Old Dec 07, 2006, 07:36 AM
Phiber Optik is offline
Find More Posts by Phiber Optik
Womb Drifter
Phiber Optik's Avatar
NC, USA
Joined Dec 2004
Originally Posted by db1
I was thinking of using a light slow setup. I have a power system left over from an old Slofly Micro 22. Slow with good acceleration. Might not work but I'm going to try it anyway.
db
Thats exactly how I would make mine. I have a 26g Strong CDR and an 8x6 just waiting to go onto one of them....
Phiber Optik is offline Find More Posts by Phiber Optik
Old Dec 09, 2006, 10:40 AM
myrslakt is offline
Find More Posts by myrslakt
Rotorhead
Sweden
Joined Jan 2006
Good setup?
I'm getting one of these wings (the small version) and I'm thinking of this setup:
The "stock" Swift Power Pack-300, it's a speed 300 geared 1:5 with a 8x6 prop...
JETI Jes 012, 12 amp ESC...
7,4v Lipos, 800 mAh, 15C...
Hitec Hs-55 servos...
What do you experienced people think?
Anything too wimpy or overkill?
Will it fit/balance nicely?
Opinions/suggestions?
myrslakt is offline Find More Posts by myrslakt
Old Dec 10, 2006, 07:00 AM
euromodels is offline
Find More Posts by euromodels
Sydney
Joined Nov 2004
Hi Myrslakt,
My first Swift had about the same setup (Speed 300 1:5,....). I didn't like it much. I had a lot of fun after switching to brushless.
Zdenel
euromodels is offline Find More Posts by euromodels
Old Dec 20, 2006, 08:21 AM
Cabbiee is offline
Find More Posts by Cabbiee
Netherlands
Joined Jul 2006
Does somebody know what a good light but powerfull budget brushless motor is for a Swift II?? And available in Europe.
Cabbiee is offline Find More Posts by Cabbiee
Old Dec 20, 2006, 08:33 AM
Cabbiee is offline
Netherlands
Joined Jul 2006
Would a Robbe Roxxy 2824/26 be something? It's a 1380 kV outrunner. It weights 48 Grams.
Or the 2824/34? That's a 1100 kV outrunner.
What will produce more power? A 2824/26 with 7x4 GWS prop. Or a 2824/34 with 8x4 GWS prop. And will it be enough for the Swift II??
Datasheet:
http://data.robbe-online.net/robbe_p...1_1-477826.pdf
Old Jan 22, 2007, 02:38 PM
db1 is offline
db1
Find More Posts by db1
db1
don betz
db1's Avatar
United States, OH, Cincinnati
Joined Aug 2004
Finally got mine flying today. I used HS-55's and a GWS 2205-15T with the GWS 15A ESC. I went cheap and it seems to work well. Oh, I'm running a GWS 8040 and a TP 2S1320 PL. Seems to work well. I need to increase my aileron throws to make it more fun but other than that it seems to be an OK setup, especially for the money!
db
db1 is offline Find More Posts by db1
Old Jan 22, 2007, 03:02 PM
endeavor_635650 is offline
Find More Posts by endeavor_635650
Crash Hard!!!
endeavor_635650's Avatar
Moultrie, Ga
Joined Jul 2004
I fly mine with a Hobby Lobby 400xt outrunner and it is awesome! Only a $25 motor! Unlimited vertical with a 3 cell Thunder Power 910 lipo and an APC 8x6 slow flyer prop. Also, two e-flite servos and a castle creations phoenix 10 esc. I had to add some ballast under the battery to make it ballance so, I think a 3 cell Thunder Power 1320 would be ideal. With the 910 mah Thunder Power I get 30 minutes of flying if I just cruise but only 10 minutes if a really ring it out. This is one of the best flying wings I have ever had. It has quickly become the club favorite and is replacing the old favorite, the gws slow stick. MS Composit hit a home run with this one!
Brian
endeavor_635650 is offline Find More Posts by endeavor_635650
Old Jan 23, 2007, 01:56 PM
db1 is offline
db1
db1
don betz
db1's Avatar
Joined Aug 2004
I tried it again today but with a 3S 1320 and an APC 5.1 x 4.5 (I think) and it was a bit more fun. I think I'll stick with the 3S setup for now.
db
db
Old Jan 26, 2007, 10:29 PM
db1 is offline
db1
db1
don betz
db1's Avatar
Joined Aug 2004
OK, more different set-ups tried.
I've come to like a 3S 910 and an APC 6x4. I've also cranked up the throws.
The thing is a riot with the CG about 3/8" behind the recommended position. The thing will almost loop in its length! I have the battery just press fit into the foam which is no longer adequate I found out when I ejected the battery after a full throttle dive and a full up elevator loop that ejected the battery and sent it at least 120'-130' away! The wing was at only about 10' AGL when it happened too. This thing is a blast and it went together CHEAP! Great bang for the buck!
db
Old Jan 28, 2007, 12:40 PM
myrslakt is offline
Rotorhead
Sweden
Joined Jan 2006
Maybe brushless is the way to go...
I can have the Swift II + AXi 2208/26 SILVER + JES12 ECO for about $130... sounds like a good deal to me!
But I don't understand if this setup is for 2 or 3 cells...?
Maybe both would be OK?
Old Jan 28, 2007, 10:13 PM
Crash Hard!!!
Moultrie, Ga
Joined Jul 2004
2 or 3 cells won't matter. The AXI performs well with both.
Brian
Old Jan 29, 2007, 08:14 AM
myrslakt is offline
Rotorhead
Sweden
Joined Jan 2006
Really? That's great!
I guess I'll have to prop up or down depending on voltage...
Any hints?
Old Jan 29, 2007, 09:27 AM
Crash Hard!!!
Moultrie, Ga
Joined Jul 2004
No, there is no need to prop down. The AXI 2208 series is very capable of handling an 8x6 all the way up to a 10x4.7 prop on two or three cells. I personally run an 8x6 on my swift with a three cell lipo and it has loads of power. Alternativly, it would still fly well with a two cell. You can't go wrong, it will fly very well with either setup.
Oh, the reason I run an 8x6 prop is because there isn't enough room for anything bigger.
Brian
Old Jan 29, 2007, 01:10 PM
myrslakt is offline
Rotorhead
Sweden
Joined Jan 2006
Thanks a lot Brian!
There seems to be no end to the good news!
I'll order this setup tonight, together with some 8x6 props... which I guess will be of the APC brand... would that be "plain vanilla" 8x6, 8x6e or 8x6sf...?
Old Jan 29, 2007, 02:49 PM
db1 is offline
db1
db1
don betz
db1's Avatar
Joined Aug 2004
I'm sure the AXI performs better but a hundred dollars better??? The GWS setup was only $30.
db
Discussion Good setup for a MSComposit Swift II ? myrslakt Foamies (Kits) 4 Oct 10, 2009 02:30 PM
Video Swift II Maiden Sim69 Electric Plane Talk 3 Jan 27, 2007 11:32 PM
Sold Swift II Airbrush line British Scheme Twinkletoze Aircraft - Electric - Airplanes (FS/W) 0 Jan 05, 2007 10:58 PM
Discussion Swift II from MS Composit? db1 Flying Wings 14 Dec 11, 2006 07:13 PM
Discussion My Swift II + Question highboy Flying Wings 2 Nov 29, 2006 11:05 AM
