Old Jun 28, 2010, 11:09 AM
Diggs is offline
Find More Posts by Diggs
Not your average DiggsyBear
Diggs's Avatar
Raleigh, NC
Joined Dec 2006
Originally Posted by DropTank View Post
Went by Home Depot and Lowe's this morning and no Welder. I'll try another Lowe's and Ace tomorrow. I saw UHU in a stick form at Michael's. Is that it or is it in a tube?
I will be using the 1500kv motor from HK. Will the APC 8x4 and the GWS 8040 work?
If you are in Raleigh, I didn't have much luck finding Welder locally. I picked it up once in the Plumbing dept at the Lowes in Garner. As for the prop, the 1500KV and the GWS8040 makes a great combo on 3S.
Diggs
Diggs is offline Find More Posts by Diggs
Old Jun 28, 2010, 11:13 AM
DropTank is offline
Find More Posts by DropTank
Is it Friday yet?
DropTank's Avatar
United States, NC, Raleigh
Joined Jun 2008
Yep, I'm in Raleigh. I'll check a couple more places including the plumbing department.
Thanks!
DropTank is offline Find More Posts by DropTank
Old Jun 29, 2010, 12:20 AM
Truglodite is offline
Find More Posts by Truglodite
Registered Aircraft Offender
Truglodite's Avatar
Carmichael, CA
Joined Feb 2007
Plumbing isle eh? Interesting... hope handymen aren't using welder for plumbing jobs.
If they don't have it, stop by the customer service desk on the way out and ask them to order some. Our local Lowe's carries it in a 2 pack of 1oz tubes (Homax item # 730634 1106). Might even look for/ask for some Dow PB3 foam while you're at it.
Truglodite is offline Find More Posts by Truglodite
Old Jun 29, 2010, 06:43 AM
ghost2212 is offline
Find More Posts by ghost2212
Skint since 2000
ghost2212's Avatar
Reading, United Kingdom
Joined Oct 2008
Control Throws and Expo
What are you guys using?
do i need to trim in any up elevator?
Brett
ghost2212 is offline Find More Posts by ghost2212
Old Jun 29, 2010, 10:27 AM
Skint since 2000
ghost2212's Avatar
Joined Oct 2008
Just maidened my swift
Swift II Maiden (8 min 26 sec)
Flies nicely though it was really windy. I had to add the keychain cam to the nose to get the CofG in the most rearward of the suggestion.
My setup is
Turnigy 2730 1500kv Motor With a Graupner 6x5.5
Mystery 12A
2 Metal Geared Servo's
Rhino 610mah 3s Relatively near the front
What are you guys running and do you find it hard to get the CofG Forward?
Brett
Old Jun 29, 2010, 03:28 PM
unlvace is offline
Find More Posts by unlvace
Las Vegas
Joined May 2008
Brett. Use the rhino 750 3s. Well balance plus more flight time
unlvace is offline Find More Posts by unlvace
Old Jun 29, 2010, 03:59 PM
Skint since 2000
ghost2212's Avatar
Joined Oct 2008
Ok
I'll order a couple of those
Old Jul 02, 2010, 02:00 PM
unlvace is offline
Las Vegas
Joined May 2008
Swift II
http://www.rcgroups.com/forums/showthread.php?t=1267667
Old Jul 06, 2010, 09:17 AM
DropTank is offline
Is it Friday yet?
DropTank's Avatar
Joined Jun 2008
Which mix are ya'll using with the DX6i? Dual aileron or elevon.
Old Jul 06, 2010, 01:00 PM
Sleurhutje is offline
Find More Posts by Sleurhutje
Sleurhutje's Avatar
Netherlands
Joined Sep 2008
You should use Elevon. Otherwise your elevator will not be mixed correctly with the ailerons.
Sleurhutje is offline Find More Posts by Sleurhutje
Old Jul 06, 2010, 07:02 PM
DropTank is offline
Is it Friday yet?
DropTank's Avatar
Joined Jun 2008
Thanks Sleurhutje, thats what I thought.
Old Jul 07, 2010, 03:48 PM
bobf is offline
Find More Posts by bobf
Sparky "Electrics Rule"
bobf's Avatar
Mission, BC Canada
Joined Jul 2002
Well life with a Swift II has not been fun. I normally use a friend to trim out my planes but he is not available now. I had a Swift I which flew great.After many hours of flying I retired it and the ni-mh batteries. I should have waited till I could find someone at my club field to hand launch it for me. I could not get my hands on the controls fast enough after what really where poor launches. My Swift was very easy to launch but lighter I think. I broke the nose on the first launch, never did that on my Swift. And on the third launch I broke the GWS 7 x3.5 prop even with a prop saver they appear to be a real weak prop. I tried a Gws 8 x 4 but that seemed to overload the motor. So now repair the bird the best I can and wait for more props. My local hc carries all most no GWS products now. They also don't sell the Swift anymore. CS price with shipping to Canada is a little high.
Maybe I should go fly my Pawnee 40 or Pulse XT 40.
bobf is offline Find More Posts by bobf
Old Jul 08, 2010, 07:09 PM
GFBurke is offline
Find More Posts by GFBurke
allthingsthatfly.com
GFBurke's Avatar
USA, ID, Meridian
Joined Jan 2007
SwiftII owners, don't miss out
http://allthingsthatfly.com/prize.php
still have the swiftII myself and now a Xeno. Both are great but fly diffrnty.
The Xeno tracks better, but swift is just "bouncy fun".
You need ALL wings!!!
GFBurke is offline Find More Posts by GFBurke
Old Jul 11, 2010, 06:35 PM
dolbydarma is offline
Find More Posts by dolbydarma
What? Not a T-Rex!!!
dolbydarma's Avatar
USA, CO, Colorado Springs
Joined Mar 2008
DX6i Elevon does not work correctly!
I just got my first Swift II (love it) and luckily the guy I bought it from gave me this bit of info before it arrived. Take a look at:
http://www.rcgroups.com/forums/showthread.php?t=940867
I used this guy's fix and it works perfect! My previous elevon plane flys so much better with this fix. Check it out - it will make a world of difference.
dolbydarma is offline Find More Posts by dolbydarma
Old Jul 11, 2010, 08:07 PM
DropTank is offline
Is it Friday yet?
DropTank's Avatar
Joined Jun 2008
Got my two first flights on my Swift today. I really like this thing! The first flight needed some trimming and I got the feel for it. The second flight was later in the day and I switched on the lights and did some low flying. They show up really well. I only have wing tip lights, so it's for low light and not totally a dark sky.
Can't wait until tomorrow!
Discussion Good setup for a MSComposit Swift II ? myrslakt Foamies (Kits) 4 Oct 10, 2009 02:30 PM
Video Swift II Maiden Sim69 Electric Plane Talk 3 Jan 27, 2007 11:32 PM
Sold Swift II Airbrush line British Scheme Twinkletoze Aircraft - Electric - Airplanes (FS/W) 0 Jan 05, 2007 10:58 PM
Discussion Swift II from MS Composit? db1 Flying Wings 14 Dec 11, 2006 07:13 PM
Discussion My Swift II + Question highboy Flying Wings 2 Nov 29, 2006 11:05 AM
