Old May 05, 2012, 04:49 PM
mrmurder1975 is offline
Find More Posts by mrmurder1975
mrmurder1975's Avatar
Joined Dec 2007
Originally Posted by Aero Andy View Post
Great news, please don't forget to post a picture or two of your completed Swift, or even a flight video if you have chance.
All the best
Andy
i certainly will! thanks andy.
oh,one more question....can you buy the stock motor mounts separate anywhere or do they only come with the kit? mine is looking a bit tatty and i would like to stick a nice new one on there,it kinda lets the look of the wing down as it is... thanks.
mrmurder1975 is offline Find More Posts by mrmurder1975
Old May 06, 2012, 01:22 AM
Aero Andy is offline
Find More Posts by Aero Andy
ExPat
Aero Andy's Avatar
Spain, Murcia, Mazarrón
Joined Apr 2010
Here's the link for a new mount, http://www.mscomposit.com/airplanes/...ion-mount.html
You could always paint your old mount, I did. In fact my whole wing was looking a bit tatty, so I spray painted the lot, it certainly stands out in the sky now.
Andy
Aero Andy is offline Find More Posts by Aero Andy
Old May 06, 2012, 04:41 AM
Joined Dec 2007
excellent,thanks andy! that is one smart looking wing.....what kind of spray paint did you use to cover that mate?
Old May 06, 2012, 07:14 AM
ExPat
Aero Andy's Avatar
Joined Apr 2010
Thanks, I use Model Color paints, I water them down by a third so I can spray them on.
Andy
Old May 06, 2012, 08:40 AM
carlsoti is offline
Find More Posts by carlsoti
hass-alfed and bass-ackwards
carlsoti's Avatar
United States, AZ, Chandler
Joined Jun 2008
I've got a Hacker SkyCarver, which I believe is a gussied up SwiftII. http://www.aero-model.com/Hacker-Sky...m-Edition.aspx
It's my first flying wing, and I plan on going with a "light" set-up. 1700kv BW, GWS HD 7x3.5, etc, etc...
I've got a BUNCH of different adhesives available. Of the following, which do you guys think will produce the lightest, yet most effective bond on the EPP?
CA, PU(gorilla glue, both white and original), West Systems G/flex laminating resin, "Welders glue", standard BSI epoxy 5min, 15min, and 20min finishing.
For ultimate strength, I think the G/flex with a strip of FG or CF around the joint, DLG style, would be the way to go. But I don't plan on hot rodding this thing. Noise at our field is a big issue. I'm certain to get a few dirty looks just showing up with a wing, regardless of what motor it has.
Would pre-foaming some PU so it doesn't squish out be overkill?
I've heard of some say to stay away from CA when building these. If I only plan to putz around with a li'l BW and catch a few thermals here and there, wouldn't a decent CA joint be good enough?
All thoughts and opinions are appreciated.
carlsoti is offline Find More Posts by carlsoti
Old May 07, 2012, 07:22 AM
Joined Dec 2007
i have used ca on mine without problems,although ca can sometimes make quite a brittle bond. i have found uhu por gives a much stronger bond between the surfaces (apply to both surfaces,leave to cure until dry to the touch,10/15 mins, and then press together,but you prob know that already!). got my uhu por on the bay.
Old May 07, 2012, 09:53 AM
ExPat
Aero Andy's Avatar
Joined Apr 2010
Yep, plus one on the UHU por, that's what I use.
Andy
Old May 07, 2012, 03:45 PM
Joined Dec 2007
my hk ss 25/30 esc is getting really hot on my current setup no matter what prop i use : 1300 3s lipo,2x hxt900,orange 6ch rx, 1500kv outrunner, apc 7x5 prop so i figure i may have a dodgy esc (have the same esc on one of my axn using an apc and 2200 lipo and thats fine) so am going to replace it with this (lighter than the ss too) 20a esc
http://robotbirds.com/catalog/produc...oducts_id=1378
just wondered if anyone has used one before? specs seem quite good and according to the site its the latest version/firmware.
thanks
Old May 07, 2012, 04:40 PM
carlsoti is offline
carlsoti's Avatar
Joined Jun 2008
Thanks guys. I've got some Welders Glue contact cement. I guess I'll go with that. It get's hot here in the desert, so I think that's less likely to get brittle and crack than CA, or even epoxy.
Do you know who manufactures that ESC? It could be a rebranded hobbywing, ZTX, or mystery ESC.
Old May 07, 2012, 05:07 PM
Joined Dec 2007
interesting you should say that mate,as the programming card that they say is used to programme it looks to be the same as the one used for the turingy esc's... this is the one they advertise for it....
http://robotbirds.com/catalog/produc...oducts_id=1385
Old May 21, 2012, 02:32 PM
gsantos_pt is offline
Find More Posts by gsantos_pt
gsantos_pt's Avatar
Portugal
Joined Feb 2011
Hello guys
I mounted yesterday about 60 leds on my Swift for fly in the dark
MS Composit Swift 800mm with LED's (3 min 45 sec)
Happy Landings
gsantos_pt is offline Find More Posts by gsantos_pt
Old May 22, 2012, 04:11 AM
IceWind is online now
Find More Posts by IceWind
throw new IOPilotException();
IceWind's Avatar
Ireland, County Dublin, Dublin
Joined Feb 2005
Andy
That is a really cool paint scheme.
I had the black stripes on mine made with tape and it really helps.
IceWind is online now Find More Posts by IceWind
Old May 22, 2012, 07:08 AM
ExPat
Aero Andy's Avatar
Joined Apr 2010
Originally Posted by gsantos_pt View Post
Hello guys
http://www.youtube.com/watch?v=XZl8j...&feature=g-upl
Happy Landings
Great video, the LED's look really cool. Well done my friend.
Andy
Old May 22, 2012, 07:10 AM
ExPat
Aero Andy's Avatar
Joined Apr 2010
Hi IceWind
Thanks for the compliment, I'm glad the stripes worked well for you too.
Cheers
Andy
Old May 22, 2012, 01:41 PM
GregSilver is offline
Find More Posts by GregSilver
GregSilver's Avatar
United States, FL, Plantation
Joined Nov 2005
Hey guys, Airbagit and I have made some cool products for the Swift.
http://www.ezfpv.com/?page_id=101
The motor mount is a direct replacement for the stock one...and the skids are just badass.
GregSilver is offline Find More Posts by GregSilver
Discussion Good setup for a MSComposit Swift II ? myrslakt Foamies (Kits) 4 Oct 10, 2009 02:30 PM
Video Swift II Maiden Sim69 Electric Plane Talk 3 Jan 27, 2007 11:32 PM
Sold Swift II Airbrush line British Scheme Twinkletoze Aircraft - Electric - Airplanes (FS/W) 0 Jan 05, 2007 10:58 PM
Discussion Swift II from MS Composit? db1 Flying Wings 14 Dec 11, 2006 07:13 PM
Discussion My Swift II + Question highboy Flying Wings 2 Nov 29, 2006 11:05 AM
