Old Oct 03, 2010, 09:51 PM
cgoffa is offline
Find More Posts by cgoffa
cgoffa's Avatar
Joined Dec 2009
light glass
I am flying mine with 1/2 glass put on with wbpu, one short 1x6 carbon flat spar between the servos, and a little screamer, mounted to a magic motor mount glued on with goop, with a 3 cell 800mah lipo. I am at an all up weight of 10.4 ounces. For night flying i have 1 meter of hobby king blue leds on the top of the wing and one meter of amber on the bottom, the pic I am posting is from the NEAT fair, it is me flying in thru and around the saturday night fireworks display, credit for the photo goes to stan, I downloaded it from his post here on rcg.
The reason I replied, is that you can get a really strong, and stiff wing and never have to re-cover the tape again, PLUS the wbpu really brings out the graphics and makes the screen print pop.
Originally Posted by Diggs View Post
LOL, the so called manual is lame, but you don't need much with the Swift II. Mine fly's naked with no spar or tape. However, I don't see any problems with using the tape. I kinda like it flexy so when I schmack mother earth it bounces nicely. Another option would be to use twine / kite string, and cut a slit top and bottom directly over each other, but don't go all the way through. Slide in the string, apply thin CA and let it harden. This does wonders on stiffening. Have done this on several 3D EPP foamy models and it always impresses me how lite and strong it is.
Hope you enjoy it!
Diggs
cgoffa is offline Find More Posts by cgoffa
Old Oct 05, 2010, 08:05 PM
coinworker is offline
Find More Posts by coinworker
What's tomorrows forecast?
coinworker's Avatar
United States, IN, Goshen
Joined Jun 2009
Thanks for this thread guys...I just ordered the "swift patrol" wing from my LHS and now need to buy components. So i've looked around a bit in this thread and i've seen the recommendation from diggs on motor set up. i use the same motor(1500 i think) for my yak 55 and love it. i like the idea of keeping it light but i think i want a little more speed than the 2730 can deliver. does anyone have any other recommended tried and true motor, esc, battery, prop set ups for a little more omph? i prefer to order from HK or hobbypartz when it comes to components. also if one where to use tape what is the tape that i keep seeing that's being used... it looks like clear duct tape or something?
coinworker is offline Find More Posts by coinworker
Old Oct 05, 2010, 09:31 PM
Diggs is offline
Find More Posts by Diggs
Not your average DiggsyBear
Diggs's Avatar
Raleigh, NC
Joined Dec 2006
I would look at this..
http://www.gobrushless.com/shop/inde...=MD2505-C-1845
Diggs
Diggs is offline Find More Posts by Diggs
Old Oct 05, 2010, 09:41 PM
DaOldGuy is online now
Find More Posts by DaOldGuy
Flying Half Pound and Down
DaOldGuy's Avatar
United States, PA, Bellefonte
Joined Dec 2007
Timocharis <Dave North> builds very nice motors, one of his Micro Dan re-winds or posted forsale by other seller.
http://www.rcgroups.com/forums/searc...ery=Timocharis
Dave showed me the ropes of re-winding, but I cannot do it as good as he does... So I buy them from him.
DaOldGuy is online now Find More Posts by DaOldGuy
Old Oct 05, 2010, 09:54 PM
Diggs is offline
Diggs's Avatar
Raleigh, NC
Joined Dec 2006
+1 on that suggestion. His motors are also top notch.
Diggs
Old Oct 06, 2010, 12:05 AM
coinworker's Avatar
Joined Jun 2009
Hey diggs does your suggested setup give unlimited vertical? and thanks for the links but i was hoping for a motor from HK that might give me some good speed... i looked at the scm3223 1200kv set up but that motor is out of stock... any other ideas.
And the hxt900 are out of stock at HK so what's the next best thing from them... lots of choices to choose from any opinions. Thanks again guys.
Old Oct 06, 2010, 04:55 AM
DaOldGuy's Avatar
Joined Dec 2007
This motor stock from Hobby City puts out between 17 and 18 ounces of thrust with an 8X4 and if your build is like most around 9 ounces that is 2 to 1 power over weight.
http://www.hobbycity.com/hobbyking/s...s_Motor_1500kv
I put these servos in mine, metal gear 14 gram
http://www.hobbycity.com/hobbyking/s...idProduct=8303
Old Oct 06, 2010, 10:17 AM
coinworker's Avatar
Joined Jun 2009
so now i'm slightly confused is the 2730 1500kv faster than the 1700kv? man i suddenly feel like a newbie again. of course i really never have motor shopped before.
