Old Jun 10, 2010, 10:45 AM
b94cast is offline
Find More Posts by b94cast
Benign Forecast
b94cast's Avatar
Colorado
Joined Dec 2009
Originally Posted by Diggs View Post
I would say that's a much better choice. I am not sure of the AUW of his Swift II FPV wing, but the 1500kv blue wonder would barely fly it. So a few more oz's of thrust should do the trick. Spinning a bit larger prop would help, but you don't want to get to large and induce torque roll.
Diggs
Would it be a somewhat safe to say that given sufficient thrust that this wing would fly, relatively regardless of the speed? I know I am heavier than a nice light build - but I also dont have a cat strapped onto it - I was hoping for something that was able to fly a bit slow, speed not really being the target at all. Slow with responsiveness - rather like your light build setup - only with a not so light setup...
Thanks!
-S
b94cast is offline Find More Posts by b94cast
Old Jun 10, 2010, 11:19 AM
Diggs is offline
Find More Posts by Diggs
Not your average DiggsyBear
Diggs's Avatar
Raleigh, NC
Joined Dec 2006
Thanks!
-S
I think it will fly, but that is speculation only. I have no clue how heavy it is, or how well it is CG'ed. Without the cat, and from what I can see, I think weight is your main obstacle, but I also wonder if your cg is tail heavy? With enough thrust and speed it should fly, but I think due to the added weight, adding thrust would be more helpful than adding speed.
My 40" Ritewing Demon Lite weighs in probably at 4-5 lbs, so I think your swift II will fly, but it aint going to be at walking speed. Again speculation, not sure how heavy it is, and if I did know all I could do is recommend your setup produce an equal or greater amount of thrust. Get the CG set properly and give it a go. It should work.
Diggs
Diggs is offline Find More Posts by Diggs
Old Jun 11, 2010, 10:31 AM
Mihai is offline
Find More Posts by Mihai
Cary, NC
Joined Oct 2006
Well, at some point I built and flew a 30oz composite wing of the same shape as the Swift 2. I had 400W on it on a small prop (4.5x4.5 if I recall exactly). Was a bear to fly as it has tremendous inertia, so I had to plan everything in advance, but it flew. My knees were shaking while flying as I had 7oz of lead epoxied in the nose of the wing - at the speeds of that wing in a dive that would go through everything.
M.
Mihai is offline Find More Posts by Mihai
Old Jun 11, 2010, 05:46 PM
bobf is offline
Find More Posts by bobf
Sparky "Electrics Rule"
bobf's Avatar
Mission, BC Canada
Joined Jul 2002
Well I heard from Common Sense and they have no spare motor mounts. They did say they would contact the supplier and put my name on a email list.
Anyway I went ahead and mounted a piece of ply on the front of the mount left after the locktite cracked most of it. It seems to have worked and only took about 30 minutes.
And as a side note don't get ca and kicker on your hand. It is a rather hot experience.
Have a look.
Originally Posted by bobf View Post
I have been looking at the mount that is left and I think I can glue a piece of ply onto the front of the mount. I will try. Nothing to loose but time and I have lots of that just not a lot of energy.
bobf is offline Find More Posts by bobf
Old Jun 11, 2010, 07:02 PM
b94cast is offline
Benign Forecast
b94cast's Avatar
Colorado
Joined Dec 2009
Have a look.
Looks great!
If all else fails, I have a stock mount (already assembled, took it off the wing that I am trying to turn into a FPV setup) that you can have - just pay whatever the shipping is.
Re: the ca/kicker - I learned that one the hard way. I had ca covering a fair portion of the backside of my hand, didnt notice (it was the hand holding the bits) and grabbed a bottle of kicker and proceeded to spray - there were a few blisters from that - 0o
Old Jun 11, 2010, 08:00 PM
bobf is offline
bobf's Avatar
Mission, BC Canada
Joined Jul 2002
Ok I give up. What does FPV stand for?
Old Jun 11, 2010, 08:05 PM
b94cast is offline
Benign Forecast
b94cast's Avatar
Colorado
Joined Dec 2009
First Person Video
Camera mounted on airplane, head mounted display ground side to see through the camera on the airplane realtime -
Old Jun 11, 2010, 11:34 PM
Lammergier is online now
Find More Posts by Lammergier
Bone Breaker
Lammergier's Avatar
Dallas , Texas, United States
Joined Oct 2002
Has anybody tried a ritewing build on a swift. I have a couple of kits I would like to experiment on. Something that would do over 100mph. I have the gear
I would need to beef up the airframe and put some balsa elevons on it.
