Old Feb 29, 2012, 01:32 PM
IFlyRCs is offline
Find More Posts by IFlyRCs
ICrashRCs
United States, TN, Memphis
Joined Jun 2011
Give Foam Tac a shot - really good stuff.
http://www.rcfoam.com/product_info.p...f0674f62f61e4d
Don't like Ultimate RC Foam Glue.
IFlyRCs is offline Find More Posts by IFlyRCs
Old Mar 04, 2012, 06:21 PM
stallion explosi is offline
Find More Posts by stallion explosi
United Kingdom, England, Hackney
Joined Aug 2011
is anyone using laminating film on swift 2s? if i get one i'd like to strengthen it a bit, lam is great for that and would preserve the graphics. is it a good idea? any reason not to?
stallion explosi is offline Find More Posts by stallion explosi
Old Mar 05, 2012, 08:51 AM
teslahed is offline
Find More Posts by teslahed
Joined Jul 2008
I used laminating film on my full sized raven (swift clone). It works fine but adds some weight. Pick a film that isn't too thick and you should get good results. I spray painted my wing underneath the film and i don't seem to have any seperation problems - i re-iron it after bad crashes though.
Bear in mind it adds weight to the wing surface and there is more wing surface behind the ideal centre of gravity position than in front, so by laminating your wing you will make getting the centre of gravity forward far enough more difficult, especially if you fit too heavy a motor on the back. As long as you are careful with your weights you should be ok.
If you do it right you will probably get a faster, tougher, more streamlined wing but you will probably lose some slow speed performance due to the increased wingloading. If you get it wrong you'll end up with a wing that won't balance unless you sick half a ton of lead in the nose.
http://imageshack.us/photo/my-images...coveringc.jpg/
http://imageshack.us/photo/my-images/6/14finishedc.jpg/
Laminating the EPP wingtips and elevons definitely stiffens them up.
Link to pics of build
The wing is now almost 2 years old and still flies great. None of my unlaminated wings have lasted as well (or been flown as much).
Link to where i got my laminating film from.
teslahed is offline Find More Posts by teslahed
Old Mar 06, 2012, 05:09 PM
Joined Aug 2011
great stuff thanks for that. out of interest, what do you do about the elevons? do you cut them off, cover and re-attach?
Old Mar 06, 2012, 06:14 PM
teslahed is offline
Joined Jul 2008
Yeah i did exactly that. I used crossweave fibreglass tape to re-attach them.
However you might get better performance using the right grade of balsa wood - I haven't tried that myself.
Old Mar 09, 2012, 04:03 PM
GregSilver is offline
Find More Posts by GregSilver
GregSilver's Avatar
United States, FL, Plantation
Joined Nov 2005
why are you guys adding so much weight to te swift?
if you want, add a small CF/fiberglass rod into the foam.
I fly my swift with a 3S 2200mah, Eagletree logger v4, ETOSD, GPS, Guardian, vTX, camera...etc etc and the only thing i did was add support rod in the center and a 2" wide strip of laminate on the leading edge. I can do insane aerobatics while panning my camera to the wing and i dont see ANY flex.
GregSilver is offline Find More Posts by GregSilver
Old Mar 16, 2012, 03:36 PM
ands is offline
Find More Posts by ands
wottree
United Kingdom, England, Exeter
Joined Nov 2011
Guys, anyone tried detachable winglets? If so how? Looking to make her flat for transport.
Ands
ands is offline Find More Posts by ands
Old Mar 16, 2012, 03:37 PM
Aero Andy is offline
Find More Posts by Aero Andy
ExPat
Aero Andy's Avatar
Spain, Murcia, Mazarrón
Joined Apr 2010
Ands
I like it, that's a good idea....
Andy
Aero Andy is offline Find More Posts by Aero Andy
Old Mar 16, 2012, 09:55 PM
ands is offline
wottree
Joined Nov 2011
Andy
Hay Andy, loving the name
Have yet to receive my Maxi so its all just research at the moment. Was thinking of cutting some ply to the shape of the wing ends, gluing them on, then working on a nylon nut/bolt system. I have read people suggesting Velcro!!! Aint no way I am doing that! How can that be strong enough?...I could be wrong though.
