Old Jan 27, 2012, 03:10 AM
Fer is offline
Fer
Find More Posts by Fer
Fer
Travelling far and wide
Fer's Avatar
Nederland
Joined Jul 2009
outside hand Frisbee style,
I hold the right wing with my left hand, power it up to the point that i feel the wing wanting to fly out of my hand and then gently throw it.
Ones i get to maiden it I'll try to get a friend of mine to make a vid.
Fer is offline Find More Posts by Fer
Old Jan 27, 2012, 02:56 PM
Lammergier is offline
Find More Posts by Lammergier
Bone Breaker
Lammergier's Avatar
Dallas , Texas, United States
Joined Oct 2002
I have a new swift for sale in electric planes if anybody is looking for one.
Lammergier is offline Find More Posts by Lammergier
Old Jan 31, 2012, 05:05 PM
Diane@lazertoyz is offline
Find More Posts by Diane@lazertoyz
Diane@lazertoyz's Avatar
United States, OH, Eastlake
Joined Jan 2007
Popwings
Check out the Popwings, they are only 4 inches wider than the Swifts, and the mini Popwings are only 2 inches bigger then the mini swifts-
http://www.lazertoyz.com/shop/Planes/popwing.htm
prices are lower also! but they fly just the same! great planes!
Diane
Lazertoyz
Diane@lazertoyz is offline Find More Posts by Diane@lazertoyz
Old Jan 31, 2012, 08:28 PM
Firepower is offline
Find More Posts by Firepower
Firepower
Firepower's Avatar
North Brisbane, Australia
Joined Mar 2010
Diane
Lazertoyz
Is this the same one also?
http://www.hobbyking.com/hobbyking/s...00mm_ARF_.html
Firepower is offline Find More Posts by Firepower
Old Feb 01, 2012, 08:06 AM
Joined Jan 2007
It is not the same manufacturer, and we have not tried them- anyone else have any info on these- are they as durable?
Diane
Old Feb 02, 2012, 05:44 AM
Firepower
Firepower's Avatar
Joined Mar 2010
Diane
I do not know how good the HK ones are yet. I just quickly read your post and did not realise you are selling them or I would not have been so rude as to mention the other ones.
Another plug for yours:
Old Feb 02, 2012, 07:48 AM
Joined Jan 2007
That's ok- there is room for a lot of vendors, but I wonder if they are the same- if someone gets one, let us know your thoughts..
Thanks!
Diane
Old Feb 12, 2012, 06:46 AM
Aero Andy is offline
Find More Posts by Aero Andy
ExPat
Aero Andy's Avatar
Spain, Murcia, Mazarrón
Joined Apr 2010
My Swift II, I got this for a Christmas present, and I'm really impressed at how well it flies. I'll take a video and post later.
Andy
Motor: Emax 2812 1500kv
ESC: Turnigy 25amp
Prop: GWS 7x6
Servos: HXT 9g
Aero Andy is offline Find More Posts by Aero Andy
Old Feb 14, 2012, 05:16 AM
ExPat
Aero Andy's Avatar
Joined Apr 2010
Swift II (2 min 25 sec)
Old Feb 21, 2012, 03:40 PM
Rabbern is offline
Find More Posts by Rabbern
Joined Feb 2012
Please dont kill me now but how is the Swift 2 compared with the Teksumo? In size and other .. can it use the same motors and props?
Rabbern is offline Find More Posts by Rabbern
Old Feb 22, 2012, 03:20 AM
Firepower
Firepower's Avatar
Joined Mar 2010
A couple of friends have just received them so will know soon how they go.
The two HK ones similar to the MiniSwift and the Swift are a couple of inches wider each so should be great. Just checked the Swift 2 is 800mm wide and the Tek is 900mm but a completely different shaped wing.
It depends what motor and prop you are using as to whether it will work on the "other one". My Turnigy 2730/3000 will power almost anything.
The Teksumo specs are:
15A~20A ESC
2208 1370kv or HK2818 1350kv Brushless Outrunner Motor
7x5 or 6x5 prop
800mAh~1000mAh 3s Lipoly Battery
That is pretty slow stuff so I'd say anything you have would power it.
What motor are you looking at using?
Old Feb 22, 2012, 06:21 AM
Rabbern is offline
Joined Feb 2012
http://www.hobbyking.com/hobbyking/s...or_1500kv.html
This one was i looking on/for.
Old Feb 22, 2012, 06:38 AM
Firepower
Firepower's Avatar
Joined Mar 2010
That would be a good motor for both planes. I bought one and was going to go to the slower KV motor but ended up trying a good 2S - 2200ma LiPo on my 3000kv one and it seems to go well still. So may stick to the high KV motor.
My 3000kv one is only suppose to go on a 2S anyway and goes good. I have all the heavy FPV stuff on it so I do not need a fast plane.
The motor you are talking about goes on a 2S or 3S LiPo but a 3S would be better.
Old Feb 22, 2012, 07:15 AM
Rabbern is offline
Joined Feb 2012
Umh what i picked to my cart on HK is Nano-tech 3s 1000mah 25-50c and 12 amp plush esc, the 2730 1500kv motor and some hxt900 servos. Is that good enough?
And a 7x3,5 prop.
Old Feb 22, 2012, 07:35 AM
Firepower
Firepower's Avatar
Joined Mar 2010
And a 7x3,5 prop.
That all should be good. The 12amp ESC is all that is required by the motor specs but I would have gone for at least the 18amp Esc but that is just me.
Time will tell if it is big enough but like I said what you got is suppose to be perfect.
All the stuff you got should be great.
There is a few tricks to putting it together. I mount my motor on the mount with a prop before I glue the mount with thick CA . That way it is easier to see if the mount is straight.
Discussion Good setup for a MSComposit Swift II ? myrslakt Foamies (Kits) 4 Oct 10, 2009 02:30 PM
Video Swift II Maiden Sim69 Electric Plane Talk 3 Jan 27, 2007 11:32 PM
Sold Swift II Airbrush line British Scheme Twinkletoze Aircraft - Electric - Airplanes (FS/W) 0 Jan 05, 2007 10:58 PM
Discussion Swift II from MS Composit? db1 Flying Wings 14 Dec 11, 2006 07:13 PM
Discussion My Swift II + Question highboy Flying Wings 2 Nov 29, 2006 11:05 AM