Old Oct 06, 2010, 10:28 AM
Diggs is offline
Diggs's Avatar
Raleigh, NC
Joined Dec 2006
That motor is what the ritewing guys are flying on their 44" IYF wings, which is heavier. I would think this motor on a Swift II would be pretty ballistic. Vertical shouldn't be a problem in the least seeing what these do on the IYF's. The IYF is a better choice for speed than the swift II IMO. I haven't tried this motor on the Swift II, but the fact it is only 10 or so grams heavier than the blue wonders, it should be a perfect match if you want some speed and thrust. Sorry, don't really have a suggestion for the Hobby City option. I would look to find something that has been hand rewound.
Diggs
Old Oct 06, 2010, 10:31 AM
DaOldGuy's Avatar
Joined Dec 2007
not really, higher Kv needs a smaller prop but the end result if set up properly you can get the same results. It is all about having an efficent set up, good power, long flight time. A Watt meter is your friend no matter what motor you choose, you just need to dial it in with prop and lipo. They are cheap, buy a couple different Kv and set it up to you liking.
Old Oct 06, 2010, 02:25 PM
coinworker's Avatar
Joined Jun 2009
hey thanks for all the help guys! i decided, since the hxt900's were back in stock and moving fast ,that i would place an order before the servo's got back ordered again. So i went with the 2730 set up... i bought both the 1500 and 1700 i know i can always use the spare on another yak 55. Now it's time to sit and wait for the orders to come in. i do have a watt and amp meter so i will be using that to check stuff out... by the way whats the max amps and watts that the 2730's can take? i don't trust the HK specs because i know they can handle a 3s battery but that's not in the specs.
Old Oct 06, 2010, 03:41 PM
DaOldGuy's Avatar
Joined Dec 2007
They are typically very close to HK spec, those motors cant take much over 10 amps, no matter the cell count, for any time period, 3S @11 volts, 110 watts is the max they typically will put out. Trick is to get the Watts up, but keep the Volts up as close to 11 as possible. Always give yourself room on the ESC for spikes and such, 15 amp is a good idea for something like this if you plan to run wide open all the time.
Old Oct 06, 2010, 04:54 PM
RCModelMB is offline
Find More Posts by RCModelMB
RCModelMB's Avatar
Česká republika, Středočeský, Mladá Boleslav II
Joined Oct 2010
Swift Night Flyer 2
Here's a video of my Swift I "night flyer" :
RCModelMB LED UFO Wing SWIFT - Night Flying Mladá Boleslav (4 min 52 sec)
37 LED
RAY C2826/18
prop. 8x3,8,
2x HITEC HS55
JETI ECO 18
3s 800mA 20C
RCModelMB is offline Find More Posts by RCModelMB
Old Oct 06, 2010, 05:10 PM
DaOldGuy's Avatar
Joined Dec 2007
37 LED
RAY C2826/18
prop. 8x3,8,
2x HITEC HS55
JETI ECO 18
3s 800mA 20C
Very nice!
Old Oct 06, 2010, 06:57 PM
dolbydarma is offline
Find More Posts by dolbydarma
What? Not a T-Rex!!!
dolbydarma's Avatar
USA, CO, Colorado Springs
Joined Mar 2008
Great Job! Nice Video too!
dolbydarma is offline Find More Posts by dolbydarma
Discussion Good setup for a MSComposit Swift II ? myrslakt Foamies (Kits) 4 Oct 10, 2009 02:30 PM
Video Swift II Maiden Sim69 Electric Plane Talk 3 Jan 27, 2007 11:32 PM
Sold Swift II Airbrush line British Scheme Twinkletoze Aircraft - Electric - Airplanes (FS/W) 0 Jan 05, 2007 10:58 PM
Discussion Swift II from MS Composit? db1 Flying Wings 14 Dec 11, 2006 07:13 PM
Discussion My Swift II + Question highboy Flying Wings 2 Nov 29, 2006 11:05 AM
