Old Jun 16, 2010, 10:15 AM
eran_k is offline
Find More Posts by eran_k
Eventually...I will fly
Israel
I wonder how you guys manage to get that fibertape to stick well to the EPP, it allways get loose real quiqk on my swift
Eran
eran_k is offline Find More Posts by eran_k
Old Jun 16, 2010, 10:31 AM
b94cast is offline
Find More Posts by b94cast
Benign Forecast
b94cast's Avatar
Colorado
Joined Dec 2009
Eran
I use the 3M Extreme tape - so far it sticks pretty well by itself. On those areas where it really needs to stick, I have read that people first spray the area with some 3M spray adhesive, let it dry, and then tape. Have not actually done that myself yet - but seems to be the consensus as the best way forward at any rate.
-S
b94cast is offline Find More Posts by b94cast
Old Jun 16, 2010, 03:35 PM
Mihai is offline
Find More Posts by Mihai
Cary, NC
Joined Oct 2006
Yes, 3M 77 works well. The other thing that works well is thinned goop, but it's more involved (and smellier).
M.
Mihai is offline Find More Posts by Mihai
Old Jun 17, 2010, 07:49 AM
Jbray is offline
Find More Posts by Jbray
United States, NC, Southport
Joined Mar 2010
Finally got it in the air last night. It flies fine but will need some adjusting for sure. It was a little windy last night and I'm sure that affected it since I built it pretty light. I may actually need some Expo too because my setup has huge throws and I noticed myself giving too much input more than once. I'm gonna dial down the servo travel a bit and add some expo in, I'll see what that does for me.
Jbray is offline Find More Posts by Jbray
Old Jun 17, 2010, 08:18 AM
Diggs is offline
Find More Posts by Diggs
Not your average DiggsyBear
Diggs's Avatar
Raleigh, NC
Joined Dec 2006
setup dual rates on it. When you are flying slow, use the high rates, when you are flying faster, use the low rates.
Diggs
Diggs is offline Find More Posts by Diggs
Old Jun 17, 2010, 08:40 AM
Jbray is offline
Joined Mar 2010
Thanks Diggs,
I'll give it a shot tonight before I mess with anything else. I'm certain the CG is not proper also. Will the "dive test" work with a model this light? Trying to get it ready for this weekend, going to try to fly friday afternoon and Saturday morning.
Old Jun 17, 2010, 11:09 AM
DropTank is offline
Find More Posts by DropTank
Is it Friday yet?
DropTank's Avatar
United States, NC, Raleigh
Joined Jun 2008
Just placed an order from Hobby King for the motor, esc, lipos and servos. I'll order the Swift soon. Maybe Common Sence RC will Have a Fathers Day sale.
DropTank is offline Find More Posts by DropTank
Old Jun 17, 2010, 11:50 AM
Diggs is offline
Diggs's Avatar
Raleigh, NC
Joined Dec 2006
Originally Posted by Jbray View Post
Thanks Diggs,
Yep, the dive test works great on wings. With fathers day, my bday and other stuff. I won't be flying this weekend Too hot anyway. Doubt I will get to see Dix Field for a few weeks.
Diggs
Old Jun 17, 2010, 06:52 PM
Lammergier is online now
Find More Posts by Lammergier
Bone Breaker
Lammergier's Avatar
Dallas , Texas, United States
Joined Oct 2002
iron tape down
try using a monocote iron and iron it down.
Lammergier is online now Find More Posts by Lammergier
Old Jun 26, 2010, 01:51 AM
Impailer is offline
Find More Posts by Impailer
FLY IY, BREAK IT, FIX IT,
Hampshire, United Kingdom
Joined Jun 2005
Eran
spread some foam safe uhu thinly before you stick the tape down. You need quite a while for the non-solvent uhu to go off, but it is worthwhile. Do not stick the tape down until the uhu has gone tacky.
The solvent based uhu may work, but unsure if it attacks the Swifts foam, so check before you use uhu regular!
Impailer is offline Find More Posts by Impailer
Old Jun 26, 2010, 09:13 AM
Diggs is offline
Diggs's Avatar
Raleigh, NC
Joined Dec 2006
Thought I would post this here since some of you might be looking for a good deal on a MS Composit models like the Swift.
http://www.rcgroups.com/forums/showthread.php?t=1265920
Diggs
Old Jun 26, 2010, 01:16 PM
DropTank is offline
Is it Friday yet?
DropTank's Avatar
Joined Jun 2008
My Swift came yesterday. Still waiting on the motor, ESC and Lipo's from Hobby King. Anyway, where do you get uhu?
Old Jun 26, 2010, 01:19 PM
Diggs is offline
Diggs's Avatar
Raleigh, NC
Joined Dec 2006
UHU is getting hard to find in the USA. This model is made with EPP, so you can use Welder Adhesive, which I prefer actually. Don't use Welder on blue core/fan fold or depron though, it will attack it. EPP foam like what the Swifts are made from is resilient to almost anything.
http://orders.homaxproducts.com/cata...Adhesives.aspx
Diggs
Old Jun 27, 2010, 07:43 PM
Truglodite is offline
Find More Posts by Truglodite
Registered Aircraft Offender
Truglodite's Avatar
Carmichael, CA
Joined Feb 2007
I second that. Welder is available at Lowe's. A few Lowe's stores I've been to don't have it on the shelf, but they can order it. FWIW, my local Michael's craft store carries UHU Por. I prefer UHU over welder for some things, like blenderm hinges and other less critical structural areas.
Kev
Truglodite is offline Find More Posts by Truglodite
Old Jun 28, 2010, 11:06 AM
DropTank is offline
Is it Friday yet?
DropTank's Avatar
Joined Jun 2008
Went by Home Depot and Lowe's this morning and no Welder. I'll try another Lowe's and Ace tomorrow. I saw UHU in a stick form at Michael's. Is that it or is it in a tube?
I will be using the 1500kv motor from HK. Will the APC 8x4 and the GWS 8040 work?
Discussion Good setup for a MSComposit Swift II ? myrslakt Foamies (Kits) 4 Oct 10, 2009 02:30 PM
Video Swift II Maiden Sim69 Electric Plane Talk 3 Jan 27, 2007 11:32 PM
Sold Swift II Airbrush line British Scheme Twinkletoze Aircraft - Electric - Airplanes (FS/W) 0 Jan 05, 2007 10:58 PM
Discussion Swift II from MS Composit? db1 Flying Wings 14 Dec 11, 2006 07:13 PM
Discussion My Swift II + Question highboy Flying Wings 2 Nov 29, 2006 11:05 AM