Lammergier is online now Find More Posts by Lammergier
Old Jun 12, 2010, 02:54 PM
bobf is offline
bobf's Avatar
Mission, BC Canada
Joined Jul 2002
Well finally my Swift II Red Dart is finished. Considering I bought all the parts last year to replace my Swift I. I am using a Lasertoyz 2712-1700 Blue Thunder and a 7035 prop. I tried a GWS8040 but that pushed 15 amp which is running my esc at max.
Old Jun 12, 2010, 09:58 PM
Atom1025 is offline
Find More Posts by Atom1025
Fly me to the moon...
Atom1025's Avatar
Sacramento
Joined Jun 2005
I built some swift II night fliers. The AUW is 8.55oz with a 610 3s! Still amazingly below recommended weight! So A light loftey night flier is totally achievable.
I am selling them to fund my mortgage payment. You can find the for sale thread in the FS forum. I cant provide a link due to cross posting rules.
Atom1025 is offline Find More Posts by Atom1025
Old Jun 13, 2010, 03:19 AM
Truglodite is offline
Find More Posts by Truglodite
Registered Aircraft Offender
Truglodite's Avatar
Carmichael, CA
Joined Feb 2007
Originally Posted by Lammergier View Post
... I have a couple of kits I would like to experiment on. Something that would do over 100mph...
My $.02, the Swift has a thick airfoil that is very asymmetrical. So it's sorta meant for either floating around, or medium speeds with "snappy" aerobatics. My Swift is setup for the latter, and it does no more than 70mph. It has an AUW of 12oz with a 300W Microdan setup; that kind of power would make a thin airfoil symmetrical wing go 100mph easy. It'll take a ridiculous amount of power to get a swift there; guessing 500W, maybe more.
No harm in trying though. As far as I know you'd be the first one with a 100mph Swift.
Y'know, I wouldn't mind if someone came up with a Swift sized speedster.
Kev
Truglodite is offline Find More Posts by Truglodite
Old Jun 13, 2010, 04:19 PM
unlvace is offline
Find More Posts by unlvace
Las Vegas
Joined May 2008
http://www.rcgroups.com/forums/showthread.php?t=1259439
unlvace is offline Find More Posts by unlvace
Old Jun 14, 2010, 02:49 PM
Bone Breaker
Lammergier's Avatar
Joined Oct 2002
Hey atom 1025.I have some HK strip leds that I would like to try like you did.
How did you install them. Just cut a slit? Are they as bright on the bottom as they are on top?
Old Jun 14, 2010, 03:25 PM
Sleurhutje is offline
Find More Posts by Sleurhutje
Sleurhutje's Avatar
Netherlands
Joined Sep 2008
On the place you'll stick the strips, put some UHU POR or something similar, wait for 10 minutes and then stick the LED strips to the wing. The self-adhesive tape on the HK LED strips is 3M and sticks very good. On the bottom side, put a little bit of 5 mins. epoxy on each LED to prevent them from tearing off on a hard landing.
And just put them both on top and the bottom, it's even easier to make different patterns to recognize top side from bottom side.
Sleurhutje is offline Find More Posts by Sleurhutje
Old Jun 14, 2010, 08:04 PM
Atom1025 is offline
Atom1025's Avatar
Sacramento
Joined Jun 2005
Using a dremel I routed a 3mmx10mm slot and slid them in. They are free floating. This way they are fully shielded from the elements....
IMHO it does not jeopardize the structure at all.
The top has a crisper look, you see each LED. The bottom is washed out and just glows.
Discussion Good setup for a MSComposit Swift II ? myrslakt Foamies (Kits) 4 Oct 10, 2009 02:30 PM
Video Swift II Maiden Sim69 Electric Plane Talk 3 Jan 27, 2007 11:32 PM
Sold Swift II Airbrush line British Scheme Twinkletoze Aircraft - Electric - Airplanes (FS/W) 0 Jan 05, 2007 10:58 PM
Discussion Swift II from MS Composit? db1 Flying Wings 14 Dec 11, 2006 07:13 PM
Discussion My Swift II + Question highboy Flying Wings 2 Nov 29, 2006 11:05 AM