Am I right in saying the underside of the swift 2 has a hollow compartment in the middle to put electrics or did you make it.? I am going to try and combine a few mods from diffrent wings. I like how the ritewing is very clean looking with a flat middle and hidden electrics. I also like the way you can mount a GoPro right in the nose and not stuck on the top. I just don't get why a lot of guys just slap tape over the batteries to hold them in place, to me it looks ugly.
But hay, what do I know? I haven't even got mine yet!
Anyway, just ideas at the mo.
Ands, aka Andy
Old Mar 17, 2012, 01:23 AM
ExPat
Aero Andy's Avatar
Joined Apr 2010
Hi Andy
The winglets, what about a hinged surface on the underside where it meets the wing, maybe with tape or a hotglue hinge, so the winglet can fold back flat against the underneath of the main wing. It would give extra strength along that edge, and also to what ever fixings you use to hold it on.
There were a small recess's in the underside of the foam on the Swift II, but for my gear they were in the wrong places to get the CG right, so I filled those in and made my own. I also didn't want the battery etc hanging exposed over the surfaces, so I made a little open compartment to protect the gear on landings, and also helps with streamlining.
Andy
Old Mar 17, 2012, 11:09 AM
ands is offline
wottree
Joined Nov 2011
like the idea of the hinges Andy, will give it some more thought.
Have you got any pics with the mod on the underside? looking for inspiration.
Cheers
ands
Old Mar 20, 2012, 07:01 PM
Dallin is offline
Find More Posts by Dallin
Joined Aug 2011
Im just building a one of these wings. How did you guys make sure that the motor mount was lined up correctly? Is it going to make any difference if it is just a tiny bit off?
Thanks in advance!
-Dallin
Dallin is offline Find More Posts by Dallin
Old Mar 20, 2012, 10:04 PM
Firepower is online now
Find More Posts by Firepower
Firepower
Firepower's Avatar
North Brisbane, Australia
Joined Mar 2010
Thanks in advance!
-Dallin
Mount the prop on the motor and the motor to the mount and when you glue it on you can make the tips of the prop even each side.
Also with the prop on you can tell if it is parallel to the rear of the wing just in case the tips are a bit out but they should not be.
You can do this all before you glue the mount to the wing and check everything first. Mark the mount on the wing with a pen as a guide for when you glue it.
Everyone has their idea of glue to use for the mount to the wing. I used THICK CA from HK and put a lot on and I even went around all edges also. I use the kicker as it sets straight away. It will never come off.
Also in theory I guess the prop should be a bit off to one side to allow for the prop turning etc. I can tell you exactly which way it is suppose to go on something like a EasyStar but do not know on a flying wing. On the small pusher planes (do not know about wings) if you go the wrong way it really messes up the way it flies. Just do it straight unless someone advises otherwise.
Firepower is online now Find More Posts by Firepower
Old Mar 21, 2012, 02:10 AM
Dallin is offline
Joined Aug 2011
Thanks for the help Firepower. I got it mounted. Just got it as straight as possible. I used Welders glue and then Medium CA w/ kicker around the edges. After it dried it was solid. I was pulling on it and Im pretty sure it would rip the chunk of the wing it is attached to before the mount came off.
Old Apr 01, 2012, 01:00 PM
Davidpe is offline
Find More Posts by Davidpe
Davidpe's Avatar
United States, OR, Portland
Joined Feb 2012
I would love to see a picture of your setup if you get a moment. Your videos are awesome.
Thanks!
Davidpe is offline Find More Posts by Davidpe
Discussion Good setup for a MSComposit Swift II ? myrslakt Foamies (Kits) 4 Oct 10, 2009 02:30 PM
Video Swift II Maiden Sim69 Electric Plane Talk 3 Jan 27, 2007 11:32 PM
Sold Swift II Airbrush line British Scheme Twinkletoze Aircraft - Electric - Airplanes (FS/W) 0 Jan 05, 2007 10:58 PM
Discussion Swift II from MS Composit? db1 Flying Wings 14 Dec 11, 2006 07:13 PM
Discussion My Swift II + Question highboy Flying Wings 2 Nov 29, 2006 11:05 AM
