Old Jul 22, 2010, 01:05 PM
Pantseatflyer is offline
Find More Posts by Pantseatflyer
United States, AR, Fayetteville
Joined May 2005
How do you wire the strips? I have seen them for sale on HK sold by the meter but there is no mention of wiring. I assume you could go through one of the open channels on a receiver.
Pantseatflyer is offline Find More Posts by Pantseatflyer
Old Jul 22, 2010, 01:50 PM
Diggs is offline
Find More Posts by Diggs
Not your average DiggsyBear
Diggs's Avatar
Raleigh, NC
Joined Dec 2006
I tap the LED strips off either my main flight pack or a separate pack. 2~3S will do the trick. Most of the time I parallel a few connectors off my ESC where the battery plugs in. On the Swift II, just pull power from the flight pack and you will be good to go.
Diggs
Diggs is offline Find More Posts by Diggs
Old Jul 22, 2010, 01:54 PM
dolbydarma is offline
Find More Posts by dolbydarma
What? Not a T-Rex!!!
dolbydarma's Avatar
USA, CO, Colorado Springs
Joined Mar 2008
I have the Hobby King Turnigy LED's and they plug into the balance plug for power. Works great - no noticeable loss of flight time either. I have them embedded vertically in the foam (like you would mount a carbon fiber spar) and it works awesome!!!! I would love to get a bunch of them together for a night fly!
dolbydarma is offline Find More Posts by dolbydarma
Old Jul 22, 2010, 10:12 PM
Joined May 2005
Just placed an order for a set through Hobby King. Thanks for the tips! Look forward to flying at night!
Old Jul 23, 2010, 11:31 AM
dolbydarma's Avatar
Joined Mar 2008
the lights are addictive... I just ordered another strip - the more lights the better as far as I can tell...
Old Jul 23, 2010, 12:51 PM
Diggs is offline
Diggs's Avatar
Raleigh, NC
Joined Dec 2006
Check out lowpriceRC for LED strips also. They have very good pricing and they also sell the strips on a spool. So if you order more than 1 meter you get it all on one spool upto 5 meters I think. I kind of like not being forced into 1 meter lengths.
Diggs
Old Jul 23, 2010, 06:35 PM
dolbydarma's Avatar
Joined Mar 2008
They look the same! More Lights - More Fun!
Old Jul 23, 2010, 09:06 PM
Diggs is offline
Diggs's Avatar
Raleigh, NC
Joined Dec 2006
They are for the most part identical with the exception of packaging. I have used both, like them both. Just liked having strips longer than 1 meter. Makes it nice when you cut them, you aren't stuck with a short piece you might not be able to use.
Diggs
Old Jul 24, 2010, 03:54 AM
AngelGL is offline
Find More Posts by AngelGL
Plus Ultra
Asturias (Spain)
Joined Sep 2009
Hi to all,
Im mounting a Swift II right now, following Diggs's recomendations (red wonder, rhino 640 mAh, 8x4, ..) but I have a 2.4 GHz radio. The receiver of my radio has 2 antennas that have to be placed in an angle of 90.
Anybody has placed this kind of receiver in a Swift II? Anybody knows where I can find options of how to place the antennas?
Thanks in advance.
AngelGL is offline Find More Posts by AngelGL
Old Jul 24, 2010, 05:08 PM
danny.act is offline
Find More Posts by danny.act
Electrif(r)ied nitroman
danny.act's Avatar
Belgi, Vlaams Gewest, Putte
Joined Jun 2004
Finally finished the Swift II,
setup: Turnigy 2730-1500, Hyperion style (BMI) 15-20Amp. ESC, 3S 1000mAh, 8x4 HD Gws prop. and GWS servo's. The "CG" is just right with the 3S 1000mAh.
danny.act is offline Find More Posts by danny.act
Old Jul 24, 2010, 09:42 PM
Firepower is online now
Find More Posts by Firepower
Firepower
Firepower's Avatar
North Brisbane, Australia
Joined Mar 2010
Originally Posted by AngelGL View Post
Hi to all,
Thanks in advance.
Easy when you know how. That's why I am spending a lot of time on the forums learning but it is cutting down on my building time.
Swift II quick build guide (combat wing) (9 min 59 sec)
Firepower is online now Find More Posts by Firepower
Old Jul 24, 2010, 10:18 PM
Joined May 2005
Looking good! My balances perfect with a 3s, but had to add some weight to the nose for my 2s Lipos. It is my favorite plane so far.
I'm a new RC flyer and have flown my Swift II every day this with very few mishaps. In fact, tonight I flew a full 10 mins without a crash!
I have noticed one thing. Make sure and check motor mount screws, servo screws and check the elevons to make sure they are true. I flew yesterday and the Swift was flying weird. I brought it in and my motor mount screws were loose!! Now I make sure and do a pre-flight check.
Old Jul 24, 2010, 10:20 PM
bobf is offline
Find More Posts by bobf
Sparky "Electrics Rule"
bobf's Avatar
Mission, BC Canada
Joined Jul 2002
I would not run a antenna in the same hole as a servo wire like that.
http://www.youtube.com/watch?v=ShPTwumUFvg
bobf is offline Find More Posts by bobf
Old Jul 24, 2010, 11:03 PM
Firepower
Firepower's Avatar
Joined Mar 2010
You probably know that the majority of the antenna wire is shielded and the end bits are the working bits. I'd say also it may not be the best but if not going FPV it is probably all right as the range on that TX is quite good.
I have 3 elle bees and two mini swifts and the mini swifts I like much better than the heavy elle bees.
But I am new with Swifts. I have been going through this thread and I have worked out the best motor is a Turnigy 2730 Brushless Motor 1700kv and a 3s LiPo.
I like fast planes so is there anything better.
Old Jul 26, 2010, 05:03 AM
AngelGL is offline
Plus Ultra
Asturias (Spain)
Joined Sep 2009
Firepower, thanks for the video.
In my case, the receiver is a bit different. It's splitted in two parts, one for each antenna.
Can I put one part over the other? Is it recommendable to mantain one part far from the other?
(Sorry if this post is a bit offtopic)
Picture of my receiver below:
Discussion Good setup for a MSComposit Swift II ? myrslakt Foamies (Kits) 4 Oct 10, 2009 02:30 PM
Video Swift II Maiden Sim69 Electric Plane Talk 3 Jan 27, 2007 11:32 PM
Sold Swift II Airbrush line British Scheme Twinkletoze Aircraft - Electric - Airplanes (FS/W) 0 Jan 05, 2007 10:58 PM
Discussion Swift II from MS Composit? db1 Flying Wings 14 Dec 11, 2006 07:13 PM
Discussion My Swift II + Question highboy Flying Wings 2 Nov 29, 2006 11:05 AM
