Old Jun 07, 2010, 03:08 AM
scousethief is offline
Find More Posts by scousethief
scousethief's Avatar
United Kingdom, England, Redcar
Joined Jan 2006
Just use an emax 2812 motor 18 amp esc and 7x5 prop , that was more than enough to fly a 1500mah 3cell of 113g.
scousethief is offline Find More Posts by scousethief
Old Jun 07, 2010, 02:04 PM
bobf is offline
Find More Posts by bobf
Sparky "Electrics Rule"
bobf's Avatar
Mission, BC Canada
Joined Jul 2002
I wonder how it compares to a Lasertoy 2712-17 1700kv motor. Appears to me to be a little hotter. Great price though.
bobf is offline Find More Posts by bobf
Old Jun 07, 2010, 04:34 PM
bobf is offline
bobf's Avatar
Mission, BC Canada
Joined Jul 2002
The manual for the Swift II shows tape top and bottom. I never used tape on my Swift I but the Swift II will be faster. Is it needed. I don't mind on the bottom but I don't like it on top. what's the point of the nice paint job.
Old Jun 08, 2010, 02:35 AM
Truglodite is offline
Find More Posts by Truglodite
Registered Aircraft Offender
Truglodite's Avatar
Carmichael, CA
Joined Feb 2007
Originally Posted by twister782 View Post
just for the record. I used blue locktite on my MS composite swift 2. I used it on the screws that hold the motor on the motor mount. It shattered the mount like glass. It just crumbled to the touch. Just my 2 cents
Might as well add this... Loctite thread-lockers are for metal to metal only. I also learned that the hard way.
Kev
Truglodite is offline Find More Posts by Truglodite
Old Jun 08, 2010, 02:42 AM
Joined Jan 2006
clueless about the other motor Bob i can only say i use the 2812 on my swift II , toro 900 and 2 strykers its a decent enough cheap motor which is all i care about lol.
Old Jun 08, 2010, 03:03 AM
Truglodite's Avatar
Carmichael, CA
Joined Feb 2007
b94cast,
Assuming a Microdan is out of budget... the emax 2812 is actually 1660Kv. Here's Dr Kiwi's numbers for that motor:
http://www.rcgroups.com/forums/attac...mentid=2872873
So around ~23oz/17A max. I'm not exactly sure what a stock 1500Kv BW does on 3cell with an 8040hd, but that sounds over the top. Are you stuck with an 8" prop? If you can fit a 9" prop there are a lot more good options over the counter. If you can afford a Microdan 1490Kv, you'll have it in spades... there are also <$25 rewound blue wonders in the FS/W forums that can do well over 20oz on 3cell/8040hd under 12A, and that might be the ticket. A 40oz+ class motor with camera on a Swift will keep your thumbs busy unless it's fast enough.
Cheers,
Kev
Old Jun 08, 2010, 04:15 PM
Ping is offline
Find More Posts by Ping
Ping's Avatar
Indianapolis
Joined Aug 2004
Started building my Swift finally. How do you align the thrust line when using the tube style motor mount? Do you try and center it straight through the trailing edge or align one edge flush with the top or bottom of the airfoil?
Ping is offline Find More Posts by Ping
Old Jun 08, 2010, 04:16 PM
b94cast is offline
Find More Posts by b94cast
Benign Forecast
b94cast's Avatar
Colorado
Joined Dec 2009
Originally Posted by Truglodite View Post
b94cast,
Cheers,
Kev
thanks for all the info!
With how I have this setup, I should be able to go up at least a couple of sizes on the prop - but still learning - so all of this info is great! I was thinking that I just couldnt do FPV as I wanted on this, but had not considered strapping a bigger motor/prop combo to it.
