Old May 24, 2012, 01:43 AM
Lammergier is online now
Find More Posts by Lammergier
Bone Breaker
Lammergier's Avatar
Dallas , Texas, United States
Joined Oct 2002
Hot glue sticks to epp like crazy good. Yes it is heavery than most other glues but you only need it in a couple of places and don't use big blogs of it and its quick and easy. I have built dozens of light swifts with it.
Lammergier is online now Find More Posts by Lammergier
Old Jun 11, 2012, 12:25 PM
tk240381 is offline
Find More Posts by tk240381
Norway, Oslo
Joined Apr 2011
Hey all, just got a Swift II and looking for a good motor and ESC setup for this. I already have the servos (some HXT900 should do?). Would like a suggestion for a good motor which is relatively fast.
I've got loads of 3S 2200 mAh batteries and some 3S 850 mAh and 3S 1000 mAh. So would prefer to get something which fits that. I have an ESC (DragonSky 30A). No info on that one, so if anybody know if it's up for it, or if I should just get a plush.
Would like to order everything I need from HobbyKing. Thanks. :-)
tk240381 is offline Find More Posts by tk240381
Old Jun 11, 2012, 12:40 PM
gsantos_pt is offline
Find More Posts by gsantos_pt
gsantos_pt's Avatar
Portugal
Joined Feb 2011
Hello
I had tested 3 motors yet. 980kv 9x5 , 1900kv 7x6, 2200kv 6x4
Now I'am using the last one with a 1300mah 3s and hxt 900 servos. The plane it's fast enought with this configuration and has a really nice vertical climbs . You will need to add some carbon spars to elevons because on full throttle the epp elevons are not rigid enought. 30A esc it's the same that I have. The flight time normal is about 10-12 min but you can go to 15 min or more. Link for motor: http://www.hobbyking.com/hobbyking/s...dProduct=12919
And a video for you have an idea of the speeds that you will get:
MS Composit Swift 800mm with LED's (3 min 45 sec)
With my old 980kv motor
MS Composit Swift - Flying in the afternoon (3 min 36 sec)
happy landings
gsantos_pt is offline Find More Posts by gsantos_pt
Old Jun 11, 2012, 01:35 PM
tk240381 is offline
Norway, Oslo
Joined Apr 2011
Originally Posted by gsantos_pt View Post
Hello
http://www.youtube.com/watch?v=XZl8j...&feature=g-upl
happy landings
Great. The motor fits right on? Do you have a picture of your wing closeup? Want to see how you did it with the carbon spars on the elevons ++. :-)
Old Jun 11, 2012, 05:07 PM
gsantos_pt's Avatar
Portugal
Joined Feb 2011
I dont have the model with me now (only at the weekend). I didn't make modifications on the motor mount. I can show you a example:
EPO Parkjet Hobbyking mini Skyfun extrem modify and fast (7 min 43 sec)
see at 1min40s. You can glue it with CA (foamsafe)
Old Jun 11, 2012, 11:18 PM
stuglas69 is offline
Find More Posts by stuglas69
Joined Jul 2010
I am going to be getting the swift II. I am lost on the setup I want, other than the servos. I want something not to fast since I am a little newer. Any help would be appreciated.
stuglas69 is offline Find More Posts by stuglas69
Old Jun 12, 2012, 08:11 AM
Aero Andy is offline
Find More Posts by Aero Andy
ExPat
Aero Andy's Avatar
Spain, Murcia, Mazarrón
Joined Apr 2010
Here's my set up, and it's still going strong. The performance is good, take a look at the video to see.
Andy
Motor: Emax 2812 1500kv
ESC: Turnigy 25amp
Prop: GWS 7x6
Servos: HXT 9g
Swift II (2 min 25 sec)
Aero Andy is offline Find More Posts by Aero Andy
Old Jun 12, 2012, 09:19 AM
Joined Jul 2010
Thanks for the response, what hardware do I need to mount the prop and the motor to the mount. Also what would I need for a break away prop? Is the video on 2s or 3s?
Old Jun 12, 2012, 09:47 AM
ExPat
Aero Andy's Avatar
Joined Apr 2010
To mount the motor to the mount, you just need 2mm diameter screws, and for the prop, these or similar prop savers for a 3mm shaft http://hobbyking.com/hobbyking/store...idProduct=8240
The video it's flying on a 3s 1000mAh
Old Jun 12, 2012, 10:15 AM
Joined Jul 2010
alright thanks, what flight time do you get? I am going to get a 850mah.
Old Jun 12, 2012, 10:29 AM
mthomas is offline
Find More Posts by mthomas
Hi I am Mark & I am an addict
mthomas's Avatar
USA, KY, Louisville
Joined May 2007
I am flying with the same motor/prop as Aero Andy but am using a 3s1000 lipo. We are vacationing on the beach right now and I just came in from about 15 minutes of flying over the surf. Only went wide open a few times to get up high then cut it off and glide around a bit. I tried to get into the same air as the birds but the air was bumpier than I prefer to fly in.
It's a good light setup, great for casual flying and plenty of power to climb.
Mark
mthomas is offline Find More Posts by mthomas
Old Jun 12, 2012, 12:18 PM
Joined Jul 2010
Is this the esc your talking about?
http://www.hobbyking.com/hobbyking/s...less_ESC_.html
Old Jun 12, 2012, 12:28 PM
tk240381 is offline
Norway, Oslo
Joined Apr 2011
Andy
ESC: Turnigy 25amp
Prop: GWS 7x6
Servos: HXT 9g
https://vimeo.com/36637951
Somewhere in Europe you can get a hold of the Emax motors?
Old Jun 12, 2012, 12:50 PM
danny.act is offline
Find More Posts by danny.act
Electrif(r)ied nitroman
danny.act's Avatar
België, Vlaams Gewest, Putte
Joined Jun 2004
http://www.brchobbies.co.uk/?page=shop&item=420
danny.act is offline Find More Posts by danny.act
Old Jun 12, 2012, 01:28 PM
ExPat
Aero Andy's Avatar
Joined Apr 2010
That's the same make, mines the 25amp, although the Hobby King 25amp SS series is also very good, I have a few of these and they're super cheap at $5.99.
http://hobbyking.com/hobbyking/store...5_30A_ESC.html
Andy
Discussion Good setup for a MSComposit Swift II ? myrslakt Foamies (Kits) 4 Oct 10, 2009 03:30 PM
Video Swift II Maiden Sim69 Electric Plane Talk 3 Jan 28, 2007 12:32 AM
Sold Swift II Airbrush line British Scheme Twinkletoze Aircraft - Electric - Airplanes (FS/W) 0 Jan 05, 2007 11:58 PM
Discussion Swift II from MS Composit? db1 Flying Wings 14 Dec 11, 2006 08:13 PM
Discussion My Swift II + Question highboy Flying Wings 2 Nov 29, 2006 12:05 PM
