want more thrust try a 8x4.3, and for more speed 7x6. Please post some photos or a video once you've got it all finished, good luck with the build.
Andy
Old Aug 14, 2012, 09:10 PM
oldfish is offline
Find More Posts by oldfish
FLYING Better Than Drugs
oldfish's Avatar
Thonotosassa, FL
Joined May 2007
Has any one tried to add rudder control to a swift ll and if so how did it work.
Thanks for any help Bob
oldfish is offline Find More Posts by oldfish
Old Aug 14, 2012, 10:58 PM
ExPat
Aero Andy's Avatar
Joined Apr 2010
Sorry Bob, I haven't tried, but just like you, I'd like to know too..
Andy
Old Aug 17, 2012, 05:09 AM
Romis is offline
Find More Posts by Romis
Joined Aug 2012
Hi, I am just building my Swift, but I would like to practice flying with wing on simulator. Does anybody has Swift (or other wing) in Phoenix or AFPD?
Thanks.
Romis is offline Find More Posts by Romis
Old Aug 31, 2012, 05:27 AM
Dworf is offline
Find More Posts by Dworf
Joined Dec 2007
Hello all,
I have an Swift II which is reinforced with carbon rod that goes through entire wing and on elevons.
I have an issue with it tho.
At high speed it starts to roll to the left hard. When i push the stick to right to compensate it does not help much just a little it still goes into an death roll to the left. Only way to save the swift is to cut the throttle and wait few seconds so that speed goes down then i can control the plane normally.
Anyone else had same issues? how did you solve it? any ideas?
thanks all
Dworf
Dworf is offline Find More Posts by Dworf
Old Aug 31, 2012, 05:53 AM
ExPat
Aero Andy's Avatar
Joined Apr 2010
Originally Posted by Dworf View Post
Hello all,
thanks all
Dworf
Hi Dwolf
Obviously you have made sure that your elevons are aligned and not loose. So this problem sounds like your motor thrust line is off, I'm sure it's nothing to do with your carbon reinforcement. While standing behind your Swift, make sure that your motor is aligned straight along the centre line, you could consider adding 3-4 degrees of right thrust, this should prevent the wing from wanting to roll left. Hope this helps, let us know.
Andy
Old Aug 31, 2012, 09:37 AM
Dworf is offline
Joined Dec 2007
Originally Posted by Aero Andy View Post
Hi Dwolf
Andy
hey Thanks for the info that sounds actually really logical will try it out!
thanks again
Old Sep 03, 2012, 07:30 PM
Hill Top Flyer is offline
Find More Posts by Hill Top Flyer
Hill Top Flyer
Hill Top Flyer's Avatar
United States, WA, Twisp
Joined Jan 2010
Swift 2
Hi,
I've been flying my Swift 2 this summer and love it! I added a washer on the right side of the motor to add some right thrust. When I started to fly the wing with 3s, no thrust washer, it did the same left turn at high speed and the only way to recover was to pull the power back. I then started flying with 2s and all was fine at WOT, but too slow. SO, the thrust washer solved the problem. We always put right thrust and down thrust on a nitro plane to counteract the torque.
I also added carbon to the elevons and straping tape to the wing as it helps to firm it up. Great plane and lots of fun to fly.
HTF
Hill Top Flyer is offline Find More Posts by Hill Top Flyer
Discussion Good setup for a MSComposit Swift II ? myrslakt Foamies (Kits) 4 Oct 10, 2009 02:30 PM
Video Swift II Maiden Sim69 Electric Plane Talk 3 Jan 27, 2007 11:32 PM
Sold Swift II Airbrush line British Scheme Twinkletoze Aircraft - Electric - Airplanes (FS/W) 0 Jan 05, 2007 10:58 PM
Discussion Swift II from MS Composit? db1 Flying Wings 14 Dec 11, 2006 07:13 PM
Discussion My Swift II + Question highboy Flying Wings 2 Nov 29, 2006 11:05 AM