Thanks!
b94cast is offline Find More Posts by b94cast
Old Jun 09, 2010, 12:52 AM
Truglodite's Avatar
Carmichael, CA
Joined Feb 2007
NP bro,
If you can fit a 9", you've got lots of options. A 42gm ax2210n would be nice if you are going cheap; it will do about 25oz with 11A and a GWS9050. Note that the AX bearing tube is larger, so you may or may not have to drill new holes to fit the stock AX mount. Another thing to consider is torque; with extra power and a larger prop, you might find the torque troublesome during steep climbs and hard acceleration. Then again it might be manageable, and worth the efficiency for longer or more aggressive FPV sessions.
A Motrolfly DM2210-1700Kv will be much less torqy than the above setup. It's $36 and a portly 53gm, but with a 7x5e will do 29oz/21A. The neat part about this setup is it'll also have more pitch speed, so you won't be battling with stall as much. There's something to be said about that when your flying FPV I think.
Thing is, you're going to have to make sure these heavier motors aren't going to force you to add a ton of lead for CG. With the motor far back enough to fit a 9" prop, that's going to be a challenge I think. If it's looking impossible, a 36gm Microdan 1490 would be the hail-mary.
Cheers,
Kev
Old Jun 09, 2010, 04:23 PM
bobf is offline
bobf's Avatar
Mission, BC Canada
Joined Jul 2002
Same problem. Were you able to order a replacement mount? I emailed Common Sense and phoned but as of yet no reply. I don't think I am willing to order a complete wing just for the motor mount. They also have no stock on the white Swift II which would save a little money.
Old Jun 09, 2010, 06:01 PM
bobf is offline
bobf's Avatar
Mission, BC Canada
Joined Jul 2002
I have been looking at the mount that is left and I think I can glue a piece of ply onto the front of the mount. I will try. Nothing to loose but time and I have lots of that just not a lot of energy.
Old Jun 09, 2010, 06:50 PM
Subsonic Ken is offline
Find More Posts by Subsonic Ken
Omaha Nebraska
Joined Apr 2008
NP bro,
Cheers,
Kev
Better yet for a wing I would recomend the Motrolfly 2210-2200 on 3s with a 6x5.5 APC, at 10.8v I got 96mph pitch speed and 806 grams (28.4 Oz) thrust 28.6 amps. I use this set up in my fun jet with a 1300 30c Sonic Power lipo.
Ken
Subsonic Ken is offline Find More Posts by Subsonic Ken
Old Jun 09, 2010, 07:18 PM
Diggs is offline
Find More Posts by Diggs
Not your average DiggsyBear
Diggs's Avatar
Raleigh, NC
Joined Dec 2006
He is trying to do FPV from his swift II, and needs more thrust to deal with the modifications he has made to the wing. While that is a fine setup for speed, it really isn't suitable for his application.
Diggs
Diggs is offline Find More Posts by Diggs
Old Jun 09, 2010, 09:23 PM
Omaha Nebraska
Joined Apr 2008
Ok, what about using the 2210-1700 with a Graupner 8x4 slim prop, motor calc puts the thrust around 40 ounces. How much thrust we looking for?
Ken
Old Jun 09, 2010, 09:49 PM
Diggs is offline
Diggs's Avatar
Raleigh, NC
Joined Dec 2006
Ken
I would say that's a much better choice. I am not sure of the AUW of his Swift II FPV wing, but the 1500kv blue wonder would barely fly it. So a few more oz's of thrust should do the trick. Spinning a bit larger prop would help, but you don't want to get to large and induce torque roll.
Diggs
Discussion Good setup for a MSComposit Swift II ? myrslakt Foamies (Kits) 4 Oct 10, 2009 02:30 PM
Video Swift II Maiden Sim69 Electric Plane Talk 3 Jan 27, 2007 11:32 PM
Sold Swift II Airbrush line British Scheme Twinkletoze Aircraft - Electric - Airplanes (FS/W) 0 Jan 05, 2007 10:58 PM
Discussion Swift II from MS Composit? db1 Flying Wings 14 Dec 11, 2006 07:13 PM
Discussion My Swift II + Question highboy Flying Wings 2 Nov 29, 2006 11:05 AM
